4 Replies Latest reply on Jul 21, 2011 4:29 AM by Peter Kahrel
    UI Issue
    Spitler666
      I have an issue trying to create a basic UI.
      The code works great in Adobe After Effects but in InDesign, I see the window flash up but then disappears.
      Any ideas?
      Thanks.
      Phil
      var myPalette = buildUI(this);
      if (myPalette != null && myPalette instanceof Window) {
      myPalette.show()
      function buildUI (thisObject) {
      if (thisObject instanceof Panel) {
      var myWindow = thisObject;
      } else {
          var myWindow = new Window ("palette", "My Window");
      // alert( myWindow) ;
      myWindow.myPanel = myWindow.add("group");
      myWindow.myPanel.orientation = "column";
      myWindow.myPanel.okButton = myWindow.myPanel.add("button");
      myWindow.myPanel.okButton.text = "OK";
      myWindow.myPanel.cancelButton = myWindow.myPanel.add("button");
      myWindow.myPanel.cancelButton.text = "Cancel";
      myWindow.layout.layout(true);
      myWindow.layout.resize();
      myWindow.myPanel.okButton.onClick = function () {
      ok_pressed();
      myWindow.myPanel.cancelButton.onClick = function () {
      cancel_pressed();
      return myWindow;
      } //function buildUI ()
      function ok_pressed(){;
      alert ("ok");
      function cancel_pressed(){;
      alert ("cancelled");
        • 1. Re: UI Issue
          Larry G. Schneider Adobe Community Professional & MVP
          You might try looking here
          www.kahrel.plus.com/indesign/scriptui-1-6.pdf
          • 2. Re: UI Issue
            Peter Kahrel Adobe Community Professional & MVP
            In InDesign (but not in After Effects) you have to target an engine for palettes to work. Add this line at the top of your script:
            #targetengine "session";
            Peter
            (That pdf might still be useful : )
            • 3. Re: UI Issue
              PhilSpitler
              This worked great thanks.
              One thing I cannot figure out is how to make a dockable UI.
              In After Effects, I simply put the script in the "ScriptUI" folder and it appears as a dockable script.
              Is there a way to do something similar in InDesign?
              Or as a workaround, could I get my script to launch as InDesign starts.
              Thanks.
              Phil
              • 4. Re: UI Issue
                I don't think so.
                Yes. Place in the Startup Scripts folder, which is a subfolder of the Scripts folder.
                Peter
