2 Replies Latest reply on Sep 19, 2011 7:50 AM by PegasusT4
    Multiple Error Messages CFB2 after hotfix installation
    PegasusT4 Level 1
      I just installed the CFB2 Hotfix on Windows 7 pro 64 AND 32bit machines and now get a ton of startup errors in the error log. I have no idea what is causing this. Here is a small part of the error log. I have tried starting with the -clean option and still get the errors. It's approx. 900 lines of messages.
      Any way to remove the cause of these?
      Doug
      !ENTRY org.eclipse.equinox.preferences 4 4 2011-07-20 14:01:23.928
      !MESSAGE Exception loading preferences from: .
      !STACK 0
      org.osgi.service.prefs.BackingStoreException: Unable to determine provisioning agent from location: file:\2fC:\2fUsers\2fDoug\2fAppData\2fLocal\2fTemp\2fI1306347801\2fWindows\2fp2\2f
          at org.eclipse.equinox.internal.p2.engine.ProfilePreferences.getAgent(ProfilePreferences.jav a:159)
          at org.eclipse.equinox.internal.p2.engine.ProfilePreferences.load(ProfilePreferences.java:24 0)
          at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:3 07)
          at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences. java:543)
          at org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:669 )
          at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences. java:549)
          at org.eclipse.core.internal.preferences.RootPreferences.getNode(RootPreferences.java:106)
          at org.eclipse.core.internal.preferences.RootPreferences.node(RootPreferences.java:85)
          at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.getPreferenc es(AbstractRepositoryManager.java:499)
          at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.remember(Abs tractRepositoryManager.java:857)
          at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.stop(Abstrac tRepositoryManager.java:1052)
          at org.eclipse.equinox.internal.p2.core.ProvisioningAgent.unregisterService(ProvisioningAgen t.java:121)
          .................... cut .................
      !SESSION 2011-07-20 14:01:34.716 -----------------------------------------------
      eclipse.buildId=unknown
      java.version=1.6.0_24
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
      Command-line arguments:  -os win32 -ws win32 -arch x86 -clean
      !ENTRY org.eclipse.equinox.p2.engine 4 4 2011-07-20 14:01:37.799
      !MESSAGE An error occurred while installing the items
      !SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2011-07-20 14:01:37.799
      !MESSAGE session context was:(profile=profile, phase=org.eclipse.equinox.internal.p2.engine.phases.Install, operand=null --> [R]com.adobe.ide.coldfusion.search 2.0.0.277745, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.InstallBundleAction).
      !SUBENTRY 1 org.eclipse.equinox.p2.touchpoint.eclipse 4 0 2011-07-20 14:01:37.799
      !MESSAGE The artifact file for osgi.bundle,com.adobe.ide.coldfusion.search,2.0.0.277745 was not found.
      ...... more .....
      !ENTRY org.eclipse.update.configurator 4 0 2011-07-20 14:01:38.686
      !MESSAGE Could not install bundle plugins/org.sat4j.pb_2.2.0.v20100429.jar   Bundle "org.sat4j.pb" version "2.2.0.v20100429" has already been installed from: reference:file:plugins/org.sat4j.pb_2.2.0.v20100429.jar
      !ENTRY org.eclipse.update.configurator 4 0 2011-07-20 14:01:38.687
      !MESSAGE Could not install bundle plugins/org.scriptaculous.1.8_1.8.0.00001.jar   Bundle "org.scriptaculous.1.8" version "1.8.0.00001" has already been installed from: reference:file:plugins/org.scriptaculous.1.8_1.8.0.00001.jar
      !ENTRY Extensions 1 0 2011-07-20 14:01:42.481
      !MESSAGE Dangling meta character '*' near index 0
        • 1. Re: Multiple Error Messages CFB2 after hotfix installation
          krishnapreddy_adobe
          Can you please close the builder if running and
          rename the directory
          <USER_Home>/Adobe ColdFusion Builder 2.0 Configuration/
          to
          <USER_Home>/Adobe ColdFusion Builder 2.0 Configuration_XX/
          (Or any another name is also OK)
          and try launching the builder.
          This should heal any plugin versions cached data and fix the issue.
          • 2. Re: Multiple Error Messages CFB2 after hotfix installation
            PegasusT4 Level 1
            I just tried that on my 64-bit machine and get the following in my error.log. Note on the keybinding, I have NOT added or changed any keybindings, so don't know where that's coming from.
            !SESSION 2011-09-15 14:03:47.654 -----------------------------------------------
            !ENTRY org.eclipse.jface 2 0 2011-09-15 14:05:08.069
            !MESSAGE Keybinding conflicts occurred.  They may interfere with normal accelerator operation.
