1 Reply Latest reply on Jul 20, 2011 4:26 AM by Colin Brougham
    Key Frame animation floating/swinging, happening on motion/position key frames
    pur3forlyphe Level 1
      Hi there,
      I keep noticing this type of floating effect on only certain key frame animations i create,
      it's wierd, if i key frame the postion of a picture it will add a swing effect, i.e. it goes from 1 point to the other with increasing then decreasing the x co-ordinates
      The position X point is set to 720, the next point is also 720, but for some reason it decides to go down to 601 in between the 2 key frames,
      No keyframe interpolation style is given, had a simular issue in after effects with interpolation styles
      Help!
