4 Replies Latest reply on Nov 15, 2006 1:23 PM by Newsgroup_User
    Video object _width property
    Level 7
      Hi all,
      I have a class which has a private property 'screen' containing a
      reference to a Video object like:
      private var screen:Video;
      A few lines below there's a public method returning the width of the
      video object:
      public function getWidth():Number{
      return this.screen._width;
      Now, when I compile I get the following error:
      **Error**
      D:\aloft\FlashLibrary\current\nl\aloft\media\phpflv\ScreenView.as: Line
      35: There is no property with the name '_width'.
      However, when i run the code and call the method I get the width of the
      object without any problems.
      If I have the method return any of the properties without the underscore
      (like: width, smoothing, deblocking etc.) I get no compile error.
      What am I missing here?
      Thanks in advance,
      Manno
      Manno Bult
      manno@xs4all.nl
        • 1. Re: Video object _width property
          injpix Level 3
          The “_width” property is used to assign the video a value or transform the video to whatever value. The “width” property is a read-only property. It will simply just return the current width of the video. Look at the example in the link below;
          http://livedocs.macromedia.com/flash/8/main/wwhelp/wwhimpl/common/html/wwhelp.htm?context= LiveDocs_Parts&file=00002848.html
          • 2. Re: Video object _width property
            Level 7
            myIP wrote:
            > The ?_width? property is used to assign the video a value or transform the
            > video to whatever value. The ?width? property is a read-only property. It
            > the link below;
            I know the distinction between the two, I was only wondering why it
            gives compiletime errors when referring to the "_width" property (whith
            preceding underscore) and not when referring to the "width" property.
            Though representing different properties, they are both _valid_ properties.
            The error makes no sense to me really since the _width property does
            exist while it claims it does not...
            Manno
            Manno Bult
            manno@xs4all.nl
            • 3. Re: Video object _width property
              injpix Level 3
              Now I fully understand your question. I don’t know why that is and I am curious myself. Hopefully someone will post something about it.
              • 4. Re: Video object _width property
                Level 7
                Hi myIP
                thanks for the heads up,
                I've found an ugly hack though:
                The anonimous function in the init method compiles without error and
                works, like the one below it, as expected. For now I'm OK with it, but
                it annoys me pretty much. Maybe later I'll look into it deeper at a
                later time (and post it here). Must be something silly...
                private function init(target:MovieClip,
                depth:Number,
                ns:NetStream){
                //... more code here
                this.update = function(){
                this.screen._width = this.screen.width;
                this.screen._height = this.screen.height;
                public function update(){
                myIP wrote:
                > Now I fully understand your question. I don?t know why that is and I am curious myself. Hopefully someone will post something about it.
                Manno Bult
                manno@xs4all.nl
