2 Replies Latest reply on Jul 18, 2011 4:16 PM by k-yo!
    CS5.5 file crashes Flash on opening
    k-yo!
      I've got an iMac and a MacBook Pro both running 10.6.8 and Flash CS5.5.
      I've built some files on the iMac using Flash CS5.5, but when I try and open them on the MB Pro the file crashes Flash on opening. The problem for me right now is the iMac is at my office and I'm offsite using the MB Pro. I tried re-installing Flash CS5.5 but that didn't fix the problem. Is there anything I can do to try and debug or figure out why this is happening. Other files and new files are fine in CS5.5 on the MB Pro, just this specific file that I need to work on :-) is crashing.
      I'm pasting the Crash Report in here with the hope that someone from Adobe can understand what's going on and tell me the problem / fix for it. It's looking like I'm going to have to leave the site and go back to my office, which is a pain and looks kind of un-professional in my opinion.
      Process:         Adobe Flash CS5.5 [725]
      Path:            /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/MacOS/Adobe Flash CS5.5
      Identifier:      com.adobe.flash
      Version:         11.5.0.325 (11.5.0)
      Code Type:       X86 (Native)
      Parent Process:  launchd [172]
      Date/Time:       2011-07-18 12:48:42.186 -0500
      OS Version:      Mac OS X 10.6.8 (10K540)
      Report Version:  6
      Interval Since Last Report:          220442 sec
      Crashes Since Last Report:           20
      Per-App Interval Since Last Report:  3209 sec
      Per-App Crashes Since Last Report:   15
      Anonymous UUID:                      2DEB8EB2-4DFD-4FD1-83B3-85736FAE2059
      Exception Type:  EXC_BAD_ACCESS (SIGBUS)
      Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000001
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Application Specific Information:
      Java information:
      Exception type: Bus Error (0xa) at pc=0000000023340ac8
      Java VM: Java HotSpot(TM) Client VM (20.1-b02-384 mixed mode macosx-x86)
      Current thread (0000000033002000):  JavaThread "main" [_thread_in_native, id=-1608428224, stack(00000000bf800000,00000000c0000000)]
      Stack: [00000000bf800000,00000000c0000000]
      Java Threads: ( => current thread )
        0000000033244400 JavaThread "Thread-3" [_thread_blocked, id=-1338343424, stack(00000000b02a8000,00000000b03a8000)]
        0000000036081800 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1304035328, stack(00000000b2360000,00000000b2460000)]
        0000000036081000 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1305092096, stack(00000000b225e000,00000000b235e000)]
        0000000036075000 JavaThread "FelixPackageAdmin" daemon [_thread_blocked, id=-1306148864, stack(00000000b215c000,00000000b225c000)]
        0000000036073800 JavaThread "FelixStartLevel" daemon [_thread_blocked, id=-1307205632, stack(00000000b205a000,00000000b215a000)]
        000000003680a400 JavaThread "FelixDispatchQueue" [_thread_blocked, id=-1308262400, stack(00000000b1f58000,00000000b2058000)]
        00000000331d6000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1310375936, stack(00000000b1d54000,00000000b1e54000)]
        0000000036801000 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=-1311432704, stack(00000000b1c52000,00000000b1d52000)]
        0000000036800000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1312489472, stack(00000000b1b50000,00000000b1c50000)]
        0000000036004400 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=-1313546240, stack(00000000b1a4e000,00000000b1b4e000)]
        00000000331ce000 JavaThread "Finalizer" daemon [_thread_blocked, id=-1314603008, stack(00000000b194c000,00000000b1a4c000)]
        00000000331cd000 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1315659776, stack(00000000b184a000,00000000b194a000)]
      =>0000000033002000 JavaThread "main" [_thread_in_native, id=-1608428224, stack(00000000bf800000,00000000c0000000)]
      Other Threads:
        00000000331ca400 VMThread [stack: 00000000b1748000,00000000b1848000] [id=-1316716544]
        00000000331df800 WatcherThread [stack: 00000000b1e56000,00000000b1f56000] [id=-1309319168]
      VM state:not at safepoint (normal execution)
      VM Mutex/Monitor currently owned by a thread: None
      Heap
      par new generation   total 14784K, used 0K [0000000040100000, 0000000041100000, 0000000041100000)
        eden space 13184K,   0% used [0000000040100000, 0000000040100000, 0000000040de0000)
        from space 1600K,   0% used [0000000040f70000, 0000000040f70000, 0000000041100000)
        to   space 1600K,   0% used [0000000040de0000, 0000000040de0000, 0000000040f70000)
      concurrent mark-sweep generation total 49152K, used 9268K [0000000041100000, 0000000044100000, 0000000048100000)
      concurrent-mark-sweep perm gen total 22104K, used 13261K [0000000048100000, 0000000049696000, 000000004c100000)
      Code Cache  [0000000033801000, 00000000339da000, 0000000035801000)
      total_blobs=980 nmethods=832 adapters=90 free_code_cache=31644864 largest_free_block=192
      Virtual Machine Arguments:
      JVM Args: -Djava.awt.headless=true -Xmx128m
      Java Command: <unknown>
      Launcher Type: generic
      Physical Memory: Page Size = 4k, Total = 8192M, Free = 17592186043592M
      Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
      0   ...ia.Flash Player.authplaylib 0x23340ac8 ExternalPlayer_Initialize + 1898520
      1   ...ia.Flash Player.authplaylib 0x232a0274 ExternalPlayer_Initialize + 1241028
      2   ...ia.Flash Player.authplaylib 0x232a0e72 ExternalPlayer_Initialize + 1244098
      3   ...ia.Flash Player.authplaylib 0x23320b01 ExternalPlayer_Initialize + 1767505
      4   ...ia.Flash Player.authplaylib 0x23297611 ExternalPlayer_Initialize + 1205089
      5   ...ia.Flash Player.authplaylib 0x23297b19 ExternalPlayer_Initialize + 1206377
      6   ...ia.Flash Player.authplaylib 0x2329b8c9 ExternalPlayer_Initialize + 1222169
      7   ...ia.Flash Player.authplaylib 0x232815c3 ExternalPlayer_Initialize + 1114899
      8   ...ia.Flash Player.authplaylib 0x232190a3 ExternalPlayer_Initialize + 687603
      9   ...ia.Flash Player.authplaylib 0x2321a7b3 ExternalPlayer_Initialize + 693507
      10  ...ia.Flash Player.authplaylib 0x2321a929 ExternalPlayer_Initialize + 693881
      11  ...ia.Flash Player.authplaylib 0x23223ace ExternalPlayer_Initialize + 731166
      12  ...ia.Flash Player.authplaylib 0x22edf83f 0x22cfa000 + 1988671
      13  ...ia.Flash Player.authplaylib 0x230002d7 0x22cfa000 + 3171031
      14  ...ia.Flash Player.authplaylib 0x23000757 0x22cfa000 + 3172183
      15  ...ia.Flash Player.authplaylib 0x2302a1f2 0x22cfa000 + 3342834
      16  ...ia.Flash Player.authplaylib 0x2302b9d6 0x22cfa000 + 3348950
      17  ...ia.Flash Player.authplaylib 0x23030a3f 0x22cfa000 + 3369535
      18  ...ia.Flash Player.authplaylib 0x23080bd8 0x22cfa000 + 3697624
      19  ...ia.Flash Player.authplaylib 0x23081279 0x22cfa000 + 3699321
      20  ...ia.Flash Player.authplaylib 0x231a7924 ExternalPlayer_Initialize + 222836
      21  com.apple.CoreFoundation      0x926a5a6b __CFRunLoopRun + 8059
      22  com.apple.CoreFoundation      0x926a33f4 CFRunLoopRunSpecific + 452
      23  com.apple.CoreFoundation      0x926a3221 CFRunLoopRunInMode + 97
      24  com.apple.HIToolbox           0x970cad60 RunCurrentEventLoopInMode + 392
      25  com.apple.HIToolbox           0x970cab17 ReceiveNextEventCommon + 354
      26  com.apple.HIToolbox           0x9725308e _AcquireNextEvent + 54
      27  com.apple.HIToolbox           0x97248d40 RunApplicationEventLoop + 228
