0 Replies Latest reply on Jul 12, 2011 11:22 PM by SagerAdobe
    ALC-REP-018-000
    SagerAdobe Level 1
      Hi everyone,
      I have the following problem appears when I open the pdf form from a user task (It was working fine),,,, can any body help
      2011-07-13 09:15:05,892 ERROR [com.adobe.workflow.AWS] An exception was thrown with name com.adobe.repository.RepositoryException message:ALC-REP-018-000: Resource [urn:uuid:id:defc350e-52ac-4caf-b835-182319221f46] does not exist or you do not have sufficient rights to access it. while invoking service RepositoryService and operation readResourceContent and no fault routes were found to be configured.
      2011-07-13 09:15:05,892 ERROR [com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker] An exception was thrown with name com.adobe.repository.RepositoryException message:ALC-REP-018-000: Resource [urn:uuid:id:defc350e-52ac-4caf-b835-182319221f46] does not exist or you do not have sufficient rights to access it. while invoking service RepositoryService and operation readResourceContent and no fault routes were found to be configured.
      2011-07-13 09:15:05,907 ERROR [com.adobe.workflow.AWS] An exception was thrown with name com.adobe.repository.RepositoryException message:ALC-REP-018-000: Resource [urn:uuid:id:defc350e-52ac-4caf-b835-182319221f46] does not exist or you do not have sufficient rights to access it. while invoking service RepositoryService and operation readResourceContent and no fault routes were found to be configured.
      2011-07-13 09:15:06,001 ERROR [org.apache.axis.encoding.ser.BeanSerializer] Exception:
      java.lang.NullPointerException
      at com.adobe.idp.dsc.provider.impl.soap.axis.ser.ArraySerializer.serialize(ArraySerializer.j ava:76)
      at org.apache.axis.encoding.SerializationContext.serializeActual(SerializationContext.java:1 504)
      at org.apache.axis.encoding.SerializationContext.serialize(SerializationContext.java:980)
      at org.apache.axis.encoding.SerializationContext.serialize(SerializationContext.java:707)
      at com.adobe.idp.dsc.provider.impl.soap.axis.ser.AdobeAxisBeanSerializer.serialize(AdobeAxis BeanSerializer.java:281)
      at org.apache.axis.encoding.SerializationContext.serialize(SerializationContext.java:680)
      at org.apache.axis.AxisFault.writeDetails(AxisFault.java:865)
      at org.apache.axis.message.SOAPFault.outputImpl(SOAPFault.java:165)
      at org.apache.axis.message.MessageElement.output(MessageElement.java:1208)
      at org.apache.axis.message.SOAPBody.outputImpl(SOAPBody.java:139)
      at org.apache.axis.message.SOAPEnvelope.outputImpl(SOAPEnvelope.java:478)
      at org.apache.axis.AxisFault.output(AxisFault.java:759)
      at org.apache.axis.SOAPPart.writeTo(SOAPPart.java:301)
      at org.apache.axis.SOAPPart.writeTo(SOAPPart.java:269)
      at org.apache.axis.SOAPPart.saveChanges(SOAPPart.java:530)
      at org.apache.axis.attachments.AttachmentsImpl.getAttachmentCount(AttachmentsImpl.java:554)
      at org.apache.axis.Message.getContentType(Message.java:486)
      at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:775)
      at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
      at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
      at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
      at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:290)
      at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
      at com.adobe.idp.dsc.provider.impl.soap.axis.InvocationFilter.doFilter(InvocationFilter.java :43)
      at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:235)
      at com.adobe.idp.um.auth.filter.CSRFFilter.doFilter(CSRFFilter.java:41)
      at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
      at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
      at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
      at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.ja va:179)
      at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:84)
      at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
      at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
      at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java: 157)
      at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
      at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:241)
      at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
      at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.ja va:580)
      at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
      at java.lang.Thread.run(Thread.java:619)
      java.io.IOException: java.lang.NullPointerException
      at com.adobe.idp.dsc.provider.impl.soap.axis.ser.AdobeAxisBeanSerializer.serialize(AdobeAxis BeanSerializer.java:326)
      2011-07-13 09:15:06,001 ERROR [org.apache.axis.SOAPPart] Exception:
      java.io.IOException: java.io.IOException: java.lang.NullPointerException
      2011-07-13 09:15:06,001 WARN  [org.apache.axis.attachments.AttachmentsImpl] Exception:
      AxisFault
      faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException
      faultSubcode:
      faultString: ALC-DSC-003-000: com.adobe.idp.dsc.DSCInvocationException: Invocation error.
      faultActor:
      faultNode:
      faultDetail:
      {http://xml.apache.org/axis/}hostname:adobe-srv-1
      at org.apache.axis.AxisFault.makeFault(AxisFault.java:101)
      at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:333)
      at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
      at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
      at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
      at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
      at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
      at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
      Caused by: ALC-DSC-003-000: com.adobe.idp.dsc.DSCInvocationException: Invocation error.
      at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:152)
      at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
      at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
      at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassi vationInterceptor.java:53)
      at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
      at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:357)
      at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequired(Ej bTransactionCMTAdapterBean.java:274)
      at sun.reflect.GeneratedMethodAccessor217.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:597)
      at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
      at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionConta iner.java:237)
      at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:158)
      at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstance Interceptor.java:169)
      at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
      at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
      at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:350)
      at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:181)
      at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:168)
      at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
      at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor. java:138)
      at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:648)
      at org.jboss.ejb.Container.invoke(Container.java:960)
      at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:430)
      at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
      at $Proxy188.doRequired(Unknown Source)
      at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:129)
      at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
      at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
      at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
      at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:188)
      at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
      at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:115)
      at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
      at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:93)
      at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:20 9)
      at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:66)
      at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
      at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:886)
      at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke(WorkflowDSCInvoker. java:347)
      at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:158)
      at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequiresNew (EjbTransactionCMTAdapterBean.java:299)
      at sun.reflect.GeneratedMethodAccessor215.invoke(Unknown Source)
      at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:404)
      at $Proxy188.doRequiresNew(Unknown Source)
      at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:143)
      at com.adobe.idp.dsc.provider.impl.soap.axis.AdobeAxisServiceProvider.invokeMethod(AdobeAxis ServiceProvider.java:222)
      at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
      at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
      ... 33 more
      Caused by: com.adobe.repository.RepositoryException: ALC-REP-018-000: Resource [urn:uuid:id:defc350e-52ac-4caf-b835-182319221f46] does not exist or you do not have sufficient rights to access it.
      at com.adobe.repository.commands.VerifyAccessControlRightsHelper.verify(VerifyAccessControlR ightsHelper.java:492)
      at com.adobe.repository.commands.ReadResourceContentCommand.execute(ReadResourceContentComma nd.java:138)
      at com.adobe.repository.commands.CommandProcessor.execute(CommandProcessor.java:135)
      at com.adobe.repository.bindings.dsc.RepositoryProviderServiceImpl.readResourceContent(Repos itoryProviderServiceImpl.java:687)
      at sun.reflect.GeneratedMethodAccessor1222.invoke(Unknown Source)
      at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
      at com.adobe.repository.bindings.dsc.RepositoryServiceImpl.invocationRequest(RepositoryServi ceImpl.java:226)
      at com.adobe.repository.bindings.dsc.RepositoryServiceImpl.readResourceContent(RepositorySer viceImpl.java:940)
      at sun.reflect.GeneratedMethodAccessor1221.invoke(Unknown Source)
      ... 121 more
