• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Automation libraries do not work with upgrade license
New Here ,
Jul 20, 2011 Jul 20, 2011
Hi there,
Since we upgraded from Flex 3 to 4 (purchsing an upgrade premium license), when running the automation test it started to trigger a popup saying: "License not presetn.With the trial verison only limited replays are allowed.". I have tried compiling the project using Flex 4 SDK with either license number and still get the popup when running the test.
How do I get this to work? from the look of it, the compiler argument -license only supports one license number at the time.
Should this work?
-license=flexbuilder4,[license number]
Cheers,
Diego
TOPICS
Installation and activation
Views
984
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Hi Diego,
http://raniskumar.wordpress.com/2009/07/28/flex-builder-license-and-automation-flex-3/
The above blog post outlines various approaches to add license for Flex builder 3. To use Flash Builder 4 license, one should change flexbuilder3 keyword to flashbuilder4. Hope that helps.
Deeptika
Votes
Translate
Translate
Report
Report
New Here ,
Thanks Deeptika for your reply, but it doesn't seem to work.
I'm using the following macro to compile:
<macrodef name="compile.flex">
<attribute name="flexHome" default="${flex.home}"/>
<attribute name="backgroundColor" default="#FFFFFF"/>
<attribute name="incremental" default="true"/>
<attribute name="optimize" default="true"/>
<attribute name="strict" default="true"/>
<attribute name="targetPlayer"/>
<attribute name="useNetwork" default="true"/>
<attribute name="in"/>
<attribute name="out"/>
<attribute name="failonerror" default="true"/>
        <attribute name="static-link-runtime-shared-libraries" default="false"/>
        <attribute name="flex-licence" default="${flex.licence}"/>
    <attribute name="additional" default=""/>
<sequential>
            <property name="rsl.dir" value="@{flexHome}/frameworks/libs"/>
<java jar="@{flexHome}/lib/mxmlc.jar" fork="true" maxmemory="512m" failonerror="@{failonerror}" resultproperty="buildResultProperty">
<jvmarg line="-Xms32m -Xmx768m -Dsun.io.useCanonCaches=false"/>
<!-- Add metadata -->
<arg value="-title=${title}"/>
<arg value="-publisher=${publisher}"/>
<arg value="-creator=${creator}"/>
<arg value="-language=${language}"/>
<!-- Compiler arguments -->
                <arg value="-licenses.license flexbuilder4 @{flex-licence}"/>
<arg value="+flexlib=@{flexHome}/frameworks"/>
                <arg value="-source-path=@{flexHome}/frameworks/libs"/>
<arg value="-static-link-runtime-shared-libraries=@{static-link-runtime-shared-libraries}"/>
<arg value="-library-path+=${basedir}/libs"/>
<arg value="-default-background-color=@{backgroundColor}"/>
<arg value="-theme=@{flexHome}/frameworks/themes/Halo/halo.swc"/>
<arg value="-incremental=@{incremental}"/>
<arg value="-optimize=@{optimize}"/>
<arg value="-strict=@{strict}"/>
<arg value="-use-network=@{useNetwork}"/>
<arg value="-target-player=@{targetPlayer}"/>
<arg value="-output=@{out}"/>
<arg line="@{additional}"/>
<arg value="@{in}"/>
</java>
</sequential>
</macrodef>
This is the error I get:
[java] Adobe Flex Compiler (mxmlc)
     [java] Version 4.1.0 build 16076
     [java] Copyright (c) 2004-2009 Adobe Systems, Inc. All rights reserved.
     [java]
     [java] command line: Error: unknown configuration variable 'licenses.license flexbuilder4 xxxx-xxxx-xxxx-xxxx-xxxx-xxxx'
     [java]
     [java] Use 'mxmlc -help' for information about using the command line.
Thanks for your help
Votes
Translate
Translate
Report
Report
Adobe Employee ,
In this line, flexbuilder4 should be flashbuilder4. Please try this and let me know your findings.
Deeptika
Votes
Translate
Translate
Report
Report
New Here ,
good catch, thanks for that. However it doesnt seem to work
[java] command line: Error: unknown configuration variable 'licenses.license flashbuilder4 xxxx-xxxx-xxxx-xxxx-xxxx-xxxx'
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Jul 21, 2011 Jul 21, 2011
Hi Diego,
Was the same macro working earlier with Flex 3 SDK?
Deeptika
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
yes it was and I've never seen that popup before.
Votes
Translate
Translate
Report
Report
