When publishing to .epub, RH9 is generating the folders shown below but not a single .epub file. Has anyone encountered this before and/or found a solution?
Thank you!
Take a look at the sample projects. They contain examples and instructions on how they were created. Maybe something there will help.
Click Open on the RoboHelp Starter page and then click Samples in the ribbon on the left.
The ePub scripts uses 7za.exe to create .epub file and it clearly shows that you have not given the path to the this exe in you epub generater dialog (see attached snapshot), for your aid I am shraing it over acrobat.com @ https://acrobat.com/#d=0VTCusXxBcHljpbmnXKKnQ, If you did not find it over web, Please remove the ".zzz" from it and save it on your local machine and give the path once in RH 9
Hope this wil help
Ashish
