3 Replies Latest reply on Jul 18, 2011 2:11 AM by eprevot123
    Zend Debugger not starting
    drew_falkman
      Hello--
      I'm having a serious time trying to get the Zend Debugger working on the PHP side with MAMP 1.9.6.
      I added the following lines at the end of my php.ini file:
      zend_extension = "/Applications/MAMP/bin/php5.3/zend/ZendDebugger.so"
      zend_debugger.allow_hosts = 127.0.0.1/32
      zend_debugger.expose_remotely = always
      I see in my php info that it's installed and the variables. However, I cannot connect to the debugger from FB/Zend Studio. When I run a debugging session, the PHP [Headless PHP Application] has one item in the stack: <terminated> Session Terminated.
      I have searched high and low and the only thing I could find was this line in the Apache log, apparently from the startup.
      [Zend Debugger] Debugger compile handler overriden, will not be active in this request
      I suspect that there may be a conflict? I tried removing disabling XCache by setting the size to 0. Same thing happened. I tried removing XCache entirely but it seemed to disable PHP functioning.
      Help...!?
      Thanks.
