5 Replies Latest reply on Oct 16, 2013 2:24 AM by Fara10
    Failed to open pdf error on every document
    jkinsman Level 1
      Today I came and started placing pdf documents in Indesign CS3 like I always do, and suddenly I start getting "failed to open pdf" errors on every pdf file I try and place. I have tried all the suggested tactics of selecting show import options, changing the crop to bounding box, etc. Nothing working.
      I also tried to open the pdf in acrobat and export into a different format or optimize it using the pdf optimizer, but when I do that I get gobbly **** text on the pdf. See screenshots
      Screen shot 2011-07-19 at 9.19.39 AM.png Screen shot 2011-07-19 at 9.19.27 AM.png
      The only workaround that works is to save as a raster image. But this is incredibly time consuming. I also tried importing these same files into Indesign cs 4 and I get the same errors. I am wondering if this is a system wide issue. Any ideas or suggestions?
      I noticed all these pdf were created using cs4 and above. Not sure if this helps.
