3 Replies Latest reply on Jun 5, 2007 7:01 PM by Newsgroup_User
    Xtras size
    newmfa
      "Xtras size" this is my problem..!
      i made project with dirMX04, i used stub project to publish it, all used xtras in
      external folder, the project working well, but how reduce xtras size..?
      i found in "add xtras" menu "zipXtra.x32" is this a solve..?
      is there a link learn me how use zip Xtra..?
      regards
      newmfa
        • 1. Re: Xtras size
          Level 7
          No, that won't help.
          There used to be an option for creating a compressed player in previous
          versions, but for some reason it was removed from MX2004. I guess it had to
          do with cross platform publishing. No matter what the reason, I couldn't
          disagree more with the removal of the option - could have at least been
          supported only for the host OS, as it used to be.
          If you own director 8.5 or MX and your scripts are compatible with them, you
          can select to include all Xtras in the projector, and create a single
          compressed file. You can still include the Xtras in mx2004, but the file
          won't be compressed.
          "newmfa" <webforumsuser@macromedia.com> wrote in message
          news:f41oid$4pv$1@forums.macromedia.com...
          > Hi,
          > xtras
          > in
          > regards
          > newmfa
          • 2. Re: Xtras size
            Level 7
            In the Files tab of publish, you can still choose to use Shockwave
            compression. In the Shockwave tab you can compress both images and audio.
            You can also make a Shockwave player if you want. Including all Xtras won't
            make the file smaller either, but it will slow down the launch time.
            Dave -
            Head Developer
            http://www.blurredistinction.com
            Adobe Community Expert
            http://www.adobe.com/communities/experts/
            • 3. Re: Xtras size
              Level 7
              Yes, media can still be compressed. But you can't create a compressed player
              anymore. So, you start by aprox +1.5 MB (~2.5 from ~1.1).
              As for the shockwave player, do you remember what happened with 8.5 sw
              projectors when sw player 10 was released? The movie informed it needed to
              install sw 8.5, launched a browser, installed sw10 and then refused to run.
              Wouldn't risk going through that again.
              "DMennenoh **AdobeCommunityExpert**" <dave@blurredistinction.com> wrote in
              message news:f43h5r$agj$1@forums.macromedia.com...
              > won't make the file smaller either, but it will slow down the launch time.
              > Dave -
              > Head Developer
