2 Replies Latest reply on Jul 11, 2011 5:21 PM by preditorj40153117
    Newbie - External Monitoring and Media Prefs
    preditorj40153117 Level 1
      i have a black magic card. I had gotten premier to send a signal via hdmi to my external 27inch monitor but it has just quit. At one time it would send the source monitor A/V but not the timeline.
      What is the correct set up so that i can make PP default to sending the stream to the external on every project?
      Also who do i set premier to dual screen editing?
      In premier preferences under the media tab i see the intermediate media timebase  is set to 29.97fps drop-frame. The footage i am using is 720p60.
      Does this effect how Premier is handling my source footage? If not what does the window effect?
        • 1. Re: Newbie - External Monitoring and Media Prefs
          Colin Brougham Level 6
          There is no way to set this on a project basis; it's per sequence. You must use one of the Blackmagic sequence presets to enable external monitoring from a sequence.
          I'm not positive, but this should be possible with the BMD card. However, setting up two desktop monitors is an OS setting, not necessarily a Premiere Pro setting. As long as you can expand your desktop over two monitors, you should be able to set up Premiere Pro and its various frames and panels to utilize both monitors. This is independent of full-screen external monitoring through the BMD.
          In premier preferences under the media tab i see the intermediate media timebase ... Does this effect how Premier is handling my source footage? If not what does the window effect?
          That dictates (or is supposed to, anyway) how imported media that does not have a specific timebase/frame rate should be handled on import. As far as I'm aware, this only affects image sequences--I've never seen it have any influence on an imported video or audio file. Even if it's set wrong when you import an image sequence, you can reinterpret the image sequence once it's in your project. Simply right-click it and select Modify > Interpret Footage. If you don't use image sequences, I think you can safely ignore this setting.
