1. Re: - error occurred - An FTP error occurred - cannot put template.css. Access denied
SnakEyez02 Jul 18, 2011 6:38 AM (in response to glacier434)Since you have stated this is a dedicated server that you are the owner of we can troubleshoot this a little further. Click on Site->Advanced->FTP Log. What error are you getting in the transfer? That will state a lot. Then make sure the permissions and ownership match the user account that you are logging in with. If this turns out to be an ownership issue I would recommend setting recursive permissions on the account to encompass all files and folders since the login being used should assign correct ownership permissions and if it is not then that is another issue to look into.
2. Re: - error occurred - An FTP error occurred - cannot put template.css. Access denied
glacier434 Jul 18, 2011 6:45 AM (in response to glacier434)I just answered my own question. If I am putting to a system that also has a web interface for editing files, like Joomla, which is what I'm doing, then once I try to edit the file on the Web UI it marks the file as Read only. I have to go in via ftp and change the properties of those specific files back to writeable.
I searched and searched for this answer before posting the question on this forum, which is why I decided to keep the question here. Just as an alternative solution for someone else with the same circumstances (web interface available) as myself.
Ciao.
