This content has been marked as final.
Show 1 reply
1. Re: Overlaying Two PDF's...
Steve Werner Jul 13, 2011 8:51 PM (in response to 1957GoldTop)I can help you with the first part of the request:
1. Open the PDF that will be the base layer.
2. Show the Layers panel: View > Show/Hide > Navigation Panes > Layers. You'll see it in the Navigation pane to the left.
3. From the Layers panel menu choose Import as Layer.
4. In the Import as Layer dialog, in the Source section, browse to select the second PDF file. Give the layer a name.
5. In the Position section scale the PDF on top and change its positioning. You can also change the opacity. Then click OK.
I don't know of a way of inversing the PDF. It should be changed in the original artwork before making it into a PDF file.
