0 Replies Latest reply on Jul 20, 2011 10:45 AM by jp2010*
    Inserting column in Table.  Should I be using subforms?
    jp2010*
      Hi -
      Attached is a document I have been working on with many tables throughout the form.  I need to add an additional column added to almost all of the tables.
      I have tried to use the insert column function, but I can't get it to work.  I shrank up the tables to see if I needed more space, but it still didn't work.  I have started to read a little about using
      subforms with the tables, but I am not sure where to start.  Is this the right path to go down or is there an easier way to insert columns.  If I should use subforms, is there an efficient way to change the tables to subforms?  Throughout the form there are rows that can be repeated or deleted.  I hope that I can keep this working in the same manner if possible without a lot of re-work.
      Any help would be greatly appreciated.