            !SUBENTRY 1 org.eclipse.jface 2 0 2011-09-15 14:05:08.069
            !MESSAGE A conflict occurred for ALT+CTRL+R:
            Binding(ALT+CTRL+R,
                ParameterizedCommand(Command(com.adobe.ide.coldfusion.shortcut.cfscript,Insert cfscript block,
                    Category(com.adobe.ide.coldfusion.commands,CFML Editor,null,true),
                    com.adobe.ide.coldfusion.shortcut.handlers.CFScriptHandler,
                    ,,true),null),
                cfscheme,
                com.adobe.ide.editor.cfml.context,,,user)
            Binding(ALT+CTRL+R,
                    ,,true),null),
                cfscheme,
                com.adobe.snippet.context,,,user)
            !ENTRY org.eclipse.osgi 2 1 2011-09-15 14:06:56.414
            !MESSAGE NLS unused message: CFMLKeysPreferencePage.0 in: com.adobe.ide.coldfusion.keyboard.preferences.messages
            !ENTRY org.eclipse.osgi 2 1 2011-09-15 14:06:56.415
            !MESSAGE NLS unused message: CFMLKeysPreferencePage.1 in: com.adobe.ide.coldfusion.keyboard.preferences.messages
            !ENTRY org.eclipse.osgi 2 1 2011-09-15 14:06:56.416
            !MESSAGE NLS unused message: CFMLKeysPreferencePage.4 in: com.adobe.ide.coldfusion.keyboard.preferences.messages
            !SESSION 2011-09-15 14:08:36.899 -----------------------------------------------
            !ENTRY org.eclipse.jface 2 0 2011-09-15 14:08:41.807
            !SUBENTRY 1 org.eclipse.jface 2 0 2011-09-15 14:08:41.807
            Binding(ALT+CTRL+R,
                    ,,true),null),
                cfscheme,
            Binding(ALT+CTRL+R,
                    ,,true),null),
                cfscheme,
            !SESSION 2011-09-16 13:43:24.117 -----------------------------------------------
            !ENTRY org.eclipse.jface 2 0 2011-09-16 13:43:31.062
            !SUBENTRY 1 org.eclipse.jface 2 0 2011-09-16 13:43:31.062
            Binding(ALT+CTRL+R,
                    ,,true),null),
                cfscheme,
            Binding(ALT+CTRL+R,
                    ,,true),null),
                cfscheme,
            !SESSION 2011-09-19 10:18:43.271 -----------------------------------------------
            !ENTRY org.eclipse.equinox.p2.engine 4 4 2011-09-19 10:18:55.798
            !MESSAGE An error occurred while committing the engine session for profile: profile.
            !SUBENTRY 1 org.eclipse.equinox.p2.touchpoint.eclipse 4 0 2011-09-19 10:18:55.798
            !MESSAGE
            !SUBENTRY 2 org.eclipse.equinox.p2.touchpoint.eclipse 4 0 2011-09-19 10:18:55.798
            !MESSAGE Error saving manipulator.
            !STACK 0
            java.lang.NullPointerException
                at org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxFwConfigFileParser.saveFwConfi g(EquinoxFwConfigFileParser.java:489)
                at org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxManipulatorImpl.save(EquinoxMa nipulatorImpl.java:407)
                at org.eclipse.equinox.internal.p2.touchpoint.eclipse.LazyManipulator.save(LazyManipulator.j ava:96)
                at org.eclipse.equinox.internal.p2.touchpoint.eclipse.EclipseTouchpoint.saveManipulator(Ecli pseTouchpoint.java:61)
                at org.eclipse.equinox.internal.p2.touchpoint.eclipse.EclipseTouchpoint.commit(EclipseTouchp oint.java:137)
                at org.eclipse.equinox.internal.p2.engine.EngineSession.commit(EngineSession.java:123)
                at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:91)
                at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
                at org.eclipse.equinox.internal.p2.reconciler.dropins.ProfileSynchronizer.executePlan(Profil eSynchronizer.java:720)
                at org.eclipse.equinox.internal.p2.reconciler.dropins.ProfileSynchronizer.performAddRemove(P rofileSynchronizer.java:173)
                at org.eclipse.equinox.internal.p2.reconciler.dropins.ProfileSynchronizer.synchronize(Profil eSynchronizer.java:128)
                at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.synchronize(Activator.java:4 19)
                at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start(Activator.java:176)
                at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:7 83)
                at java.security.AccessController.doPrivileged(Native Method)
                at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextIm pl.java:774)
                at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:7 55)
                at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
                at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:374)
                at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1067)
                at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManage r.java:561)
                at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManage r.java:546)
                at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java :459)
                at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelMana ger.java:243)
                at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManage r.java:440)
                at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
                at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
            !ENTRY org.eclipse.jface 2 0 2011-09-19 10:19:16.671
            !SUBENTRY 1 org.eclipse.jface 2 0 2011-09-19 10:19:16.671
            Binding(ALT+CTRL+R,
                    ,,true),null),
                cfscheme,
            Binding(ALT+CTRL+R,
                    ,,true),null),
                cfscheme,
            !ENTRY org.eclipse.ui 4 4 2011-09-19 10:20:08.432
            !MESSAGE Category com.adobe.model.editor.views not found for view com.adobe.rds.client.core.views.DatabaseView.  This view added to 'Other' category.
            !MESSAGE Category com.aptana.ide.documentation not found for view com.aptana.ide.documentation.jquery.visualjquery.  This view added to 'Other' category.
            !MESSAGE Category com.aptana.ide.documentation not found for view com.aptana.ide.documentation.libraryname.sampleview.  This view added to 'Other' category.
            !ENTRY org.eclipse.ui 4 4 2011-09-19 10:20:08.447
