4 Replies Latest reply on Jul 21, 2011 8:42 AM by Owen_Alextoys
    Go to next frame
    Owen_Alextoys Level 1
           I have a FLA that was originally created in indesign and I'm trying to get it to go to the next frame at a set interval. This is my first attempt at action script This is what I've come up with but it's not working. any help would be much apreciated
      stop();
      var myTimer:Timer = new Timer(5000);
      myTimer.addEventListener(TimerEvent.TIMER, fiveSec);
      myTimer.start();
      function fiveSec(event:TimerEvent):void
         this.nextFrame();
        • 1. Re: Go to next frame
          There's nothing wrong with the code.  Do you have enough frames in the timeline to go anywhere?  Try putting a trace in the function to see what it has to say about which frame you're in...
             this.nextFrame();
             trace(currentFrame);
          • 2. Re: Go to next frame
            I have three frames in the timeline.
            I got the following error when I tired to debug
            Scene 1, Layer 'Actions', Frame 1, Line 16 1021: Duplicate function definition.
            Here's the AS3 for that frame.
            /* Stop at This Frame
            The Flash timeline will stop/pause at the frame where you insert this code.
            Can also be used to stop/pause the timeline of movieclips.
            stop();
            myTimer.start();
               this.nextFrame();
               this.nextFrame();
            • 3. Re: Go to next frame
              You cannot have two functions with the same name.  You only needed to add the trace line to the existing function.
              • 4. Re: Go to next frame
                Perfect that fixed it. Thanks for the help. This is my first project with action script.
