5 Replies Latest reply on Jul 21, 2011 9:48 AM by k3dj
    Flash Catalyst CS5.5 Scale to fit the Browser size.
    aniseplanet
      Hello,
      I've create a website and when i preview on my browser ( 1280x664 website size) it look very good ,but when i try to see it from a different desktop will smaller or bigger size my website is croped ,some important functions are croped.
      I've been all the day looking in internet trying to fund a solution how to fix this but nothing.
      I saw an article that explaind how to fix that in flash catalyst cs5 and i tried to but didnt work
      so please help me to tell me how to make this work, i want just my website to get scaled
      ''to work in any monitor size''
      Thank you
        • 1. Re: Flash Catalyst CS5.5 Scale to fit the Browser size.
          k3dj Level 1
          Could you add a link to your site here at all ? That would help with some workarounds maybe.
          I have noticed that many of the professional websites designed by web-agencies use a common design. They design the content to fit the majority of users who can view and do seem to view at around 800 x 450 - take a look at this as a good reference point.
          They then place the main content in a container - and centre it - so that it moves with fluidity - as the users resize the browser window, the content stays central on the page. Often a background image is used behind the main content - and the background image can be scaled to fit the window.
          There are some good examples like Carl Cox's Intec Label Website and some more at a great London Design Agency called bobbentleydesign.com
          You will note that many of these sites use the same method. Since such reputable designers use the same methods I would assume there's a damn good reason to do it that way, it must be the best way available . . . if there was a reliable way to scale everything then I would bet these pro's would be doing so - but they dont.
          Sorry I do not have the kind of solution that you are looking for. I am not a pro and very new to CS5 myself but I hope it may help you out. I think you are looking for something that can not be done effectively or consistently but I may be wrong. Perhaps someone knows but in the meantime . . . work around it.
          • 2. Re: Flash Catalyst CS5.5 Scale to fit the Browser size.
            aniseplanet Level 1
            Thank you for yor Reply and your Advice. I know that the designer must see the moniotors references and from wich customers with be more visited ,
            but i thought that with flash catalyst it will be easy done,
            but at least how can i activate the scrollbars in order even the small monitors can see?
            my website
            • 3. Re: Flash Catalyst CS5.5 Scale to fit the Browser size.
              k3dj Level 1
              I took a look through the code and I noticed the css style has 'overflow' set to 'auto'
              Remember I am a newbie and not a pro but I think that if you want the scroll bars to show - then you should change that styling and set it to 'scroll'
              For more information on this take a look at this . . .
              http://www.w3schools.com/cssref/pr_pos_overflow.asp
              It's a good resource site for reference and there are great examples which help all us newbies understand these things a little better.
              I do however reserve the right to be over ruled by the pros that post here ; ) If I am wrong then hopefully one of them will help you out.
              • 4. Re: Flash Catalyst CS5.5 Scale to fit the Browser size.
                aniseplanet Level 1
                That doesn't seem to work , it shows the scroll panel but they are inactive,
                do you know maybe how to activate the scroll through flash builder?
                thank you!
                • 5. Re: Flash Catalyst CS5.5 Scale to fit the Browser size.
                  k3dj Level 1
                  That's a massive NO - sorry aniseplanet - I use CS5 Web Premium and I am a newbie to all intensive purporses. I have been finding my way around Flash Pro and Flash Catalyst to date. My background was Print Media originally, more Magazine and Ad Design so I am much more familair with Photoshop and Illustrator and some previous knowledge of Dreamweaver helped but I have no idea about Flash Builder at all. That's a massive step up for most people.
                  I think you need to get some advice from those with more knowledge and as far as Flash Builder goes, they are quite rare. I am sure someone will show up if you give it time, maybe make a new post in the Flash Builder Forum. Sorry I could not be of more help and I hope you get some guidance soon.
                  Best Wishes and Good Luck.
