3 Replies Latest reply on Jun 19, 2007 8:41 AM by spotsstang
    Help with xmlsearch
    spotsstang
      I have been trying to get this final step completed for my application and just cannot seem to get a answer. I need to retriev a value from a xml post.
      I am using xmlsearch to find the result:
      <cfset customer.firstname = xmlsearch(xmlcustomer, "name[@part='first']")>
      <cfset customer.lastname = xmlsearch(xmlcustomer, "name[@part='last']")>
      I am getting returned:
      <?xml version="1.0" encoding="UTF-8"?> <name part="first">MyFirstName</name>
      <?xml version="1.0" encoding="UTF-8"?> <name part="last">MyLastName</name>
      I obviously want just the first and last names but cannot seem to figure out how to get them out. Any help would be greatly appreciated.
        • 1. Re: Help with xmlsearch
          insuractive Level 3
          xmlSearch() returns an XML node, which is a complex data type (think structure). Once you retrieve your XML node, you then have to parse out the data you want (do a <cfdump> on your xmlsearch() results to see what I mean).
          The solution is pretty simple:
          <cfset xmlNode= xmlsearch(xmlcustomer, "name[@part='first']")>
          <cfset customer.firstname = xmlNode.xmlText>
          • 2. Re: Help with xmlsearch
            sanaullah
            Hi spotsstang,
            Here is a simple example, I want to search a employee with id of 23
            <employee id="23">
            <firstname>John</firstname>
            <lastname>Smith</lastname>
            </employee>
            <cfset mydump = xmlSearch(myXml,'/employee [@id='23']/*') >
            <cfdump var="#mydump #">
            see the dump value, it will show you the returned structure.
            hopefully this will help you in understanding of xmlsearch.
            • 3. Re: Help with xmlsearch
              spotsstang Level 1
              Thanks for the replies. I was able to work through it in the mean time and here is the way that I resolved it:
              <cfset fName = xmlsearch(xmlcustomer, "name[@part='first']")>
              <cfset xmlFName = xmlparse(fName[1][1], "yes")>
              <cfset customer.firstname = xmlFName["name"]["XmlText"]>
              <cfset lName = xmlsearch(xmlcustomer, "name[@part='last']")>
              <cfset xmlLName = xmlparse(lName[1][1], "yes")>
              <cfset customer.lastname = xmlLName["name"]["XmlText"]>
