4 Replies Latest reply on Jul 21, 2011 1:12 AM by jbx028
    How to remove an ink signature with Javascript
    jbx028 Level 1
      Hello,
      I created a form with the capability to sign it with an "ink signature".
      I would like to add a button on top of my form to remove any ink signature. It's possible to remove them with a right click and delete, but because we will use the form with a tablet it's better to have a button that will remove them automatically.
      I tried a lot of things in javascript but without success. Any ideas ?
      Thanks in advance for your help
        • 1. Re: How to remove an ink signature with Javascript
          SForrest96 Level 4
          As you may or may not know, an "Ink" signature is simply an annotation (pencil tool) used to represent a hand written signature.  You can Acrobat Javascript to delet annotations.  I added the following JavaScript to a button on a PDF to "delete" the annotation.
          var annots = this.getAnnots({ nPage:0 });
          for (var i = 0; i < annots.length; i++)
                  if (annots[i].type == "Ink")
                         annots[i].destroy();
          I also attached the sample form.
          Hope this helps.
          Steve
          • 2. Re: How to remove an ink signature with Javascript
            jbx028 Level 1
            Hello,
            Thanks for your quick reply.
            I tried your piece of code but i got the following error message :
            "this.getAnnots is not a function"
            It is consistent with what i can see in livecycle. I do not see this method in the list of possible properties/methods assigned to "this".
            I read the documentation and saw that this method is assigned to the object "doc". I tried to replace "this" by "doc" and then app.doc (i saw an example in internet) but unfortunately the syntax is not recognised (error message : doc is not defined).
            Johnny
            • 3. Re: How to remove an ink signature with Javascript
              jbx028 Level 1
              I did some progress
              I do not have any errors anymore with the following syntax : var annots = event.target.getAnnots({nPage:1});  --> (event.target instead of doc)
              but i got the message "annots has no properties" now. FYI i have the same error message with your form in attachement.
              In designer, i do not see any properties/methods after event.target.
              Something else i have to declare somewhere ?
              Johnny
              • 4. Re: How to remove an ink signature with Javascript
                jbx028 Level 1
                Finally it is ok. The error i mentionned above is triggered when there is no signature.
                I just added a test. The final code is :
                var annots = event.target.getAnnots({nPage:0});
                if (annots != null) {
                     for (var i=0; i < annots.length; i++) {
                          if (annots[i].type == "Ink") { annots[i].destroy(); }
                Thanks a lot for your help.
                Regards,
                Johnny