      28  com.adobe.flash               0x0102372a non-virtual thunk to CFileDialogImpl::~CFileDialogImpl() + 4302
      29  com.adobe.flash               0x00ffc12d CTimerImpl::~CTimerImpl() + 279
      30  com.adobe.flash               0x00ffc1d9 CTimerImpl::~CTimerImpl() + 451
      31  com.adobe.flash               0x002657c2 devtech_private::Buffer<unsigned short>::Grow(unsigned long) + 1506
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib             0x9174e382 kevent + 10
      1   libSystem.B.dylib             0x9174ea9c _dispatch_mgr_invoke + 215
      2   libSystem.B.dylib             0x9174df59 _dispatch_queue_invoke + 163
      3   libSystem.B.dylib             0x9174dcfe _dispatch_worker_thread2 + 240
      4   libSystem.B.dylib             0x9174d781 _pthread_wqthread + 390
      5   libSystem.B.dylib             0x9174d5c6 start_wqthread + 30
      Thread 2:
      0   libSystem.B.dylib             0x91727b42 semaphore_wait_signal_trap + 10
      1   libSystem.B.dylib             0x917556f8 _pthread_cond_wait + 1089
      2   libSystem.B.dylib             0x9179e05f pthread_cond_wait + 48
      3   com.adobe.amt.services        0x11625274 C_AMTUISwitchSuppressUpdates + 16864
      4   com.adobe.amt.services        0x1161e074 C_EULA_SetState + 2166
      5   com.adobe.amt.services        0x116252da C_AMTUISwitchSuppressUpdates + 16966
      6   libSystem.B.dylib             0x91755259 _pthread_start + 345
      7   libSystem.B.dylib             0x917550de thread_start + 34
      Thread 3:
      0   libSystem.B.dylib             0x91755aa2 __semwait_signal + 10
      1   libSystem.B.dylib             0x9175575e _pthread_cond_wait + 1191
      2   libSystem.B.dylib             0x917573f8 pthread_cond_wait$UNIX2003 + 73
      3   ...ple.CoreServices.CarbonCore 0x99af621e TSWaitOnCondition + 126
      4   ...ple.CoreServices.CarbonCore 0x99ae1b68 TSWaitOnConditionTimedRelative + 202
      5   ...ple.CoreServices.CarbonCore 0x99add533 MPWaitOnQueue + 250
      6   com.adobe.ACE                 0x060c4309 0x6089000 + 242441
      7   com.adobe.ACE                 0x060c3d01 0x6089000 + 240897
      8   ...ple.CoreServices.CarbonCore 0x99ac154a PrivateMPEntryPoint + 68
      9   libSystem.B.dylib             0x91755259 _pthread_start + 345
      10  libSystem.B.dylib             0x917550de thread_start + 34
      Thread 4:
      Thread 5:
      Thread 6:
      Thread 7:
      Thread 8:
      Thread 9:
      Thread 10:
      0   libSystem.B.dylib             0x917650d6 recvfrom$UNIX2003 + 10
      1   libSystem.B.dylib             0x91784eab recv$UNIX2003 + 54
      2   ServiceManager-Launcher.dylib 0x271772d7 Invoke + 54887
      3   ServiceManager-Launcher.dylib 0x27176376 Invoke + 50950
      4   ServiceManager-Launcher.dylib 0x27175227 Invoke + 46519
      5   ServiceManager-Launcher.dylib 0x27175279 Invoke + 46601
      6   ServiceManager-Launcher.dylib 0x27175303 Invoke + 46739
      7   ServiceManager-Launcher.dylib 0x2716f706 Invoke + 23190
      8   ServiceManager-Launcher.dylib 0x2716f8ef Invoke + 23679
      9   ServiceManager-Launcher.dylib 0x271704cf Invoke + 26719
      10  ServiceManager-Launcher.dylib 0x271705cd Invoke + 26973
      11  ServiceManager-Launcher.dylib 0x271739b8 Invoke + 40264
      12  ServiceManager-Launcher.dylib 0x27173c61 Invoke + 40945
      13  ServiceManager-Launcher.dylib 0x2717428f Invoke + 42527
      14  ServiceManager-Launcher.dylib 0x2717448c Invoke + 43036
      15  ServiceManager-Launcher.dylib 0x2716611a Login + 1654
      16  ServiceManager-Launcher.dylib 0x271676f7 Login + 7251
      17  ServiceManager-Launcher.dylib 0x271749fb Invoke + 44427
      18  ServiceManager-Launcher.dylib 0x27176f49 Invoke + 53977
      19  libSystem.B.dylib             0x91755259 _pthread_start + 345
      20  libSystem.B.dylib             0x917550de thread_start + 34
      Thread 11:
      0   libSystem.B.dylib             0x9174d412 __workq_kernreturn + 10
      1   libSystem.B.dylib             0x9174d9a8 _pthread_wqthread + 941
      2   libSystem.B.dylib             0x9174d5c6 start_wqthread + 30
      Thread 12:  Java: Exception Handler Thread
      0   libSystem.B.dylib             0x91727afa mach_msg_trap + 10
      1   libSystem.B.dylib             0x91728267 mach_msg + 68
      2   libSystem.B.dylib             0x91793c78 mach_msg_server + 520
      3   libjvm.dylib                  0x2b9100eb jio_snprintf + 43803
      4   libjvm.dylib                  0x2b90ff80 jio_snprintf + 43440
      5   libjvm.dylib                  0x2b90ed2d jio_snprintf + 38749
      Thread 13:  Java: Gang worker#0 (Parallel GC Threads)
      2   libjvm.dylib                  0x2bb824c9 JVM_RaiseSignal + 365377
      3   libjvm.dylib                  0x2b90f0e6 jio_snprintf + 39702
      4   libjvm.dylib                  0x2bb76681 JVM_RaiseSignal + 316665
      5   libjvm.dylib                  0x2bb76750 JVM_RaiseSignal + 316872
      6   libjvm.dylib                  0x2b90ec5d jio_snprintf + 38541
      7   libjvm.dylib                  0x2b923cbe jio_vsnprintf + 333
      8   libjvm.dylib                  0x2b90ed2d jio_snprintf + 38749
      Thread 14:  Java: Gang worker#1 (Parallel GC Threads)
      Thread 15:  Java: Gang worker#2 (Parallel GC Threads)
      Thread 16:  Java: Gang worker#3 (Parallel GC Threads)
      Thread 17:  Java: Gang worker#4 (Parallel GC Threads)
      Thread 18:  Java: Gang worker#5 (Parallel GC Threads)
      Thread 19:  Java: Gang worker#6 (Parallel GC Threads)
      Thread 20:  Java: Gang worker#7 (Parallel GC Threads)
      Thread 21:  Java: Gang worker#0 (Parallel CMS Threads)
      7   libjvm.dylib                  0x2bbdda92 JVM_RaiseSignal + 739594
      Thread 22:  Java: Gang worker#1 (Parallel CMS Threads)
      Thread 23:  Java: Concurrent Mark-Sweep GC Thread
      2   libjvm.dylib                  0x2bb82599 JVM_RaiseSignal + 365585
      3   libjvm.dylib                  0x2bb8293c JVM_RaiseSignal + 366516
      4   libjvm.dylib                  0x2bb7669b JVM_RaiseSignal + 316691
      7   libjvm.dylib                  0x2b9be0c9 JVM_Close + 13205
      8   libjvm.dylib                  0x2b9be031 JVM_Close + 13053
      9   libjvm.dylib                  0x2b929d73 jio_vsnprintf + 25090
      10  libjvm.dylib                  0x2b90ed2d jio_snprintf + 38749
      11  libSystem.B.dylib             0x91755259 _pthread_start + 345
      12  libSystem.B.dylib             0x917550de thread_start + 34
      Thread 24:  Java: VM Thread
      7   libjvm.dylib                  0x2b990564 JVM_Lseek + 149378
      8   libjvm.dylib                  0x2b990214 JVM_Lseek + 148530
      9   libjvm.dylib                  0x2b90ed2d jio_snprintf + 38749
      10  libSystem.B.dylib             0x91755259 _pthread_start + 345
      11  libSystem.B.dylib             0x917550de thread_start + 34
      Thread 25:  Java: Reference Handler
      4   libjvm.dylib                  0x2bb7e82c JVM_RaiseSignal + 349860
      5   libjvm.dylib                  0x2bbbdb5f JVM_RaiseSignal + 608727
      6   libjvm.dylib                  0x2b99d50a JVM_MonitorWait + 196
      7   libjvmlinkage.dylib           0x26240e75 JVM_MonitorWait + 69
      8   ???                           0x3380b9d9 0 + 864074201
      9   ???                           0x33803e31 0 + 864042545
      10  ???                           0x33803e31 0 + 864042545
      11  ???                           0x33801374 0 + 864031604
      12  libjvm.dylib                  0x2b9917aa JVM_Lseek + 154056
      13  libjvm.dylib                  0x2b991544 JVM_Lseek + 153442
      14  libjvm.dylib                  0x2b99d341 JVM_StartThread + 2726
      15  libjvm.dylib                  0x2b99d246 JVM_StartThread + 2475
