23 Replies Latest reply on Jul 21, 2011 10:07 AM by Amy Blankenship
    Create a circle class
    chriswillis100 Level 1
      Hey guys,
      I'm trying to do something very simple which isnt working
      I've got a custom class that creates a circle:
      package create
      import flash.display.Shape
      public class circle
      public function circle()
      var circle:Shape = new Shape();
      circle.graphics.lineStyle(5, 0, 1);
      circle.graphics.drawCircle(50,50,20);
      And i have a main mxml file that has a button that when pushed should run the code in the custom class's costructor and add the circle to the stage:
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
         xmlns:mx="library://ns.adobe.com/flex/mx">
      <fx:Script>
      <![CDATA[
      import creat.circle
      protected function createCircle_clickHandler(event:MouseEvent):void
      </fx:Script>
      <s:Button id="createCircle" x="27" y="122" width="35" label="Button"
        click="createCircle_clickHandler(event)"/>
      </s:WindowedApplication>
      What code would have to go in the createCircle function to make it work? I've tried creat.circle(); and it's given me the error that says i need 1 argument in the () part. Which is confusing
      Anyone help?
      Chris
        • 1. Re: Create a circle class
          ShardulSingh Level 3
          Create your  circle class as below:-
          Circle Class:-
          package
              import flash.display.Sprite;
              import mx.core.UIComponent;
              public class Circle extends UIComponent
                  public function Circle()
                      var circle:Sprite = new Sprite();
                      this.addChild(circle);
          And Use it in your Application as below:
          YourApplication:-
              <fx:Script>
                  <![CDATA[
                      protected function btnHandler(event:MouseEvent):void
                          var circle : Circle = new Circle();
                          circleConatiner.addChild(circle);
              </fx:Script>
              <fx:Declarations>
                  <!-- Place non-visual elements (e.g., services, value objects) here -->
              </fx:Declarations>
              <mx:VBox>
              <mx:Box id="circleConatiner" width="150" height="150" backgroundColor="0xCCCCCC"/>
              <s:Button id="btn" label="Create Circle" click="btnHandler(event)"/>
              </mx:VBox>
          with Regards,
          Shardul
          • 2. Re: Create a circle class
            Amy Blankenship Level 4
            That's a good solution, along the lines of the question.  But I wonder if maybe just using the Ellipse primitive might not work better? Check out http://help.adobe.com/en_US/flex/using/WSda78ed3a750d6b8fee1b36612357de97a3-8000.html for MXML usage.
            You could also use it in AS like so:
            var circle:Ellipse = new Ellipse();
            circle.width = 50;
            circle.height = 50;
            circle.stroke = new SolidColorStroke(0, 5, 1);
            myGroup.addElement(circle);//myGroup defined elsewhere, perhaps in MXML
            Note that Spark WindowedApplication implements IVisualElementContainer, so it has an addElement method that works the same way as Group's does.
            You can change the width of an Ellipse at runtime.
            HTH;
            Amy
            • 3. Re: Create a circle class
              Thats brilliant!
              Thank you for you help
              • 4. Re: Create a circle class
                Ok i've got this:
                package create
                import mx.graphics.SolidColorStroke;
                import spark.primitives.Ellipse;
                public class circle extends UIComponent
                circle.x = 0
                circle.y = 0
                circle.width = 50;
                circle.height = 50;
                circle.stroke = new SolidColorStroke(0x00FF00, 5, 1)
                and this is my main.mxml
                <fx:Script>
                <![CDATA[
                import create.circle;
                var circle1:circle = new circle();
                circleConatiner.addChild(circle1);
                </fx:Script>
                <fx:Declarations>
                </fx:Declarations>
                <mx:VBox>
                </mx:VBox>
                But nothing is happening when i click the button
                • 5. Re: Create a circle class
                  Probably the easiest thing is to just make circleContainer look like this:
                  <s:BorderContainer backgroundColor="#CCCCCC" borderVisible="false" id="circleContainer">
                       <s:Ellipse width="50" height="50">
                            <s:stroke>
                                 <s:SolidColorStroke color="0" weight="5" />
                            </s:stroke>
                       </s:Ellipse>
                  </s:BorderContainer>
                  However, if you want to make it a separate Class, try this:
                  public Class Circle extends Ellipse {
                       public function Circle() {
                            stroke = new SolidColor(5, 0, 1);
                  Then you can either add it to the MXML similar to above, or you can use addElement to add it to an IVisualElementContainer (which Box is not).
