2 Replies Latest reply on Jul 19, 2011 1:36 PM by MCLMasterKey
    Remove Extended Features with JavaScript?
    MCLMasterKey Level 1
      A LITTLE HISTORY:
      At first I was manually trying to crop a PDF using the Document > Crop Pages option in Acrobat Pro.
      However, it told me that I could not crop the document because the document "restricts some features to allow for extended features in Acrobat Reader" and that I should Save a Copy in order to remove the restrcitions and be able to crop the document.
      That was fine and that did indeed work by saving a copy. And, I was then able to crop the document.
      However, now I have been given hundreds of these documents to crop and they all have this "extended features" thing enabled on them.
      I was going to write a JavaScript batch command to crop the files (which I have done for previous projects) but it wouldn't work (I assume because of the extended features).
      Then I tried writing a javaScript to saveAs all the documents with the asCopy option set to true.
      That did not seem to work either because when I then tried to crop one of the saveAs files, I got the same "extended features" error.
      QUESTION:
      Does anyone know how I can programmatically get around this problem? Can I disable "extended features" via JavaScript? Can I do some sort of save or exprto or something that will strip it out? Am I simply doing something wrong? Or, is it just not possible?
      Any assistance is greatly appreciated!
      Mark
        • 1. Re: Remove Extended Features with JavaScript?
          I'm not sure the error you got is becaues of the extended rights. Could you post your code, as well as the exact error message?
          • 2. Re: Remove Extended Features with JavaScript?
            I haven't even gotten to the code part yet.
            Here is a word-for-word transcription of the error message:
            This document restricts some Acrobat features to allow for extended features in Acrobat Reader. To create a copy of the document that is not restricted (and has no extended features in Adobe Reader), click Save a Copy.
            This is an Adobe Acrobat dialog where I have a Save a Copy button and a Cancel button.
            This warning message appears when I manually try to crop the document by using the Document -> Crop Pages option from Adobe Acrobat.
            As I was originally asking:
            Does anyone know how I can programmatically get around this problem via JavaScript? Can  I disable "extended features" via JavaScript? Can I do some sort of  save or export or something that will strip it out?
            I have 320 documents I need to crop. I really don't want to have to manually Save a Copy for each document.
            Thank you very much!