      16  libjvm.dylib                  0x2b99d1d4 JVM_StartThread + 2361
      17  libjvm.dylib                  0x2b99d048 JVM_StartThread + 1965
      18  libjvm.dylib                  0x2b99cea7 JVM_StartThread + 1548
      19  libjvm.dylib                  0x2b90ed2d jio_snprintf + 38749
      20  libSystem.B.dylib             0x91755259 _pthread_start + 345
      21  libSystem.B.dylib             0x917550de thread_start + 34
      Thread 26:  Java: Finalizer
      9   ???                           0x33988040 0 + 865632320
      10  ???                           0x33801374 0 + 864031604
      11  libjvm.dylib                  0x2b9917aa JVM_Lseek + 154056
      12  libjvm.dylib                  0x2b991544 JVM_Lseek + 153442
      13  libjvm.dylib                  0x2b99d341 JVM_StartThread + 2726
      14  libjvm.dylib                  0x2b99d246 JVM_StartThread + 2475
      15  libjvm.dylib                  0x2b99d1d4 JVM_StartThread + 2361
      16  libjvm.dylib                  0x2b99d048 JVM_StartThread + 1965
      17  libjvm.dylib                  0x2b99cea7 JVM_StartThread + 1548
      18  libjvm.dylib                  0x2b90ed2d jio_snprintf + 38749
      Thread 27:  Java: Surrogate Locker Thread (Concurrent GC)
      6   libjvm.dylib                  0x2b90eba4 jio_snprintf + 38356
      7   libjvm.dylib                  0x2b9ad9d7 JVM_IsPrimitiveClass + 5991
      8   libjvm.dylib                  0x2b99d048 JVM_StartThread + 1965
      9   libjvm.dylib                  0x2b99cea7 JVM_StartThread + 1548
      Thread 28:  Java: Signal Dispatcher
      0   libSystem.B.dylib             0x91727b36 semaphore_wait_trap + 10
      1   libjvm.dylib                  0x2b9ae209 JVM_IsPrimitiveClass + 8089
      2   libjvm.dylib                  0x2b9adbf4 JVM_IsPrimitiveClass + 6532
      3   libjvm.dylib                  0x2b99d048 JVM_StartThread + 1965
      4   libjvm.dylib                  0x2b99cea7 JVM_StartThread + 1548
      Thread 29:  Java: C1 CompilerThread0
      7   libjvm.dylib                  0x2b9b4d30 JVM_Write + 288
      8   libjvm.dylib                  0x2b9af368 JVM_IsPrimitiveClass + 12536
      9   libjvm.dylib                  0x2b99d048 JVM_StartThread + 1965
      10  libjvm.dylib                  0x2b99cea7 JVM_StartThread + 1548
      11  libjvm.dylib                  0x2b90ed2d jio_snprintf + 38749
      12  libSystem.B.dylib             0x91755259 _pthread_start + 345
      13  libSystem.B.dylib             0x917550de thread_start + 34
      Thread 30:  Java: Low Memory Detector
      7   libjvm.dylib                  0x2b9b0cf6 JVM_IsPrimitiveClass + 19078
      Thread 31:  Java: VM Periodic Task Thread
      4   libjvm.dylib                  0x2b9b2eae JVM_IsPrimitiveClass + 27710
      Thread 32:  Java: FelixDispatchQueue
      11  ???                           0x33803e31 0 + 864042545
      12  ???                           0x33803e31 0 + 864042545
      13  ???                           0x3380430d 0 + 864043789
      14  ???                           0x33801374 0 + 864031604
      15  libjvm.dylib                  0x2b9917aa JVM_Lseek + 154056
      16  libjvm.dylib                  0x2b991544 JVM_Lseek + 153442
      17  libjvm.dylib                  0x2b99d341 JVM_StartThread + 2726
      18  libjvm.dylib                  0x2b99d246 JVM_StartThread + 2475
      19  libjvm.dylib                  0x2b99d1d4 JVM_StartThread + 2361
      20  libjvm.dylib                  0x2b99d048 JVM_StartThread + 1965
      21  libjvm.dylib                  0x2b99cea7 JVM_StartThread + 1548
      22  libjvm.dylib                  0x2b90ed2d jio_snprintf + 38749
      23  libSystem.B.dylib             0x91755259 _pthread_start + 345
      24  libSystem.B.dylib             0x917550de thread_start + 34
      Thread 33:  Java: FelixStartLevel
      11  ???                           0x3380430d 0 + 864043789
      12  ???                           0x33801374 0 + 864031604
      13  libjvm.dylib                  0x2b9917aa JVM_Lseek + 154056
      14  libjvm.dylib                  0x2b991544 JVM_Lseek + 153442
      15  libjvm.dylib                  0x2b99d341 JVM_StartThread + 2726
      16  libjvm.dylib                  0x2b99d246 JVM_StartThread + 2475
      17  libjvm.dylib                  0x2b99d1d4 JVM_StartThread + 2361
      18  libjvm.dylib                  0x2b99d048 JVM_StartThread + 1965
      19  libjvm.dylib                  0x2b99cea7 JVM_StartThread + 1548
      20  libjvm.dylib                  0x2b90ed2d jio_snprintf + 38749
      21  libSystem.B.dylib             0x91755259 _pthread_start + 345
      22  libSystem.B.dylib             0x917550de thread_start + 34
      Thread 34:  Java: FelixPackageAdmin
      Thread 35:  Java: Code Model Worker
      3   libjvm.dylib                  0x2bb8280f JVM_RaiseSignal + 366215
      4   libjvm.dylib                  0x2ba148d0 JVM_SocketAvailable + 246
      5   ???                           0x3380b9d9 0 + 864074201
      6   ???                           0x33803e31 0 + 864042545
      7   ???                           0x33803e31 0 + 864042545
      8   ???                           0x3380430d 0 + 864043789
      9   ???                           0x33804473 0 + 864044147
      10  ???                           0x33803f97 0 + 864042903
      Thread 36:  Java: Code Model Worker
      Thread 37:  Java: Thread-3
      3   libjvm.dylib                  0x2bb82a6b JVM_RaiseSignal + 366819
      4   libjvm.dylib                  0x2b9e8315 JVM_Sleep + 246
      5   libjvmlinkage.dylib           0x26241a68 JVM_Sleep + 72
      6   ???                           0x3380b9d9 0 + 864074201
      9   ???                           0x33801374 0 + 864031604
      10  libjvm.dylib                  0x2b9917aa JVM_Lseek + 154056
      11  libjvm.dylib                  0x2b991544 JVM_Lseek + 153442
      12  libjvm.dylib                  0x2b99d341 JVM_StartThread + 2726
      13  libjvm.dylib                  0x2b99d246 JVM_StartThread + 2475
      14  libjvm.dylib                  0x2b99d1d4 JVM_StartThread + 2361
      15  libjvm.dylib                  0x2b99d048 JVM_StartThread + 1965
      16  libjvm.dylib                  0x2b99cea7 JVM_StartThread + 1548
      17  libjvm.dylib                  0x2b90ed2d jio_snprintf + 38749
      18  libSystem.B.dylib             0x91755259 _pthread_start + 345
      19  libSystem.B.dylib             0x917550de thread_start + 34
      Thread 38:
      Thread 39:
      1   libSystem.B.dylib             0x917819c5 nanosleep$UNIX2003 + 188
      2   com.adobe.flash.flbridge      0x2acb985b ScObjects::Thread::sleep(unsigned int) + 59
      3   com.adobe.flash.flbridge      0x2acb3de3 ScObjects::BridgeTalkThread::run() + 163
      4   com.adobe.flash.flbridge      0x2acb9968 ScObjects::Thread::go(void*) + 168
      5   libSystem.B.dylib             0x91755259 _pthread_start + 345
      6   libSystem.B.dylib             0x917550de thread_start + 34
      Thread 40:
      3   ...ia.Flash Player.authplaylib 0x2314a11f 0x22cfa000 + 4522271
      4   ...ia.Flash Player.authplaylib 0x22d1425f 0x22cfa000 + 107103
      5   ...ia.Flash Player.authplaylib 0x2314a20c 0x22cfa000 + 4522508
      6   ...ia.Flash Player.authplaylib 0x2314a250 0x22cfa000 + 4522576
      7   ...ia.Flash Player.authplaylib 0x2314a376 0x22cfa000 + 4522870
      Thread 41:
      Thread 42:
      Thread 43:
      Thread 44:
      0   libSystem.B.dylib             0x91727b5a semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib             0x917556e1 _pthread_cond_wait + 1066
      2   libSystem.B.dylib             0x917845a8 pthread_cond_timedwait_relative_np + 47