                  HTH;
                  Amy
                  • 6. Re: Create a circle class
                    As my class i've got this:
                    circle.x = 0
                    circle.y = 0
                    circle.width = 50;
                    circle.height = 50;
                    addElement(circle);
                    and it's saying that addElement is a possibly undefined method
                    And i've got this in my Main.mxml file:
                    circleConatiner.addChild(circle1);   //<mx:Box> container
                    And it's saying Implicit coercion of a value of type create:circle to an unrelated type flash.display:DisplayObject
                    • 7. Re: Create a circle class
                      If i put this code into the Main.mxml file it works perfectly:
                      var circle1:Ellipse = new Ellipse();
                      circle1.x = 50
                      circle1.y = 50
                      circle1.width = 50;
                      circle1.height = 50;
                      circle1.stroke = new SolidColorStroke(0x000000,5,1);
                      addElement(circle1);
                      But if i put it in the class file it says that addElement is possibly undefined
                      • 8. Re: Create a circle class
                        Rangora Level 3
                        The class would have to extend Ellipse. Then you just create a new Circle (your class) and call addElement(circle) in your view.
                        • 9. Re: Create a circle class
                          Chris;
                          I think you're kind of missing the "core" of what I am trying to tell you:
                          1. You're not going to be able to add an Ellipse to a mx container, because Ellipse is too low level.  You need to use a Spark container as the parent.
                          2. Please consider just using the mxml syntax I gave you.  You don't really need a circle Class, because there is already an Ellipse class you can just use.
                          3. If you absolutely have to have a circle Class (which suggests this is a school assignment and not a real problem), it should extend a Class that can be added to the parent container.  If you must use box for some reason, you're better off going with the UIComponent/shape solution. Or you need to return something from your function (note that none of your functions ever has a return) that the calling Class can then use to add to some part of itself.
                          4. The Circle will never be able to add itself to anything, because it lacks any knowledge of what to add to and any methods that would allow it to do any adding.  The calling Class will need to handle that.
                          Good luck!
                          • 10. Re: Create a circle class
                            Ok, but using the mxml syntax wont allow me to create lots of instances of the circle.
                            Basically what i'm working towards is a tool that allows you to create a circle by clicking and dragging it (like in MS Paint), and do it multiple times. Am i going down the right route for this?
                            I thought I needed a class to make multiple instances of a circle
                            I'm not very experienced in as3/mxml, but i really do appreciate your help
                            • 11. Re: Create a circle class
                              Yes, and that Class already exists, so there is no reason for you to write it.  It's called Ellipse.
                              Try something like this (in your MXML file):
                              protected static const stroke:IStroke = new SolidColorStroke(0, 5, 1);
                              protected function createCircle(e:MouseEvent):void {
                                   var newEllipse:Ellipse = new Ellipse();
                                   newEllipse.stroke = stroke;
                                   newEllipse.x = e.localX;
                                   newEllipse.y = e.localY;
                                   newEllipse.width = newEllips.height = 50;
                                   someSparkContainer.addElement(newEllipse);
                              Note that you CANNOT use this code to add an ellipse to an MX container.  It HAS to be a Spark container (such as BorderContainer).
                              HTH;
                              Amy
                              • 12. Re: Create a circle class
                                Oh i see, sorry about all the confusion
                                Just one more thing:
                                Is there a way of getting the coordinates of the mouse when the events MOUSE_DOWN and MOUSE_UP have been fired?
                                I need them to do this draggable resizeable circle
                                Many Thanks
                                Chris
                                • 13. Re: Create a circle class
                                  There's another problem:
                                  I've got three functions - mouseDown (defines and adds the circle),  mouseMove (drags the circle to the right size) , mouseUp (sets the circle at that size)
                                  To make multiple instances of the circle the variable has to be defined in the mouseDown function, but then the mouseMove and mouseUp instances can't use it.
                                  I also need to know how to get coordinates when the mouseDown and mouseUP is fired, because to set the size of the circle i do mouseUpCoordinates - mouseDownCoordinates
                                  Using variables wouldn't work because of the multiple instances of the circle, i think
                                  Chris
                                  • 14. Re: Create a circle class
                                    Rangora Level 3
                                    vars can work since you edit the circles 1 by 1
                                    • 15. Re: Create a circle class
                                      I dont understand what you mean
                                      Is this the best way of creating circles that drag to the right size?
                                      • 16. Re: Create a circle class
                                        You might find it useful to search the docs for MouseEvent for examples of how to use this object.
