0 Replies Latest reply on Jul 15, 2011 1:58 PM by flashharry!
    sortable URLVariables to emulate Arrays in HTML Form Variables
    flashharry! Level 1
      HI,
      I need to create a flex form that post arrays back to a php server side script, I do not have access to the source of the php and its encoded
      When my data is sent its sent in random order
      Array
          [SEARCHFIELD] => Array
                  [0] => Array
                          [SELECTEDVOL] => 1
                          [LOGIC] => 0
                          [FIELDNAME] => SELECTEDVOL
                  [3] => Array
                          [dbsearchkeyword149] => photo
                          [dbsearchflag149] => -1
                          [logic] => 1
                          [dbsearchtype149] => 253
                  [1] => Array
                          [PATHTYPE] => 1
                          [LOGIC] => 0
                          [FIELDNAME] => PATHTYPE
                  [2] => Array
                          [LOGIC] => 1
                          [FILENAME] => photo
                          [PATHSEARCHTYPE] => -1
                          [FIELDNAME] => FILENAME
      I need the SEARCHFIELD to be sent in order, it must be sent in order.
      There created in order via a loop
      var params = new URLVariables();
      params["SEARCHFIELD[" + i + "][FIELDNAME]"] = "FILENAME";
      params["SEARCHFIELD[" + i + "][PATHSEARCHTYPE]"] = tempLogic;
      params["SEARCHFIELD[" + i + "][FILENAME]"] = tempValue;
      etc.
      I need to sort params.SEARCHFIELD
      If I create the same data in html inputs it works, its received in the order its created.
      <input type="text" name="SEARCHFIELD[0][FIELDNAME]" value="" />
      <input type="text" name="SEARCHFIELD[0][PATHSEARCHTYPE]" value="" />
      <input type="text" name="SEARCHFIELD[0][FILENAME]" value="" />
      How can I post data as an array so its received in oder its created.
      I have tried an array but it comes over as object object
      tia
      harry