      3   ...ia.Flash Player.authplaylib 0x2314a0e7 0x22cfa000 + 4522215
      4   ...ia.Flash Player.authplaylib 0x22eda9de 0x22cfa000 + 1968606
      Thread 45:
      Thread 0 crashed with X86 Thread State (32-bit):
        eax: 0x00000001  ebx: 0x232a0228  ecx: 0x3a83a390  edx: 0x00000000
        edi: 0x00000002  esi: 0x0000000c  ebp: 0xbfffe3f8  esp: 0xbfffe3d0
         ss: 0x00000023  efl: 0x00010202  eip: 0x23340ac8   cs: 0x0000001b
         ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
        cr2: 0x00000001
      Binary Images:
          0x1000 -  0x1a54ff3 +com.adobe.flash 11.5.0.325 (11.5.0) <D03BEE1B-4B97-8469-285F-A5746B2AE425> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/MacOS/Adobe Flash CS5.5
      0x2db7000 -  0x2f31fe3 +com.adobe.PlugPlug 2.5.0.232 (2.5.0.232) <04C90B5C-DC6D-A2B5-BE9B-193466222BE7> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
      0x2fda000 -  0x30a7fe7 +com.adobe.AXEDOMCore AdobeAXEDOMCore 3.5.101.12783 (3.5.101.12783) <117ACA20-072D-0AB2-CCB9-0385FF43CB14> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
      0x3119000 -  0x31aaff7 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <581475CC-C039-1B42-49BA-71811D8B4E15> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
      0x31c9000 -  0x3296ff3 +libicui18n.dylib.36.0 36.0.0 (compatibility 36.0.0) <08F15219-7F35-574E-7725-1ACAA1B18A00> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ICUInternationalization.framework/Versions/3.6/libicui18n.d ylib.36.0
      0x32f9000 -  0x33d3fef +libicuuc.dylib.36.0 36.0.0 (compatibility 36.0.0) <5EE72009-40B3-7FB7-3A49-576AEDE0D400> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.6/libicuuc.dylib.36.0
      0x3413000 -  0x3dc3fff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <02108DEA-3DD2-14BE-DAEB-BE522B619C1D> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
      0x3dc6000 -  0x3dd1ff3 +libChar16.dylib ??? (???) <758855AC-2E45-350B-D64E-39422835F760> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/MacOS/libChar16.dylib
      0x3dda000 -  0x3df3fe7 +libCoreTypes.dylib ??? (???) <4943E74A-FB75-ABB7-C34A-967920772CB4> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/MacOS/libCoreTypes.dylib
      0x3e15000 -  0x3e24fef +ZLib.dylib ??? (???) /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/frameworks/ZLib.dylib
      0x3e29000 -  0x4033fe7  com.apple.carbonframeworktemplate 1.0 (1.0) <FB292B4C-FDAC-2E77-7540-CE36B139C5E1> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/frameworks/Xerces.framework/Versions/A/Xerces
      0x4371000 -  0x4375ff7  com.apple.JavaVM 13.5.0 (13.5.0) <20F901A0-ED96-1757-E741-28A79EE4CEB2> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
      0x437d000 -  0x5108fe7 +com.adobe.illustrator 382 (15.0.0) <64F68532-0311-6BBA-1F50-246CAF917549> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
      0x5eed000 -  0x5f31fff +com.adobe.illustrator.aiport AIPort version 1.0 (1.0) <69EDC44E-D7BB-A259-282D-C42725AE0E26> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AIPort.framework/Versions/A/AIPort
      0x5f94000 -  0x5fdafff +FilterPort ??? (???) <23FAE9D1-9376-1E71-21F7-D3EB2BFD50EE> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/FilterPort.framework/Versions/A/FilterPort
      0x604f000 -  0x604ffff +SPBasic ??? (???) <5D1760D8-C910-C641-0BC9-CF74A1A5190D> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
      0x6053000 -  0x606fff9 +AdobePDFSettings ??? (???) /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
      0x6089000 -  0x61c4ff2 +com.adobe.ACE AdobeACE 2.18.00.12659 (2.18.00.12659) <5BD496D2-2E2B-0411-779F-855603C5B2AE> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
      0x61ec000 -  0x66eefef +com.adobe.AGM AdobeAGM 4.20.70.12659 (4.20.70.12659) <7F6464ED-C80E-0267-A225-93B2BE537147> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
      0x6833000 -  0x686efff +com.adobe.ARE AdobeARE 1.5.02.12659 (1.5.02.12659) <639DF4B8-4D45-0517-4DED-D1CB1FC6EC12> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
      0x6878000 -  0x6892fff +com.adobe.BIB AdobeBIB 1.2.02.12659 (1.2.02.12659) <6A0E1ACF-23E8-B966-3B51-8F264E269469> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
      0x689c000 -  0x68bdff7 +com.adobe.BIBUtils AdobeBIBUtils 1.1.01 (1.1.01) <F9DA3036-401B-89A5-9512-B009D29A9B2F> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
      0x68ca000 -  0x6bbcff7 +com.adobe.CoolType AdobeCoolType 5.07.124.12659 (5.07.124.12659) <0481471E-E075-0782-BA1C-C5A5E23C5565> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
      0x6c49000 -  0x7022ff7 +com.adobe.MPS AdobeMPS 5.5.0.12659 (5.5.0.12659) <F15ACFDA-4804-A70B-CA40-13888F4B8A04> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
      0x7159000 -  0x723cfef +com.adobe.PDFPort AdobePDFPort 2.1.0.12659 (2.1.0.12659) <EAF6E16F-E356-551A-0484-50141914178C> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
      0x7274000 -  0x78a9feb +com.adobe.PDFL 9.9.0 (9.9.0.12659) <0C6CF147-E5A9-7C3F-A25C-CD096C910D4D> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
      0x79df000 -  0x7a05ff6 +com.adobe.AXE8SharedExpat AdobeAXE8SharedExpat 3.5.101.12783 (3.5.101.12783) <C7FD5306-E881-A19A-0F40-0E3844278526> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedEx pat
      0x7a18000 -  0x7a3ffed +com.adobe.AXE16SharedExpat AdobeAXE16SharedExpat 3.5.101.12783 (3.5.101.12783) <13B60B50-7241-73D6-E551-6E2E3E0AD7ED> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16Shared Expat
      0x7a52000 -  0x7aaaff7 +com.adobe.AdobeXMPCore Adobe XMP Core 5.2 -c 3 (61.141987) <31B045A8-AA5F-AFDF-E2DD-71B418CD1707> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
      0x7aba000 -  0x7b27fef +com.adobe.FileInfo.framework Adobe XMP FileInfo 5.2 -i 1 (debug) (61.141987) <ABF47D32-C58A-F9CE-E753-F0F906B13F7E> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
      0x7b44000 -  0x7ce3fe7 +com.adobe.owl AdobeOwl version 3.0.81 (3.0.81) <9C261D9E-9BD7-5DE6-5676-AEEF4828D17B> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
      0x7d4c000 -  0x8addfeb +com.adobe.psl AdobePSL 12.0.0.12659 (12.0.0.12659) <03D5B098-AD3C-FB84-0D0D-7DE57C025F3F> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
      0x8e45000 -  0x902bff7 +com.adobe.linguistic.LinguisticManager 5.0.0 (11696) <AF804353-8B13-7180-F2C8-832361EB2D5A> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
      0x90b9000 -  0x90bdffc +com.adobe.AdobeCrashReporter 3.0 (5.5.20101001) <EA9B7B55-7FE5-14D2-FBAE-817121F94086> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
      0x90c3000 -  0x9387ff3 +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.150919) <54BE6966-C47D-08E4-D08A-36B4949DE849> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
      0x968c000 -  0x97e6fff +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.150919) <549A0950-E4E2-F867-2A0D-ABFC00A56E54> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
      0x993c000 -  0x9c5dfe7 +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.150919) <3F958167-F680-C012-8CCA-424B65E75F9C> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
      0xa123000 -  0xa191ffb +com.adobe.amtlib amtlib 4.0.0.21 (4.0.0.21) <3090D254-587A-A820-DBCD-729C27532FC8> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
      0xa1a8000 -  0xa1feffb +com.adobe.headlights.LogSessionFramework ??? (2.1.2.1263) <5B594BC9-5222-651B-6B70-7AD067035B1A> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
      0xa247000 -  0xa27cfef +com.adobe.pip ??? (5.5.0.1265) <660E209C-F595-AB0B-FB5E-C8FC1527CF4D> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
