2 Replies Latest reply on Jul 18, 2011 7:16 AM by roestigraben
    What is the better solution?
    roestigraben
      Hello,
      I am pretty new to Flex / Flash Builder and am getting stuck with the following
      I have a database with say 2 tables: One with the list of items available and one table with the list chosen for specific projects
      The design view I intend to use are 2 datagrids side by side and a couple of buttons to add/delete an item from the projects.
      I also have a combobox to select the project for which I want to add/delete items. This combo box will filter all records with the chosen project name.
      The code I did based on local data (not server connection) is attached below.
      So far so good.
      Now, I want to replace the local data hold in ArrayCollections with data from a MySQL database.
      There my problem starts. In all tutorials about Flashbuilder, the databases are shwoing data directly in datagrids while I want to do this detour going thru local arraycollections (for instances to filetr data for the selected project or to render data differently)
      I am stuck.
      Can somebody give me the precious hint to progress further
      BR
      Peter Hirt
         xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
      <fx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      import mx.events.FlexEvent;
      import spark.events.IndexChangeEvent;
      [Bindable]
      public var projects:ArrayCollection = new ArrayCollection([
      {label:"Spear2340", data:1},
      {label:"Lille", data:2},
      {label:"AP9600", data:3},
      {label:"Arnie", data:4},
      {label:"Neuron", data:5},
      {label:"Cannes", data:6} ]);
      [Bindable]
      private var usedIP:ArrayCollection = new ArrayCollection([
      {project:"Spear2340", IP:"USB2 PHY", cost:"180000"},
      {project:"Lille", IP:"DDR PHY", cost:"180000"},
      {project:"AP9600", IP:"DDR PHY", cost:"180000"},
      {project:"Arnie", IP:"Ethernet Controller", cost:"180000"},
      {project:"Arnie", IP: "USB2 Host Controller", cost:"180000"},
      {project:"Neuron", IP:"USB2 PHY", cost:"180000"},
      {project:"Neuron", IP:"USB2 Host Controller", cost:"180000"},
      {project:"Cannes", IP:"USB3 PHY", cost:"180000"} ]);
      [Bindable]
      private var selectedName:String = "Arnie";
      [Bindable]
      private var ipCatalog:ArrayCollection = new ArrayCollection([
      {IP:"USB2 PHY", technology:"40lp", cost:"180000"},
      {IP:"USB2 Host Controller", technology:"na", cost:"64000"},
      {IP:"USB3 PHY", technology:"40lp", cost:"270000"},
      {IP:"Ethernet Controller", technology:"na", cost:"38000"},
      {IP:"SATA Host Controller", technology:"40lp", cost:"60000"},
      public function handleProjectSelected(event:IndexChangeEvent):void
      selectedName = DropDownListProjects.selectedItem.label;
      // filter against the project name
      usedIP.filterFunction = filterProject;
      usedIP.refresh();
      sumUpColumn();
      totalProjectPrice.visible = true;
      private function filterProject(item:Object):Boolean
      return item["project"].match(new RegExp(selectedName, 'i'))
      protected function addBtn_clickHandler(event:MouseEvent):void
      usedIP.addItem(ipCatalogDG.selectedItem);
      var currentlySelectedItem : Object = ipCatalogDG.selectedItem;
      currentlySelectedItem.project =  DropDownListProjects.selectedItem.label;
      usedIP.itemUpdated(currentlySelectedItem);
      usedIP.refresh();
      sumUpColumn();
      protected function deleteBtn_clickHandler(event:MouseEvent):void
      usedIP.removeItemAt(usedIPDG.selectedIndex);
      sumUpColumn();
      protected function usedIPDG_clickHandler(event:MouseEvent):void
      if (usedIPDG.selectedIndex !=-1) {
      deleteBtn.enabled = true;
      addBtn.enabled = false;
      protected function ipCatalogDG_clickHandler(event:MouseEvent):void
      if (ipCatalogDG.selectedIndex !=-1) {
      addBtn.enabled = true;
      deleteBtn.enabled = false;
      // determine the price per project
      [Bindable]
      private var totalPrice:Number = 0.0;
      private function sumUpColumn():void
      var i:uint
      totalPrice = 0.0;
      for(i=0; i<usedIP.length; i++) {
      totalPrice += (usedIP.getItemAt(i).cost);
      </fx:Script>
      <fx:Declarations>
      <mx:CurrencyFormatter id="usdFormatter" precision="0" currencySymbol="$"
        decimalSeparatorFrom="." decimalSeparatorTo="." useNegativeSign="true"
        useThousandsSeparator="true" alignSymbol="left"/>
      </fx:Declarations>
      <s:Panel title="Project dropdownlist checking for filtering"
      width="100%" height="100%">
      <s:VGroup width="100%" height="100%" left="120" top="5">
      <mx:HBox>
      <s:DropDownList id="DropDownListProjects"
      width="200"
      dataProvider="{projects}"
      labelField="label"
      prompt="Select Project"
      change="handleProjectSelected(event)" textAlign="left"/>
      </mx:HBox>
      <mx:HBox verticalAlign="middle">
      <mx:DataGrid id="ipCatalogDG" dataProvider="{ipCatalog}" width="400" click="ipCatalogDG_clickHandler(event)"/>
      <mx:VBox horizontalAlign="center">
      <s:Button id="addBtn"
        label="Add to Project"
        click="addBtn_clickHandler(event)"
         width="130"
         enabled="false"/>
      <s:Button id="deleteBtn"
        label="Delete from Project"
        click="deleteBtn_clickHandler(event)"
         width="130"
         enabled="false"/>
      </mx:VBox>
      <mx:DataGrid id="usedIPDG" dataProvider="{usedIP}" width="400" click="usedIPDG_clickHandler(event)"/>
      </mx:HBox>
      <s:Label id="totalProjectPrice"
      text="The total price for this Project is : {usdFormatter.format(totalPrice)}"
      visible="false"/>
      </s:VGroup>
      </s:Panel>
      </s:Application>
        • 1. Re: What is the better solution?
          kokorito Level 4
          you need to set up a server side script to send the data to flex
          try these tutorials, day 2 shows how to retrieve data, day 3 shows how to send
          http://www.adobe.com/devnet/flex/videotraining.html
          hope it helps
          • 2. Re: What is the better solution?
            roestigraben Level 1
            Many thanks for this hint
            Actually I went thru this video series already but probably forgot about it.
            Now the training shows the methods for
            HTTPService
            RemoteObject
            WebService
            they have a slightly different result handler compared to the PHP method
            I think, as I am using PHP, I am getting back generic objects (tried out on the "test server data"), so I would conclude I have to write something to the direction of
            protected function xyze_resultHandler(event:ResultEvent):void
            employees = event.result as ArrayCollection;
            with employees being the arrayCollection that I will use then for filtering and interfacing with the datagrid thru binding
            Is this correct?
            sorry to bother you with my little knowledge level so far on flex
            Peter
