3 Replies Latest reply on Oct 31, 2006 9:36 AM by Jumru
    Webservice Integration
    Jumru
      I have developed a sample web service using axis and deployed onto a tomcat server. Both the client and the servers reside in the same domain.
      One of the web services takes a java object as an input. I did not find any reference where I could send the java object to mx:WebService tag. The java class definition is part of the WSDL and is defined using XML schema.
      e.g.
      <mx:WebService id="ws"
      wsdl="/path/to/wsdl"
      showBusyCursor="true"
      useProxy="false">
      <mx:operation name="GetValue">
      <mx:request>
      //how to pass the java input object ?
      //mx:object ? If so, how ?
      </mx:request>
      </mx:operation>
      </mx:WebService>
      Any ideas as to how to best handle such situation ? Any samples or pointers ?
      Thanks in Advance.
        • 1. Re: Webservice Integration
          Jumru Level 1
          Any one there ?
          • 2. Re: Webservice Integration
            Suama
            Hello.
            I can not exect way without looking your WSDL, but I think you can sent input data as a object of ActionScript.
            In my project, some WebService methods, which need a few parameters, are called like this:
            <mx:operation name="someOperation">
            <mx:request>
            <Account>{user.Account}</Account> <-- Normal String
            <Password>{user.Password}</Password> <-- Normal String
            <Record>{record}</Record> <-- Object
            <mx:request>
            </mx:operation>
            The object named "record" is a object defined like this:
            class aRecord {
            private var Id:Number = 0;
            private var Data:String = "";
            public function aRecord():void {
            this.Id = id;
            this.Data = data;
            Sorry my poor English but I'm glad this will be any help with you...
            • 3. Re: Webservice Integration
              Jumru Level 1
              Suama, Thanks for responding. Will look into this.
              The object is simply a java object e.g CustomerRequest The class defn is part of the WSDL and is as follows :
              - <element name="CustomerRequest">
              - <complexType>
              <sequence>
              <element name="id" nillable="true" type="xsd:string" />
              <sequence />
              </complexType>
              </element>
              The above object needs to be sent as part of the web service call via Flex 2. Hope it helps.