      0xa287000 -  0xa3bffe7 +WRServices ??? (???) <87183F9D-17F4-6BDC-66A9-8FD34F320118> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
      0xa401000 -  0xa407ff3 +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.150919) <615D7334-B103-3FE9-2150-1BA67D6B541F> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
      0xa418000 -  0xa423fff +com.adobe.boost_filesystem.framework boost_filesystem version 5.0.0 (5.0.0.150919) <84E8374D-5DB8-E2F5-8677-D9D715FC04CE> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
      0xa437000 -  0xa4b6fff +com.adobe.boost_regex.framework boost_regex version 5.0.0 (5.0.0.150919) <DA8506EE-FC4B-7FE3-0B8B-75889386B07C> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
      0xa51a000 -  0xa524ffb +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.150919) <CFE6F1B2-7A2E-9D22-EE9F-267F765FE0F6> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
      0xa537000 -  0xa539ff3 +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.150919) <084DB300-4206-FDCD-EC2F-1D54F0A13E1D> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
      0xa541000 -  0xa549ffb +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.150919) <79DF91DA-997F-5806-D847-667A7AE3FE6A> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
      0xa559000 -  0xa6f6ff7 +com.adobe.AFlamingo AFlamingo 2.1.402.12783 (2.1.402.12783) <B34C21DA-5AF0-47BD-5375-375414ACC9CD> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
      0xa8c5000 -  0xa8c8ffc +com.adobe.ape.shim adbeape version 3.1.74.12761 (3.1.74.12761) <FE2ABE8A-1D3F-7AF5-297C-D22FC3E0FBDA> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
      0xa8cf000 -  0xa9e1ff7 +FlashIK Framework ??? (1.0) <8EB8A2F0-C7B0-63FC-28A0-D69E43B0AE92> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/FlashIK.framework/Versions/A/FlashIK
      0xaa73000 -  0xaab9ff7 +PFF Framework ??? (1.0) <8256E961-D8D3-0515-5FB9-A75C1D440923> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/PFF.framework/Versions/A/PFF
      0xaae3000 -  0xb4e3fef +com.adobe.AFlame AFlame 1.1.5.12783 (1.1.5.12783) <842BEADF-C618-794C-DA88-3BE4C23A697F> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/aflame.framework/Versions/A/aflame
      0xb6b6000 -  0xb6dfff3 +com.adobe.contextui.framework contextui version 5.0.0 (5.0.0.150919) <3D09FEF1-1029-490D-0B74-9E54098EF9E3> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/contextui.framework/Versions/A/contextui
      0xb71b000 -  0xb71fff7  JavaLaunching ??? (???) <91BF8AB9-AFE3-F32B-B657-959C49CF4928> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
      0xb725000 -  0xb765ff7  com.apple.vmutils 4.2 (106) <92BB4844-304C-C7AB-1F9B-686537C56099> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
      0xb77e000 -  0xb833fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <78B6EEB6-50D9-4479-D1A5-B4C381A07E4D> /usr/lib/libcrypto.0.9.7.dylib
      0xb879000 -  0xb87cfe3 +com.adobe.dvaflashview.framework dvaflashview version 5.0.0 (5.0.0.150919) <318AE6D8-5D2E-B899-A4A9-40DBBED181BF> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
      0xb8f5000 -  0xb8f6ff7  com.apple.textencoding.unicode 2.3 (2.3) <A7D310DB-A5E6-C834-F72F-A66453834CC0> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
      0xbbe6000 -  0xbbeefff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
      0xbff9000 -  0xbffaff7  ATSHI.dylib ??? (???) <56F243F1-C341-86EA-2BCC-31E75D46EBBC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
      0x114d7000 - 0x114e5fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <4D4E2081-4DB2-8F38-F233-4B8B8C1A64B9> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
      0x114e9000 - 0x114fbff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <665E7F35-8391-AA75-E032-E643B3989F19> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
      0x11600000 - 0x1166bfe7 +com.adobe.amt.services AMTServices 4.0.0.21 (BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00) (4.0.0.21) <018F21DE-7E2E-C850-4C32-D4A2131ABF74> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
      0x11687000 - 0x116f7feb +com.adobe.adobe_caps adobe_caps 4.0.42.0 (4.0.42.0) <55D7D2EA-D21E-98B1-77C6-58C0A0E07051> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
      0x117c9000 - 0x117cdff3  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <E9CB576C-283B-1DB2-0C69-E7C914BD7922> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
      0x117d2000 - 0x117d8ff7  com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f13) <76BC9284-582A-EF9A-960D-5CD0801B1917> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
      0x117e2000 - 0x117e3ff3 +com.macromedia.Flash.flastoragelib 9.0 (9.0) <841F9AEF-0220-C997-42CA-30BB849C5089> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/PlugIns/FLAStorageLib.bundle/Contents/MacOS/FLAStorageLib
      0x2262d000 - 0x2262fff7 +com.macromedia.Flash.FLfile 11.5.0.325 (11.5.0) <21E1B8AE-CB7E-7019-218F-A9AC206C88B5> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/FLfile.bundle/Contents/MacOS/FLfile
      0x22632000 - 0x22642ff3 +com.yourcompany.PointGrid ??? (1.0) <1572B151-C83B-B62E-A9C5-F741706082E5> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/PointGrid.bundle/Contents/MacOS/PointGrid
      0x22656000 - 0x2266aff7 +AdobeSFL ??? (???) <D6D44AC1-8AEC-56BB-8CDD-9059711B3485> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
      0x22670000 - 0x22699fef +com.adobe.ape adbeapecore version 3.1.74.12761 (3.1.74.12761) <21548488-E9C3-4638-D7FC-895EE0F8EE30> /Library/Application Support/Adobe/APE/3.101/adbeapecore.framework/adbeapecore
      0x22cfa000 - 0x236ecff3 +com.macromedia.Flash Player.authplaylib 10.2.153.2 (10.2.153.2) <3CFE191B-E5E1-6C47-46DB-FE24C06872B7> /Applications/Adobe Flash CS5.5/Common/Configuration/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
      0x23ea3000 - 0x23edcffb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 2.0.0.15 (2.0.0.15) <3A9CF871-6678-90BB-3770-CDBF56AF21D5> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotificati ons
      0x2418f000 - 0x24194ff7  libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <31610F71-4447-CC8F-2859-4B881BB48F9E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
      0x242ad000 - 0x242b4ff7  libverify.dylib 1.0 (1.0) <032F1D31-9879-044D-778B-44277CDA9BBB> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libverify.dylib
      0x26240000 - 0x26247ffb  libjvmlinkage.dylib ??? (???) <CEBF52ED-6F28-BC0E-A3F6-C1CCE925FB0A> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjvmlinkage.dylib
      0x27034000 - 0x2703cff7  JavaNativeFoundation ??? (???) <DB43720B-D43B-26A9-AB19-6DCCB5732F3A> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.fr amework/Versions/A/JavaNativeFoundation
      0x27164000 - 0x27187fe7 +ServiceManager-Launcher.dylib 236.0.0 (compatibility 2.5.0) <F2933B29-0CC1-00B4-1778-BF44110851F8> /Library/Application Support/Adobe/CS5.5ServiceManager/lib/ServiceManager-Launcher.dylib
      0x271be000 - 0x271daff7  libjava.jnilib ??? (???) <9DACA27C-BFBB-58BF-281B-A0C0F9A813C4> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjava.jnilib
      0x27316000 - 0x27334ff7 +com.adobe.flash.cs55.airAndroid 11.5.0.0 (11.5.0) <7BFBDD83-2B68-53BB-0E0D-43C105CB5719> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/Air2_5_Android.bundle/Contents/MacOS/Air2_5_Android
      0x273b6000 - 0x273c2ff7  libzip.jnilib ??? (???) <BAAB3F70-196A-60A9-9E75-5A9FB5989E3F> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libzip.jnilib
      0x27655000 - 0x27677ff7 +com.adobe.flash.cs55.air 11.5.0.0 (11.5.0) <1329BBFC-ED3D-C787-92B6-A63177C2552B> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/Air2_5.bundle/Contents/MacOS/Air2_5
