1 Reply Latest reply on Jul 13, 2011 2:53 PM by blazejewicz
    Save XML file error permission
    frcol
      Hi everyone,
      I read a XML file, edit it and save again:
                      var filePath:String = File.applicationDirectory.resolvePath("alerts.xml").nativePath;
                      var file:File = new File(filePath);
                     var fs:FileStream = new FileStream();
                      fs.open(file, FileMode.READ);
                      fs.addEventListener(IOErrorEvent.IO_ERROR, editsettings_IOError);
                      var xml:XML = XML(fs.readUTFBytes(fs.bytesAvailable));
                      fs.close();
                      fs.open(file, FileMode.WRITE);
                      xml[key] = value;
                      xml.toXMLString();
                      fs.writeUTFBytes(xml);
                      fs.close();
      When I´m in debug mode, everything is fine, but when I generate a Executable installer (native installer), it doesn´t work.
      I don´t have permission.
      Any solution?
        • 1. Re: Save XML file error permission
          blazejewicz Level 4
          Hello,
          That's explicitely marked in documentation to not use "applicationDirectory" for write (updates/modification/deletion/etc), e.g.:
          The File class includes static properties that let you reference commonly used directory locations. These static properties include:
          File.applicationStorageDirectory—a storage directory unique to each installed AIR application
          File.applicationDirectory—the read-only directory where the application is installed (along with any installed assets)
          and later on the same page:
          Modifying content in the application directory is a bad practice, for security reasons, and is blocked by the operating system on some platforms. If you want to store application-specific data, consider using the application storage directory (File.applicationStorageDirectory).
          http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/flash/filesystem/File.h tml#applicationDirectory
          So as pointed in docs you could use applicationStorageDirectory as location where you application-specific content is to be stored/created/updated/written/etc.
          (otherwise everything works fine when running local ADT/debug session - but it could fail at any time when deployed)
          hth,
          kind regards,
          Peter
