1. Re: for enquiry
Bill Gehrke Jul 14, 2011 5:49 AM (in response to Phoenicianvideo)Actually you are in the Hardware forum. You probably would get a more helpful answer in the Encore forum.
2. Re: for enquiry
Jerry.K Jul 14, 2011 5:53 AM (in response to Phoenicianvideo)Moved to the Encore forum
3. Re: for enquiry
Stan Jones Jul 14, 2011 6:04 AM (in response to Phoenicianvideo)Why don't you reinstall the CS5?
4. Re: for enquiry
ram8kumar Jul 14, 2011 6:36 AM (in response to Stan Jones)Stan is right.
Also you can point to the CS3 library content if you have it on your system.
5. Re: for enquiry
ram8kumar Jul 14, 2011 6:38 AM (in response to ram8kumar)I forgot to tell you how you can point to the Library :
Go to the Preferences
Go to Media tab
in Library Content, browse to the location of your CS3 library folder.
Ramesh.
6. Re: for enquiry
shuchi shrivastava Jul 14, 2011 6:47 AM (in response to Phoenicianvideo)Hi,
Did you install CS5 from the media or downloaded the ESD from Adobe's site? If you installed through the media, you can uninstall CS5 and reinstall and you will have the library also reinstalled.
If you downloaded the ESD,you will have to check if you can re- download the functional content installer from the site.
Also, if you have the CS3 library installed, you can use it in CS5. To do this launch En CS5,goto Edit->Preferences->Media.You can set Library Content location to the path where CS3 library is installed in your system
Shuchi
7. Re: for enquiry
Phoenicianvideo Jul 18, 2011 10:27 PM (in response to shuchi shrivastava)Hi,Thanks for your Help, but i dont have the plugin Library encore cs3 in the same computer i have cs5, actually i have the cs3 at external Hard drive, so how can install it to other computer i have the encore cs5, and by the way i dont have a library icon in the encore cs5 so what should do with that solution.
Thank you so much again.
john
8. Re: for enquiry
ram8kumar Jul 19, 2011 3:01 AM (in response to Phoenicianvideo)No problem.
just copy the library folder from the location Encore is installed from the CS3 system to the system where CS5 is present.
And then locate the library in CS5 as I mentioned in my previous post.
Ramesh.