      0x28a42000 - 0x28aa7fe7 +com.yourcompany.Brush ??? (1.0) <514A0F0D-DA07-9F32-B3A8-A1F1C12BF0E3> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/Brush.bundle/Contents/MacOS/Brush
      0x2ac98000 - 0x2acd9ff3 +com.adobe.flash.flbridge 11.5.0.325 (11.5.0) <72AC5C1A-8338-C772-EF75-D30229D44F9C> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/FLBridge.bundle/Contents/MacOS/FLBridge
      0x2b900000 - 0x2bc39ff7  libjvm.dylib ??? (???) <463F6D7A-45CF-0F85-167A-18BB2879EB48> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bundle/Libraries/libjvm. dylib
      0x2c700000 - 0x2c789ff7 +com.yourcompany.Collision ??? (1.0) <F7BEA1C6-99F5-FBA8-F960-20F7DC0CE06F> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/Collision.bundle/Contents/MacOS/Collision
      0x2ec00000 - 0x2ed15fff +com.yourcompany.Stroke ??? (1.0) <2DCF3D57-AEF2-C4EB-8677-135673A4BE47> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/Stroke.bundle/Contents/MacOS/Stroke
      0x40000000 - 0x400d1fe7 +com.adobe.JP2K 2.0.0 (2.0.0.12659) <88D70F2A-FFBA-EEB2-123D-42F4EB7CF4E3> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
      0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <283EE026-C0FE-1FF9-DB81-BFB155793157> /usr/lib/dyld
      0x90003000 - 0x90067fff  com.apple.htmlrendering 72 (1.1.4) <0D22B190-513B-7FF6-39FC-9D336285DE08> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
      0x90068000 - 0x90074ff7  libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
      0x90075000 - 0x90080ff7  libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x90081000 - 0x90101feb  com.apple.SearchKit 1.3.0 (1.3.0) <7AE32A31-2B8E-E271-C03A-7A0F7BAFC85C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
      0x9012f000 - 0x90199fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
      0x902b7000 - 0x903f4fe7  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <2D31CC6F-32CC-72FF-34EC-AB40CEE496A7> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x903f5000 - 0x903f5ff7  com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
      0x903f6000 - 0x906f0fef  com.apple.QuickTime 7.6.6 (1783) <1EC8DC5E-12E3-1DB8-1F7D-44C6EF193C58> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
      0x91644000 - 0x91724fe7  com.apple.vImage 4.1 (4.1) <AEF800AE-65DA-5E79-5B01-165AF51BAAF6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
      0x91725000 - 0x91725ff7  com.apple.ApplicationServices 38 (38) <EAF1BC8C-4FD4-4300-B8F7-4B24E49125E2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x91726000 - 0x91726ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
      0x91727000 - 0x918ceff7  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
      0x918cf000 - 0x91948ff7  com.apple.PDFKit 2.5.1 (2.5.1) <4C374867-71B8-B202-ADDA-9985B4379470> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
      0x91962000 - 0x9199fff7  com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x919a0000 - 0x91aa1fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <E1A44C67-FA6C-0188-F46F-EA14CEE557BB> /usr/lib/libxml2.2.dylib
      0x91aa2000 - 0x91abaff7  com.apple.CFOpenDirectory 10.6 (10.6) <6D726EA4-67D2-E534-13A3-E3767BA59786> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
      0x91abb000 - 0x91af9ff7  com.apple.QuickLookFramework 2.3 (327.6) <FCA83173-6DBF-615C-699A-529A7FD821ED> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
      0x91bb5000 - 0x91ce3fe7  com.apple.CoreData 102.1 (251) <0C2636F3-CCB4-5ED9-1D3E-5AE36BE57071> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x91ce4000 - 0x91d81fe3  com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
      0x91d82000 - 0x92665ff7  com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x92666000 - 0x92666ff7  liblangid.dylib ??? (???) <FCC37057-CDD7-2AF1-21AF-52A06C4048FF> /usr/lib/liblangid.dylib
      0x92667000 - 0x927e2fe7  com.apple.CoreFoundation 6.6.5 (550.43) <10B8470A-88B7-FC74-1C2F-E5CBD966C051> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x92932000 - 0x9296dfeb  libFontRegistry.dylib ??? (???) <AD45365E-A3EA-62B8-A288-1E13DBA22B1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
      0x92a40000 - 0x92b6dffb  com.apple.MediaToolbox 0.484.52 (484.52) <C9035045-D1B4-1B1F-7354-B00D1094D804> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
      0x92bbf000 - 0x92bc3ff7  IOSurface ??? (???) <7D8204CE-3FF9-27EC-A760-9321C44467A2> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
      0x92c13000 - 0x92d15fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
      0x92d16000 - 0x92d59ff7  com.apple.NavigationServices 3.5.4 (182) <FE19D51B-233A-69EC-9E36-B89D0EA438C1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
      0x92d5a000 - 0x92ddcffb  SecurityFoundation ??? (???) <20512B7E-DC54-8242-B656-64DCA1BFB739> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
      0x92ddd000 - 0x92e2dff7  com.apple.framework.familycontrols 2.0.2 (2020) <592738FA-B093-279A-8D4E-3F76A21E2912> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
      0x92e2e000 - 0x92e74ff7  libauto.dylib ??? (???) <7CB1AB76-50A2-8E56-66E4-CF51CA75B177> /usr/lib/libauto.dylib
      0x92e83000 - 0x92eb6fff  libTrueTypeScaler.dylib ??? (???) <0F04DAC3-829A-FA1B-E9D0-1E9505713C5C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
      0x92eb7000 - 0x92f26ff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <B3DEACA1-9375-CF8F-0898-AA2C5F8159DC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
      0x92fd1000 - 0x93193feb  com.apple.ImageIO.framework 3.0.4 (3.0.4) <20E90968-E04B-7B68-DBA2-92C729A8243F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
      0x93327000 - 0x93334ff7  com.apple.NetFS 3.2.2 (3.2.2) <0A53CD10-DBC7-2BE8-34F7-354BE201F6FB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
      0x93335000 - 0x93335ff7  com.apple.quartzframework 1.5 (1.5) <7DD4EBF1-60C4-9329-08EF-6E59731D9430> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
      0x933ae000 - 0x933afff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <838E1760-F7D9-3239-B3A8-20E25EFD1379> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x933b0000 - 0x933f9fe7  libTIFF.dylib ??? (???) <10F7E21B-EC59-6594-004F-798DA3F37789> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
      0x933fa000 - 0x934b6fff  com.apple.ColorSync 4.6.6 (4.6.6) <7CD8B191-039A-02C3-EA5E-4194EC59995B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
      0x934b7000 - 0x934beff7  com.apple.agl 3.0.12 (AGL-3.0.12) <46BD2265-78DC-2FAB-73C6-E224755C070D> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
      0x934d2000 - 0x9356dfe7  com.apple.ApplicationServices.ATS 275.16 (???) <873C8B8A-B563-50F7-7628-524EE9E8DF0F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
      0x9356e000 - 0x935afff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
      0x935f1000 - 0x9366cfff  com.apple.AppleVAFramework 4.10.26 (4.10.26) <B293EC46-9F71-F448-F0E7-2960DC6DAEF7> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
      0x936b6000 - 0x9391cff7  com.apple.security 6.1.2 (55002) <64A20CEB-E614-D35F-7B9F-246BCB25BA23> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0x9391d000 - 0x9394eff7  libGLImage.dylib ??? (???) <0EE86397-A867-0BBA-E5B1-B800E43FC5CF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x9395d000 - 0x9397ffef  com.apple.DirectoryService.Framework 3.6 (621.11) <401E67B3-96DF-287B-2892-210C3A2EE9A6> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
      0x93980000 - 0x93a39fe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <03186216-0A12-4AA9-D7BA-3E3551A1195C> /usr/lib/libsqlite3.dylib
      0x93a8e000 - 0x93aa2ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <9F5CE4F7-D05C-8C14-4B76-E43D07A8A680> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
