Hi, the content assist order of suggestions should first show the templates. As it is, they're last on the list. This is very counter-intuitive.
Does anyone know away to hack this configuration?
Hi, The order in which 'content assist' is listed, can be found at 'Windows > Preferences > FlashBuilder > Editors>ActionScript Code > Content Assist Cycling
But by default its the 'Templates' first. You can but change the order as per your convinience
Sorry for the late answer, thanks for the reply. However that didn`t work. It only affects the 2nd cycling, not the first. So I still need TWO Ctrl + Space to get to the templates. I would like to get to them with one.
Not only that but when you don`t find a matching template it's even worse, because then I have to get back to the first cycle if I want to settle for a Class/Component instead.
Thanks anyway
First Cycle will always show 'All' proposals. The order of rest of the Cycles that follow can be customized in FlashBuilder->Editors->ActionScript Code->Cycling
First cycle will also have templates in it. If you type in full word of template and if auto-insert is true in preferences, the template will be inserted automatically when cntr+space is pressed.
