1 Reply Latest reply on Jul 17, 2011 1:27 PM by Ned Murphy
    stop motion with flash
    graphicaname Level 1
      Hi everyone.
      i want to create an animation with stop motion. Create a sequence with 160 photos  numbered continuous.
      It's with flash cs3.
      thanks a lot!
        • 1. Re: stop motion with flash
          It will be easy if you have your photos all named in a similar and sequential manner (ex: img1, img2, img3, etc) located in the same folder.  All you need to do is start the process of importing the first image to the stage, and midway thru that the program should recognize it is part of a series of images and will ask if you want to import the whole series, which you will say yes to.  I think it also asks if you want them arranged frame after frame (or assumes it), so you should end up with all of the images planted in the timeline for you in sequence.