      0x93aa3000 - 0x93b51ff3  com.apple.ink.framework 1.3.3 (107) <E215794C-F3E9-C067-8882-9054796DDA8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
      0x93b52000 - 0x93b56ff7  libGIF.dylib ??? (???) <B7BA65AF-681C-F18B-A434-CBEC76A45646> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
      0x93e51000 - 0x93eaeff7  com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x93eaf000 - 0x94902ff7  com.apple.WebCore 6533.21 (6533.21.1) <04C66A67-4CF2-5F4B-4EA3-00E67B0F9411> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
      0x94903000 - 0x949affe7  com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
      0x949b0000 - 0x949c2ff7  com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
      0x949c3000 - 0x94b45fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <D5980817-6D19-9636-51C3-E82BAE26776B> /usr/lib/libicucore.A.dylib
      0x94b4e000 - 0x94be6fe7  edu.mit.Kerberos 6.5.11 (6.5.11) <88CA2CC8-9005-E017-6D61-5809C3CE5FC6> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x94be7000 - 0x94c55ff7  com.apple.QuickLookUIFramework 2.3 (327.6) <0A8CF0E7-9ED7-31F2-B6CC-7EE5A5F2EEC9> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
      0x94c56000 - 0x94caefe7  com.apple.datadetectorscore 2.0 (80.7) <463C62DE-2664-E186-915A-0772C6AC0664> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
      0x94caf000 - 0x94edaff3  com.apple.QuartzComposer 4.2 ({156.30}) <2C88F8C3-7181-6B1D-B278-E0EE3F33A2AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
      0x94edc000 - 0x94f20fe7  com.apple.Metadata 10.6.3 (507.15) <460BEF23-B89F-6F4C-4940-45556C0671B5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
      0x94f21000 - 0x94f42fe7  com.apple.opencl 12.3.6 (12.3.6) <B774CF2D-C067-DFFE-3EE6-90A036E36E06> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
      0x94f46000 - 0x94f46ff7  com.apple.Carbon 150 (152) <8DD4F8DB-6DBD-1F65-F4EB-2981DBFDED50> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x94fbc000 - 0x9501dfe7  com.apple.CoreText 151.10 (???) <5C2DEFBE-D54B-4DC7-D456-9ED02880BE98> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
      0x9501e000 - 0x9580d557  com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
      0x9580e000 - 0x95829ff7  libPng.dylib ??? (???) <4C105512-6FA8-2AE0-D058-6A8AA00F9DA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
      0x95a54000 - 0x95aa7ff7  com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
      0x95aa8000 - 0x95ab8ff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <E276514D-394B-2FDD-6264-07A444AA6A4E> /usr/lib/libsasl2.2.dylib
      0x95ab9000 - 0x95cb7ff3  com.apple.JavaScriptCore 6533.20 (6533.20.20) <C97A479C-FDF9-3F19-2EE0-80288257C477> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
      0x95cb8000 - 0x95cc8ff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <95DC4010-ECC4-3A75-5DEE-11BB2AE895EE> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
      0x95cc9000 - 0x95d81feb  libFontParser.dylib ??? (???) <D57D3834-9395-FD58-092A-49B3708E8C89> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
      0x95e33000 - 0x95ec5fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <EE9ED7BE-7D97-B759-C063-1E4B7DBD3775> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
      0x95ec6000 - 0x95ed0ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <90C38107-AEE7-AE55-5C51-28D129B19BCD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
      0x95ed1000 - 0x95ed6ff7  com.apple.OpenDirectory 10.6 (10.6) <7E8AFE74-1FA9-7B35-A0E3-545959A9CA73> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
      0x95f1c000 - 0x95f22fff  com.apple.CommonPanels 1.2.4 (91) <CE92759E-865E-8A3B-1488-ECD497E4074D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
      0x95f23000 - 0x96032fe7  com.apple.WebKit 6533.21 (6533.21.1) <87AFEE12-270F-2D84-1B93-81DF1DA47A7F> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
      0x96033000 - 0x9613fff7  libGLProgrammability.dylib ??? (???) <04D7E5C3-B0C3-054B-DF49-3B333DCDEE22> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
      0x9617d000 - 0x96180fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
      0x96188000 - 0x961d5feb  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <9E35835E-BC33-F8EC-8F3B-84D51DEBDB16> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
      0x961d6000 - 0x961d6ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x961d7000 - 0x96542ff7  com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x96543000 - 0x96599ff7  com.apple.MeshKitRuntime 1.1 (49.2) <4B41E225-69AC-6EFA-190E-DC6A4BD8109E> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
      0x966a1000 - 0x966a7fe7  com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
      0x966a8000 - 0x966cfff7  com.apple.quartzfilters 1.6.0 (1.6.0) <F45520B0-6B27-CD57-54B1-203FE32120DA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
      0x966d0000 - 0x966f6ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <5A8D5D84-06EB-F9B5-BA0A-A87A0A2C0035> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
      0x9683a000 - 0x96856fe3  com.apple.openscripting 1.3.1 (???) <0E6B81D1-C1BD-1B5F-836F-256E6701B5DE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
      0x96863000 - 0x968aaffb  com.apple.CoreMediaIOServices 140.0 (1496) <DA152F1C-8EF4-4F5E-6D60-82B1DC72EF47> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
      0x968be000 - 0x968defe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <584B2B30-DC65-6930-F59F-C49FD5604B67> /usr/lib/libresolv.9.dylib
      0x968df000 - 0x96d9aff7  com.apple.VideoToolbox 0.484.52 (484.52) <F7CF9485-A932-1305-9AA6-3F7AC38B8B15> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
      0x96d9b000 - 0x96f7dfff  com.apple.imageKit 2.0.3 (1.0) <6E557757-26F7-7941-8AE7-046EC1871F50> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
      0x96fb8000 - 0x96fccfe7  libbsm.0.dylib ??? (???) <B328FA0A-899C-4FC4-F2AC-2FDC08819CD2> /usr/lib/libbsm.0.dylib
      0x9701b000 - 0x97095fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x97096000 - 0x973bafef  com.apple.HIToolbox 1.6.5 (???) <F21289A3-A00E-0BC3-66F1-7557862CE7EB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
      0x97499000 - 0x9749cffb  com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
      0x9749d000 - 0x97577fff  com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
      0x97578000 - 0x975baff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <1AE34B00-8A62-1E51-935F-BB3F0E4BE50F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
      0x975bb000 - 0x976bdfef  com.apple.MeshKitIO 1.1 (49.2) <EC52D0C5-5291-441D-F137-8E4DD60F0E25> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
      0x976be000 - 0x976ccfe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <E1B922F4-23DC-467E-631F-7E1B9C9F51CB> /usr/lib/libz.1.dylib
      0x976d2000 - 0x97b23fef  com.apple.RawCamera.bundle 3.7.1 (570) <AF94D180-5E0F-10DF-0CB2-FD8EDB110FA2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
      0x97d47000 - 0x97d48ff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <1DD14B2E-E466-1A45-5CF7-947766F0ECD9> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
      0x97d49000 - 0x97d68ff7  com.apple.CoreVideo 1.6.2 (45.6) <F9E52A13-E181-D302-3B0E-0799ED6D6130> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x97d69000 - 0x97d6bff7  libRadiance.dylib ??? (???) <47E300B5-DBEF-86C4-29BD-86DBEDD2FBB5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
      0x97daf000 - 0x97ea3ff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <475AEF89-91A5-5100-8662-DA508D3830E9> /usr/lib/libiconv.2.dylib
