2 Replies Latest reply on Jul 20, 2011 10:05 AM by Flex harUI
    Module Manger
    _spoboyle Level 4
      I am trying to load a module using ModuleManager (the module is a spark module)
      var moduleInfo:IModuleInfo = ModuleManager.getModule("module.swf");
      moduleInfo.addEventListener(ModuleEvent.READY, moduleLoaded);
      moduleInfo.addEventListener(ModuleEvent.ERROR, error);
      moduleInfo.addEventListener(ModuleEvent.PROGRESS, progress);
      moduleInfo.addEventListener(ModuleEvent.SETUP, setup);
      moduleInfo.addEventListener(ModuleEvent.UNLOAD, unload);
      moduleInfo.load(null, null, null, moduleFactory);
      private function error(event:ModuleEvent):void
           trace("error: " + event);
      private function moduleLoaded(event:ModuleEvent):void
           trace("module loaded");
      I do not recieve any events
        • 1. Re: Module Manger
          _spoboyle Level 4
          I found the problem for some reason moduleInfo cannot be declared as a local variable. If you do it seems that it gets destroyed and therefore no events.
          really quite annoying since i don't need a member variable for this
          private var moduleInfo:IModuleInfo;
          private function init():void
               moduleInfo = ModuleManager.getModule("modules/ContactModule.swf");
               moduleInfo.load();
          • 2. Re: Module Manger
            Flex harUI Adobe Employee
            That's been discussed before.  You need a strong reference to the
            module/moduleinfo otherwise it will get garbage-collected
