6 Replies Latest reply on Mar 28, 2009 11:24 AM by BKBK
    rounding
    Nick201 Level 1
      I would like to do round. What function i should use in order to get this results.
      .01 - .24 -- 0
      .25 - .50 -- 0.5
      .51 - .74 --- 0.5
      .75 - 1.0 --- 1
      1.01 - 1.24 --- 1
      1.25 - 1.50 --- 1.5
      1.51 -1.74 -- 1.5
      1.75 - 2.0 --- 2
        • 1. Re: rounding
          Level 7
          > results.
          Your going to have to write your own of find one that somebody else has
          written to this kind of strange 'quarter' rounding. That is not normal,
          mathematical rounding that the CFML functions or going to do.
          But you have a pretty good start there, figure out the rules and
          exceptions and then you just need to code a function to uses the data
          with these rules to return the desired results.
          • 2. Re: rounding
            Level 7
            Should be simple, try the following:
            <cfset quarterRound = round(originalNumber*4)/4>
            Chris.
            > results.
            > .01 - .24 -- 0
            > .25 - .50 -- 0.5
            > .51 - .74 --- 0.5
            > .75 - 1.0 --- 1
            > 1.01 - 1.24 --- 1
            > 1.25 - 1.50 --- 1.5
            > 1.51 -1.74 -- 1.5
            > 1.75 - 2.0 --- 2
            • 3. rounding
              BKBK Adobe Community Professional & MVP
              You can immediately see that this is wrong. You're dividing integers by 4 and so will get numbers ending in .25. These are incorrect, as the result must be a whole number or a whole number and a half.
              Here is a possible answer. First, think of the number of whole quarters in a number. For example, there are 2 whole quarters in 0.749, but 3 in 0.75 and 3 in 0.99. The number of whole quarters in the list is as follows:
              .01 - .24 ---> 0
              .25 - .50 ---> 1 - 2
              .51 - .74 ---> 2
              .75 - 1.0 ---> 3 - 4
              1.01 - 1.24 ---> 4
              1.25 - 1.50 ---> 5 - 6
              1.51 -1.74 ---> 6
              1.75 - 2.0 ---> 7 - 8
              The formula for the number of whole quarters in the number x is
              fix(x*4)
              Int(x*4) is good, too, but we'll go with fix(). We now seek a function which we can apply to these whole numbers N to get the required results. A possibility is
              round(N/2)*0.5
              When we apply it to the list of whole numbers, we get
              0 ---> 0
              1 - 2 ---> 0.5
              3 - 4 ---> 1
              5 - 6 ---> 1.5
              7 - 8 ---> 2
              You will see that that is the required result. What we therefore need is the composite of both functions. It is
              round(fix(originalNumber*4)/2)*0.5
              • 4. Re: rounding
                Level 7
                Yes, you are right, I copied some code that I had used that required
                quarter-rounding.
                The required code should be
                <cfset halfRound = round(originalNumber*2)/2>
                The following test show it works.
                <cfoutput>
                <table>
                <cfloop from="0" to="1.5" step="0.01" index="iA">
                <tr>
                <td>#iA#</td>
                <td>#round(iA*2)/2#</td>
                </tr>
                </cfloop>
                </table>
                </cfoutput>
                > You can immediately see that this is wrong. You're dividing by 4 and so will
                > .01 - .24 ---> 0
                > .51 - .74 ---> 2
                > 1.01 - 1.24 ---> 4
                > 1.51 -1.74 ---> 6
                > The formula for the number of whole quarters in the number n is
                > fix(x*4)
                > [int(x*4) is good, too, but we'll go with fix()]
                > round(N/2)*0.5
                > 0 ---> 0
                > 1 - 2 ---> 0.5
                > 3 - 4 ---> 1
                > 5 - 6 ---> 1.5
                > 7 - 8 ---> 2
                • 5. Re: rounding
                  Chris,
                  I prefer your round(originalNumber*2)/2 to my round(fix(originalNumber*4)/2)*0.5. It involves just one function, and so is simpler.
                  • 6. Re: rounding
                    Others
                    fix(2*originalNumber+0.5)/2
                    int(2*originalNumber+0.5)/2