      0x97ea4000 - 0x97eadff7  com.apple.DiskArbitration 2.3.1 (2.3.1) <AAE0185D-4A47-1833-27A3-03FDF734A3BA> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x97ecd000 - 0x97f10ff7  libGLU.dylib ??? (???) <FB26DD53-03F4-A7D7-8804-EBC5B3B37FA3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x97f11000 - 0x97f12ff7  com.apple.TrustEvaluationAgent 1.1 (1) <06484720-AB50-6FD9-B5BF-05F5A640C9E5> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
      0x97f87000 - 0x97f89ff7  com.apple.securityhi 4.0 (36638) <A5F4B929-AEDE-2DFB-E02F-89CEC0940023> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
      0x97f8a000 - 0x97f8aff7  com.apple.CoreServices 44 (44) <B9461120-F72A-D28F-D0CF-5647958BD3F9> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x97f8b000 - 0x97f96ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
      0x97fa1000 - 0x97fb6fff  com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
      0x97fc7000 - 0x97ffaff7  com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
      0x97ffb000 - 0x9803fff3  com.apple.coreui 2 (114) <1A3C3B7F-3837-6477-3114-47F6BFD56CB2> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x98040000 - 0x982b1fef  com.apple.Foundation 6.6.7 (751.62) <5C995C7F-2EA9-50DC-9F2A-30237CDB31B1> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x982eb000 - 0x9831bff7  com.apple.MeshKit 1.1 (49.2) <464BD81C-9970-FBF5-507F-3EEBD020A967> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
      0x9831c000 - 0x9845ffef  com.apple.QTKit 7.7 (1783) <0C6814E2-98C2-74F4-770F-BA355CA86F0F> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
      0x98460000 - 0x984bafe7  com.apple.CorePDF 1.4 (1.4) <78A1DDE1-1609-223C-A532-D282DC5E0CD0> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
      0x984bb000 - 0x984c2ff3  com.apple.print.framework.Print 6.1 (237.1) <726A7F31-8C27-8403-0016-71E022EDC14C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
      0x984c3000 - 0x98508ff7  com.apple.ImageCaptureCore 1.1 (1.1) <F54F284F-0B81-0AFA-CE47-FF797A6E05B0> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
      0x9850c000 - 0x9851dff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <B59157A1-8796-CE8F-2508-EB96F093F6A7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
      0x9851e000 - 0x9852cff7  com.apple.opengl 1.6.13 (1.6.13) <025A905D-C1A3-B24A-1585-37C328D77148> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x98ba9000 - 0x98be6ff7  com.apple.CoreMedia 0.484.52 (484.52) <62B0C876-A931-372F-8947-7CBA0379F427> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
      0x98c00000 - 0x98ca8ffb  com.apple.QD 3.36 (???) <5A93B258-3853-636F-DB26-223642DA2779> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
      0x98da5000 - 0x98dcdff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <315D97C2-4E1F-A95F-A759-4A3FA5639E75> /usr/lib/libxslt.1.dylib
      0x98dce000 - 0x98e99fef  com.apple.CoreServices.OSServices 359 (359) <1EBCB6E1-C23A-D21A-0FDE-B3763DCCF790> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
      0x98ffd000 - 0x99021ff7  libJPEG.dylib ??? (???) <0C406884-DAAF-0409-2659-9D1602D752D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
      0x99022000 - 0x99025ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
      0x99026000 - 0x99060ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <038731B1-CC44-3943-E3DE-4BAAA203EB72> /usr/lib/libcups.2.dylib
      0x99061000 - 0x99069ff7  com.apple.DisplayServicesFW 2.3.3 (289) <828084B0-9197-14DD-F66A-D634250A212E> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
      0x990fe000 - 0x99514ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <9D89FCB3-24C9-8FCF-DB49-27B184AC3222> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
      0x99515000 - 0x9994aff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <4D2F47EF-BD32-1E3C-6A0A-438896ADE2BE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
      0x99987000 - 0x9998bff7  libGFXShared.dylib ??? (???) <801B2C2C-1692-475A-BAD6-99F85B6E7C25> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
      0x9999c000 - 0x999a6fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <DE0E0EF6-8190-3F65-6BDD-5AC9D8A025D6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
      0x999e8000 - 0x999ebff7  libCoreVMClient.dylib ??? (???) <F58BDFC1-7408-53C8-0B08-48BA2F25CA43> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
      0x999ec000 - 0x999ecff7  com.apple.Cocoa 6.6 (???) <5A785062-1ABB-2A54-BAAC-8FEF95275E05> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x999ed000 - 0x99a9afe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
      0x99a9b000 - 0x99dbbff3  com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
      0x99e56000 - 0x9a034fe3  libType1Scaler.dylib ??? (???) <97A2DBFA-C50B-266C-E63A-D6644F3B737C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
      0xb0000000 - 0xb0011ff8 +com.adobe.ahclientframework 1.6.0.20 (1.6.0.20) <6FB288F2-45FD-E54A-C9A4-A0D0C374FE37> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
      0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <2E9CCEDF-3323-FAE3-700D-33F532934139> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
      0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <C06BBEE8-081F-D16A-54DD-448BCB845EAE> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
      0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
      Model: MacBookPro8,2, BootROM MBP81.0047.B0E, 4 processors, Intel Core i7, 2.3 GHz, 8 GB, SMC 1.69f1
      Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 1024 MB
      Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 512 MB
      Memory Module: global_name
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 5.100.198.104.5)
      Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
      Network Service: Ethernet, Ethernet, en0
      Serial ATA Device: TOSHIBA MK7559GSXF, 698.64 GB
      Serial ATA Device: MATSHITADVD-R   UJ-898
      USB Device: FaceTime HD Camera (Built-in), 0x05ac  (Apple Inc.), 0x8509, 0xfa200000 / 3
      USB Device: Hub, 0x0424  (SMSC), 0x2513, 0xfa100000 / 2
      USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x0245, 0xfa120000 / 5
      USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 4
      USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x821a, 0xfa113000 / 8
      USB Device: Hub, 0x0424  (SMSC), 0x2513, 0xfd100000 / 2
      USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0xfd110000 / 3
      FireWire Device: G-Drive mini Device 00, G-TECH, Up to 800 Mb/sec
        • 1. Re: CS5.5 file crashes Flash on opening
          Sukhi12 Level 1
          Hi ,
          Could you please send us fla file that reproduce the issue  to FlashAuthBetaBugs@adobe.com
          If you are sending a zip file please change the file extension from .zip to .zzz.
          Sukhbir
          Flash Authoring
          • 2. Re: CS5.5 file crashes Flash on opening
            k-yo! Level 1
            Thanks! I sent some files.
            I'm thinking it's related to a font embedded and used dynamically from the Library. I rebuilt one of the .flas a layer at a time and I'm sure it's the embeded font (in the library). There are 2 test .flas 1 with the  embedded font and 1 without.
            Oddly enough, 1 of the times I was testing a layer at a time the file opened without crashing and then the other 2 real .flas also opened without crashing, but when I quit Flash and tried to open them a again I got the same crash issue and the files wouldn't open.
            I haven't tried yet, but I'm going to see if it crashes using a different font. The font is one of Adobe's and used as branded element in the design so I can't really change it for production use, but it would be worth it to test.
            Dave