                                        • 17. Re: Create a circle class
                                          I have, and all ive got is event.localX/event.localY
                                          This is getting really confusing :/
                                          • 18. Re: Create a circle class
                                            Basically whats the easiest way to make a circle that onMouseDown creates the circle (a really small one), onMouseMove resizes it and onMouseUp sets the size?
                                            I feel like i'm making it a lot more difficult than it needs to be
                                            Thanks for all your help though
                                            Chris
                                            • 19. Re: Create a circle class
                                              Rangora Level 3
                                              Those examples might help you. It's not exactly what you need, but it draw using mouseEvents so...
                                              http://www.jamesward.com/2010/03/22/flex-paint-updated-to-flex-4/ (simpler example)
                                              http://flexaired.blogspot.com/2008/08/simple-drawing-tool-in-flex.html
                                              What I tried to explain to you is that since you only create 1 circle at the time, you could use vars to keep a reference on this circle and the x,y. When you press the mouse button, you just create a new circle and replace the old one in the var...
                                              • 20. Re: Create a circle class
                                                Ok, i've sorted the mouse coordinates.
                                                But i'm back to the other problem where if i declare the Ellipse outside the mouseDown everytime i create a new circle the one i created before dissappears, but if it inside the mouseDown, no other function (mouseMove, mouseUp) can use it, which creates errors
                                                Sorry if i've misunderstood anything
                                                • 21. Re: Create a circle class
                                                  Rangora Level 3
                                                  I hope you will learn by STUDYING this code to understand what it does... If it's what you need, I want my correct answer (already gave it... my helpful)
                                                  <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                          xmlns:s="library://ns.adobe.com/flex/spark" title="DrawingView">
                                                      <fx:Script>
                                                          <![CDATA[
                                                              import mx.events.FlexEvent;
                                                              import mx.graphics.IStroke;
                                                              private var currentCircle:Ellipse;
                                                              private var x1:int;
                                                              private var y1:int;
                                                              private var isDrawing:Boolean = false;
        newEllipse.x = e.localX -25;
        newEllipse.y = e.localY -25;
        newEllipse.width = newEllipse.height = 50;
        currentCircle = newEllipse;
                                                              protected function resizeCircle(newSize:Number):void
        currentCircle.x = x1 -newSize/2; //reposition the circle. The center won't move this way.
        currentCircle.y = y1 -newSize/2;
        currentCircle.width = currentCircle.height = newSize;
                                                              protected function view1_mouseDownHandler(event:MouseEvent):void
        createCircle(event);
        draw.addElement(currentCircle);
        isDrawing = true;
        x1 = event.localX;
        y1 = event.localY;
                                                              protected function view1_mouseUpHandler(event:MouseEvent):void
        isDrawing = false;
                                                              protected function view1_mouseMoveHandler(event:MouseEvent):void
        if (isDrawing)
        var radius:Number = Math.sqrt((event.localX -x1)*(event.localX -x1) + (event.localY - y1)*(event.localY - y1));
        resizeCircle(radius*2); //radius is half way to mouse coordinates
                                                      </fx:Script>
                                                      <fx:Declarations>
                                                      </fx:Declarations>
                                                      <s:Group id="draw" left="0" right="0" top="0" bottom="0" mouseDown="view1_mouseDownHandler(event)"
                                                               mouseMove="view1_mouseMoveHandler(event)" mouseUp="view1_mouseUpHandler(event)"/>
                                                  </s:View>
                                                  • 22. Re: Create a circle class
                                                    You'll want to create two variables
                                                    1. circles (an Array of Circles)
                                                    2. currentCircle (the most recently created circle).
                                                    Add the circle to the array in mouse down but store a reference to it in currentCircle, then manipulate currentCircle in the other handlers.
                                                    For example
                                                    protected var circles:Array = new Array();
                                                    protected var currentCircle:Ellipse;
                                                         currentCircle = new Ellipse();
                                                         //size, position, and add the circle
                                                         circles.push(currentCircle);
                                                    protected function resizeCircle(e:MouseEvent):void {
                                                         var dx:int = e.localX - currentCircle.x;
                                                         var dy:int = e.localY - currentCircle.y;
                                                         currentCircle.width = dx;
                                                         currentCircle.height = dy;
                                                    HTH;
                                                    Amy
                                                    • 23. Re: Create a circle class
                                                      Thank you so much, sorry that it took so long for me to get
                                                      You've been really helpful
