4 Replies Latest reply on Apr 7, 2009 9:24 AM by Ang-O
    Shockwave parseUrl()
      I'm using the XML Parser.
      It works fine in edit mode and as a projector.
      It does not work when I publish to shockwave.
      I've worked with Director for years, but never did a shock before. So, I'm guessing I'm ignorant of some Shocking Truth (pun intended!!).
      Thanks for any help!!!
      Angelo
        • 1. Re: Shockwave parseUrl()
          Level 7
          The XML Parser xtra is a scripting xtra, not an asset xtra, so isn't
          automatically added to your movie's xtraList, much less marked as
          "Download if needed..." - and that last part is crucial as it isn't part
          of the slim installer.
          So: open your Director movie in the authoring environment, open the
          dialog at Modify -> Movie -> Xtras and make sure the xtra is listed (Add
          it if not) and then select it in the list and ensure that the "Download"
          box is checked.
          • 2. Re: Shockwave parseUrl()
            Level 1
            Thanks Sean,
            I have done that. I also downloaded a simple XML demo file that does work fine and am trying to see what the differences are.
            1. I've read about the dswMedia directory and am a little confused about that. Does everything go in there or just linked casts, etc?
            2. Is there any other differences between Shock and projectors?
            I know I'm missing something simple.
            Thanks!!
            Angelo
            • 3. Re: Shockwave parseUrl()
              Level 1
              It appears that my initial exit frame where I check for parsing to be complete was not right. The program was moving on before everything was parsed.
              Thanks!!
              Angelo
              • 4. Re: Shockwave parseUrl()
                Level 1
                The solution was to force a synchronous flow in the code.  I had five tables to open, so I had to make sure one was done before the next started and then had to make sure all were open before I did anything with the XML.
                The other key I noticed was that I had to force flags to indicate a handler was done. If I had a flag at the end of a handler, it might not be picked up in the Exit Frame. I actually had to turn the flag off before I ran the handler.
                If anyone needs more info or would like to provide more info, please feel free.
                I am still having trouble in another piece of the program with asynchronous flow. I'm not sure how to force it to flow synchronously (and I'm not sure I understand why I have to).
