6 Replies Latest reply on Jul 18, 2011 1:55 PM by s_davies
    Placing graphics within a scroller area
    s_davies Level 1
      I have on one of my view a lot of text so I have created it so to scroll see below, (if wrong plese let me know):
      <s:Scroller left="20" right="20" top="20" bottom="0">
           <s:RichEditableText percentWidth="100" percentHeight="100" editable="false" selectable="false">
                <s:p>My text goes here</s:p>
           </s:RichEditableText>
      </s:Scroller>
      Now with in this text would live to place some graphics like boxes with text inside as I want to create a diagram etc, but if i place my rectangle code (see below) with in the 'RichEditableText' section all goes well until till I click on a link to goto this view and nothing happens and it freezes up
      <s:Rect width="135" height="71" radiusX="10">
           <s:fill>
      <s:SolidColor color="#ff990" />
           </s:fill>
      </s:Rect>
      Does any one know how I can add the graphics etc with in there to work an scroll with the text, or am i using the wrong scroll method etc.
      Many Thanks
      Si
        • 1. Re: Placing graphics within a scroller area
          Rangora Level 3
          Does it work when you have just text in the RichEditableText?
          • 2. Re: Placing graphics within a scroller area
            s_davies Level 1
            Yes, I did it with just text  first to test then it was ok
            • 3. Re: Placing graphics within a scroller area
              Rangora Level 3
              Ok I read the doc and searched the web and I found the problem.
              RichEditableText can only accept text or InlineGraphicsElement. If you want to add graphics in the text, you will have to create an InlineGraphicsElement and add it to a paragraph.
              My first suggestion would be to change your declaration for this :
                      <s:textFlow>
                         <s:TextFlow>
                             <s:p id="firstPar">
                                   My text goes here
                             </s:p>
                         </s:TextFlow>
                     </s:textFlow>
              </s:Scroller>
              This will allow you to have more than 1 paragraph. It's how Adobe implement a RichEditableText in the doc.
              To add a graphic to this paragraph, you will add this code in the fx:Script tag.
              import flashx.textLayout.elements.InlineGraphicElement;
              private var rec:InlineGraphicElement;
              protected function view1_viewActivateHandler(event:ViewNavigatorEvent):void
                   rec = new InlineGraphicElement();
                   rec.source = drawRect();
                   firstPar.addChild(rec);
              private function drawRect():Sprite
                   var spt:Sprite = new Sprite();
                   spt.graphics.beginFill(0xff9900);
                   spt.graphics.drawRect(0,0,135,71);
                   spt.graphics.endFill();
                   return spt;
              The InlineGraphicElement can load an external file (an image for example). You can also create a sprite and set it as the source as I do here.
              I hope this will help you to understand how you could do what you want to do
              EDIT : here are my sources :
              http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/flashx/textLayout/elem ents/InlineGraphicElement.html
              http://docs.huihoo.com/flex/4/spark/components/RichEditableText.html
              • 4. Re: Placing graphics within a scroller area
                Rangora Level 3
                I did a little mistake. Instead of viewActivateHandler, you should use creationComplete. If you add this code in the viewActivate and you deactivate the view and come back, it will add a second graphic.
                Also, I didnt tell you to add the eventHandler in the <s:view> tag. In this case, it would be
                <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
                        xmlns:s="library://ns.adobe.com/flex/spark" title="testingview" creationComplete="view1_creationCompleteHandler(event)">
                and the method would be
                protected function view1_creationCompleteHandler(event:FlexEvent):void
                • 5. Re: Placing graphics within a scroller area
                  s_davies Level 1
                  Hey!, thanks for the response, I will give this a try and let you know the out come, once again many thanks.
                  Si
                  • 6. Re: Placing graphics within a scroller area
                    s_davies Level 1
                    That seemed to work a treat now to get text on top of those rectangles etc and I'm done, well I said i'm done !! :-)
                    Many Thanks for this.
                    Si
