• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How not to use Cold Fusion and Java
New Here ,
Oct 30, 2006 Oct 30, 2006
Overview
This write up is intended to give java developers that are developing ColdFusion applications some beneficial information: things that are not documented.
Scenario
The company builds enterprise class web application software for fortune 500 companies. It had purchased a CF 7 based product, had and existing proprietary J2EE based product, and needed to integrate the two while meeting a host of new requirements. These requirements were based on delivering a better user experience, faster / cheaper integration, increased flexibility / configuration, useablily, decreasing maintenance costs, the ability to deploy in either install or ASP models. An initiative was started to create a new framework that integrated the best of each technologies. Tactically, this meant that we were to build a hybrid CF and java application: one that used building blocks (decoupled / cohesive components) that would allow applications to be rapidly assembled, configured and deployed. This made sense on several levels, the team was composed of Java and CF developers, the CF rapid application development was very productive, there is great functionality delivered in the CF platform and initial performance tests showed no cause for alarm
The agreed upon design, based on requirements, and analysis by both the CF and Java staff has us using CF in the presentation layer, using a CF based MVC, use of CF based web services. The MVC was deployed using CFC inheritance for model objects and views made use of CF custom tags. The internals of the application, used a rules engine, some proprietary java, ORM, and other J2EE technology. The initial performance of the system was reasonable. We pushed on with product implementation.
Then it was time to load test the application, and tune it. Under load the response times were orders of magnitude slower, sometimes the pages even timed out.
Armed with our profiler, oracle execution plans and we charged ahead addressing issue after issue. Note that we took meticulous care in tweaking the active thread pool and ensuring that our CF setup was tuned for our application. None of the observations here are a condemnation of the language; rather they are aspects that, when considered together, not conducive for building integrated java and CF frameworks that use a structured / OO programming practices. Further detail can be provided on request.
CFC inheritance should be avoided - resolution of variable scope is expensive even if properly declared.
Since CF creates a class per method under the covers call stacks become very large, especially if used in a loop. This is nominally exacerbated by CF calls necessary to set up for the method call (String.toUpper()).
Nesting of loops and if statements should be kept to a minimum - the conditional for each lookup of logical operator like LT, GT are synchronized. Under load this results in thread waits.
Jrun has as single thread pool - both http and web service requests use the same pool. Under load this leads to thread deadlock. There are work arounds, but they are painful.
Recursion should be avoided - we had a few recursive routines and these had to be rewritten.
Custom Tags - should be used sparingly - each custom tag makes a synchronized call to the license server - (This may be fixed in CF 8)
Summary
In the end we got the performance to reasonable numbers, but we ended up moving some code to java (Custom Tags) and getting rid of 'good programming' practices (Inheritance, loops, etc), mandated proper variable scoping for those things left over. We prototyped a sans cold fusion implementation and had an order of magnitude improvement in performance and number of requests served per second.
The lesson? Use Coldfusion in its sweet spot: make a query, iterate over the results and format for display. Extensive use of structure programming techniques or OO CFCs should be avoided: they will work but under load - but are better as a prototype. Building frameworks in CF? Think twice, no three times, and, if you must, be minimalist. Text
TOPICS
Advanced techniques
Views
300
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer ,
Nov 03, 2006 Nov 03, 2006
I appreciate that you took the time to write the above article, feedbacks like this can help a great deal.
Thanks!
Votes
Translate
Translate
Report
Report
Explorer ,
Nov 17, 2006 Nov 17, 2006
LATEST
interesting aslbert123,
Not that I doubt you, but could you answer some questions about your implementation that was so slow:
1.) Did you put your CFCs in the application or server scope?
2.) Were you initializing your CFCs, via CreateObject or <cfinvoke>, on every request?
3.) Are you sure that you were properly Var'ing every variable in your methods? (people typically forget about query names and loop iterator variables)
4.) Could you give examples of how your inheritence was set up?
5.) For CustomTags, did you call them the old <cf_tag> way or the newer, better-performing <cfimport> way?
6.) How did you connect CF to Java exactly?
Aaron
Votes
Translate
Translate
Report
Report
Resources
Documentation
