5 Replies Latest reply on Jul 15, 2011 8:43 AM by jfb00
    Extended texInput issue
    jfb00 Level 3
      Hi, Yesterday I created an extended component for textInput.
      http://forums.adobe.com/thread/876786?tstart=30
      Now, when I try to pass my realValue to my method argument:
      <mx:method name="addNew" result="addNew_RO_Handler(event)">
                  <mx:arguments>
                      <number_id>myField.realValue</number_id>
      I am getting this alert:
      Data binding will not be able to detect assignments to "realValue".
      I am setting to get the value with:
      public function get realValue():String
           //Return component text real value
           return _realValue;
      What is missing?
      JFB
        • 1. Re: Extended texInput issue
          UbuntuPenguin Level 4
          You didn't make "realValue" bindable.  To be honest, since you are using it in a service call, I don't think you have too much to worry about.  But if you want to make the warning go away and for future reference try this.
          public function set realValue(value:String):void
               //Set real value
               _realValue =
               value;
               // format the number here
               super.text = formatDecimal(Number(_realValue));
               dispatchEvent( new Event(
          "realValueChange") );
          [Bindable(Event="
          realValueChange")]
               return _realValue;
          • 2. Re: Extended texInput issue
            jfb00 Level 3
            The message is gone but the value come as zero. When I debug and point to realValue i can see the number.
            Any ideas?
            JFB
            • 3. Re: Extended texInput issue
              Wait a minute ?  Do you have
              _realValue = value; or
              reaValue = value ?
              • 4. Re: Extended texInput issue
                jfb00 Level 3
                _realValue = value;
                JFB
                • 5. Re: Extended texInput issue
                  jfb00 Level 3
                  The weird thing is, when i debug i can see the value as:  realValue = 6565 [0x19a5]
                  But in my method arguments shows as NaN.
                  I convert realValue to handle number instead of string but the same issue.
                  Is this a posible bug?
                  JFB
