1 Reply Latest reply on Jul 20, 2011 6:02 AM by jfb00
    Default sort AdvancedDataGrid
    GabrielGPP
      You can sort a column in an AdvancedDataGrid Flex 4 from a button instead of clicking on the header?
        • 1. Re: Default sort AdvancedDataGrid
          jfb00 Level 3
          Yes you can do that. Just turn off the sort in the datagrid with sortableColumns="false"
          From you click button method call a function that will do the sort you array collection for you like:
          private function mySort():void{
                          //New Sort
                          var sort:Sort = new Sort();
                          sort.fields = [new SortField("Field01",true),
                              new SortField("Field02",true),
                              new SortField("Field03",true)];
                          sort.fields[2].numeric = true; //where Field03 is date
                          acOfADG.sort = sort; //where acOfADG is the array collection of the advance datagrid
                          acOfADG.refresh();
          I hope this help.
          Best
          JFB
