I have an RH8 project which takes
7 minutes to open. I'd like to try to find the culprit and
was going to start removing parts of the project and see if I can identify
anything bad. I've already recreated the cpd file several times. It was suggested here
by Peter, I believe, to try this method I described. My question regards what is the best way of approaching this? Can I delete whole folders at a time or should I start small by deleting html files?
I believe the usual method is big chunks. So take a copy of your project and delete half the project. See how it runs. If it's fine, take another original copy and delete the other half. Keep going on the bad half to narrow down the problem area.
HTH,
Amber
Just wondering if I should do this from Explorer inside or outside of
Robohelp or does it matter?
Gloria
Hi Gloria
Unless you are masochistic and wanting to cause yourself all manner of grief, always, Always, ALWAYS do things like this from inside RoboHelp!
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7, 8 or 9 within the day! |
gracias, amigo!
