5 Replies Latest reply on Jul 14, 2011 6:46 AM by Venkatesan Balasubramanian
    how to initialize checkbox in flex4
      hi friends,
                   if checkbox selected false means one function will run and checkbox selected true means another function will run, i want to use if and else condition for this.when i try this i am facting error like this how i will rectify,please help
      var chkIncrSlab:Boolean;
      if(chkIncrSlab.selected = false)----> error- Access of possibly undefined property selected through a reference with static type Boolean.
        • 1. Re: how to initialize checkbox in flex4
          _spoboyle Level 4
          Firstly, '=' is an assignment operator, use '==' for comparisons.
          Secondly, chkIncrSlab is a Boolean and so does not have a property called selected
          so chkIncrSlab.selected will fail
          I am not 100% sure but, I think you are after something like this?
          <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                      xmlns:mx="library://ns.adobe.com/flex/mx"
                                      minWidth="955" minHeight="600">
               <fx:Script>
                    <![CDATA[
                         protected function checkBox_changeHandler(event:Event):void
                              if (checkBox.selected)
                                   sayHello();
                              else
                                   sayGoodbye();
                         private function sayHello():void
                              label.text = "hello";
                         private function sayGoodbye():void
                              label.text = "good bye";
               </fx:Script>
               <s:VGroup horizontalCenter="0" verticalCenter="0">
                    <s:CheckBox id="checkBox"
                                   label="test"
                                   change="checkBox_changeHandler(event)"/>
                    <s:Label id="label"/>
               </s:VGroup>
          </s:WindowedApplication>
          • 2. Re: how to initialize checkbox in flex4
            Venkatesan Balasubramanian Level 1
            first of all thanks for the quick replay.
            i am using 2windows.i am using check box in first form.in that form i am using textinput for userid and 2 more textinput used for some value and one save button. 2nd window i am using textinput  for userid and one data grid,navigation button
            while i am clicking save button that data will be store in db, In second window using plan id i need to retrive the values which i given in the text in put fields in the first window when i am clicking navigation buttion.that values wil display in datagrids first line then how i will edit second line,3rdline.4thline etc...
            thanks in advance,
            B.venkatesan
            • 3. Re: how to initialize checkbox in flex4
              _spoboyle Level 4
              did my first post solve your orginal problem?
              the description isn't very clear, best thing to do is post some code that illustrates your issue.
              unforunately I have never worked with datagrids so am unlikely to be able to help
              • 5. Re: how to initialize checkbox in flex4
                i got some ideas form ur first post,bt what i told in my second post thats my recuirement.can u help me to get that?
                B.venkatesan
