When trying to use the latest AMI on AWS for Flash Media Server, everything seems to work right going upstream (server connects, stream goes to server), but the F4M file doesn't seem to make any client or OMFS happy. I get the following error - "The F4M document contains errors. Error #1009". Is this a bug?
Can you check if F4F recording is happening and .stream file is properly created in events folder of livepkgr.
Thanks. Yes it seems to be. But nothing spiting out. If I install the older version of FMS 4, everything works fine, but an Adobe bulletin says they is a security flaw in that version.
Is there something I have to do differently with FMS 4.0.2.0812 so it will work like FMS 4.0.1.8011?
Double checked after another reinstall of the instance and ssh to the server and no .stream file in the livepkgr folder. Just _definst_...
It might be permission issue - after reinstall can you give full permissions to your FMS installation folder
>> cd /opt/adobe/fms
>> chmod -R 777 .
>> cd /mnt/applications
>> chmod -R 777 .
I just want to rule out any functional bug - just want to make sure if its permission issue or not.
Once you run above command, publish and try to playback the stream - see if you get same error.
Thanks for your response. Those folders are wide open right now. It doesn't make a difference. Also, I did note that on the splash page when logging into the server had version number of 4.0.2.8011 instead of the 4.0.2.8012 AMI that I launched. Is that just a typo?
Still not working....
Thanks for using FMS on AWS.
The issue you reported is acknowledged and confirmed. Please be sure that we working on this and will get back to with the resolution.
The splash screen that you see is just plain text. So, it has to go down as a typo. The correct version is indeed 4.0.2 r8012.
Thanks!
Puting livestream%i?adbe-live-event=liveevent on the stream field whiling streaming a single rate can cause that error.
Please check if you're not using livestream%i?adbe-live-event=liveevent instead of livestream?adbe-live-event=liveevent when creating the single rate streaming.
Good Luck!
I am also getting this error message. And I have also tried by removing %i
still getting same error.
I wanna know the process of HTTP streaming only
Hi Joy, Are you using latest version of Adobe media server(which is 5.0.11 as of today).
yes Sir.. But the main problem is, I have created the crossdomain.xml file
<?xml version="1.0"?>
<!-- http://www.adobe.com/crossdomain.xml -->
-<cross-domain-policy>
<allow-access-from domain="*"/>
</cross-domain-policy>
But still getting crossdomain access denied . the file is in the webroot directory
if the os is linux please check permission and ownership...The file should be owned by ams user and ams group.
Thank you fro your reply. But I am using Windows Server 2012 R2 Data center.
And unable to get access.
I am attaching screenshot from default install of AMS on my desktop machine(WIN7).
Please check my configuration ...
I guess(I am not sure though) your crossdomain file has .txt extension...Instead it should be crossdomain.xml. Please turn off hide extensions in explorer menu.
oh. but it's really .xml
Hummm..in that case I am not sure why you are getting access denied. Can you fetch http://loclahost/crossdomian.xml in browser and confirm?
Yes, I can. And also with the live ip
like -
http://1.1.1.1/crossdomain.xml
is it crossdomain or crossdomian ?
Hi, I have solved the issue.
Please help me on another issue
the f4m file is geeing large. How can manage the size ?
