1 Reply Latest reply on Jul 19, 2011 5:18 AM by Rob_2006
    audio editing in air
    Rob_2006
      Hi there,
      I would like to create an audio recorder app that allows the user to edit a recorded sound. I managed to record and playback audio. The thing that is missing is the functionality to playback the sound from a certain position.
      mySound.play(myPosition) does not work since I'm playing back the sound from a byte Array as shown below:
      soundOutput = new Sound();
      soundOutput.addEventListener(SampleDataEvent.SAMPLE_DATA, playSound);
      _soundChannel = soundOutput.play(0);
      private function playSound(sampleEvent:SampleDataEvent):void
      if (!soundRecording.bytesAvailable > 0)
      return;
      for (var i:int = 0; i < 8192; i++)
      var sample:Number = 0;
      if (soundRecording.bytesAvailable > 0)
      sample = soundRecording.readFloat();
      sampleEvent.data.writeFloat(sample);
      Any ides how I can playback the audio from a specific position?
      My knowledge of audio is rather limited so all help is greatly appreciated.
      Cheers
      Robin
        • 1. Re: audio editing in air
          Rob_2006 Level 1
          I figured it out myself. The trick is to set the position in the recorded byte array correctly:
          var _phase= (startTime*44100/2)/1000;
          _soundChannel = soundOutput.play(startTime);
          // and then in sample data event handler:
          soundRecording.position = int(_phase) * 8
