7 Replies Latest reply on Jul 20, 2011 8:43 AM by yyterrwihbgd
    Problem with socket responses with flex
    yyterrwihbgd Level 1
      Hi, I am using the code below to connect to an IMAP server.
      When I telnet to the server and use the commands that I am sending in the code, the rsponses are correct.
      However, when I run the code below, I only obtain the ready and logged in responses as shown below.
      Any ideas why I am not receiving the full set of responses from the socket?
      Thanks in advance fro your advice.
      The following is the output from the code:
      +++++++++++++++++ START SENDING IMAP DATA +++++++++++++++++++++++++
      sent: . login user1 myPassword
      sent: . status INBOX (messages)
      sent: . select INBOX
      +++++++++++++++++ END SENDING IMAP DATA +++++++++++++++++++++++++
      ++++++++ [IMAP START]
      Response is: * OK Dovecot ready.
      [IMAP END] +++++++++
      Response is: . OK Logged in.
      The code is:
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
         xmlns:mx="library://ns.adobe.com/flex/mx"
         applicationComplete="init()">
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      public var dataStr:String;
      private var socket:Socket;
      private var serverURL:String= "dead.org";
      private var serverPort:int = 143;
      private var serverResponse:ByteArray = new ByteArray();
      private function init():void
        this.serverURL = serverURL;
        this.serverPort = serverPort;
        socket = new Socket();
        socket.addEventListener(ProgressEvent.SOCKET_DATA,handleNewIMAPData); //Event when socket receives new data
        this.connectToServer();
        sendIMAPdata();
      private function sendString(dataStr:String):void
        var bytes:ByteArray = new ByteArray();
        bytes.writeMultiByte(dataStr, "UTF-8");
        socket.writeBytes(bytes);
        socket.flush();
        trace("sent: " + dataStr);
      public function sendIMAPdata():void
        trace("\t +++++++++++++++++ START SENDING IMAP DATA +++++++++++++++++++++++++");
        dataStr =". login user1 myPassword" + "\r\n";
        sendString(dataStr);
        dataStr =". status INBOX (messages)" + "\r\n";
        dataStr =". select INBOX" + "\r\n";
        trace("\t +++++++++++++++++ END SENDING IMAP DATA +++++++++++++++++++++++++");
      private function handleNewIMAPData(event:ProgressEvent):void
        var numBytes:int = socket.bytesAvailable;
        serverResponse = new ByteArray();
        while(socket.bytesAvailable)
          var byte:int = socket.readUnsignedByte();
      serverResponse.writeByte(byte);
        var response:String = serverResponse.toString();
        trace(" ++++++++ [IMAP START]\n Response is: " + response + "[IMAP END] +++++++++\n");
      private function connectToServer():void
        socket.connect(serverURL, serverPort);
      </fx:Script>
      </s:WindowedApplication>
