0 Replies Latest reply on Jul 20, 2011 8:01 PM by iamalvin
    [Problem] Starting up ALC after adding RAM
    iamalvin
      We recently added the ram of our server from 4GB to 8GB, and the resource allocated to ALC was increased from 1GB to 4GB.
      It all goes well at first. However, one days after we added the RAM, the server was shutting down due to some unknow error and we needed to restart it.
      And once again, it was shutting down a few hours after it has been restarted.
      And at this time, we cannot restart the ALC again unless the original configuration has been set (i.e. using 1GB RAM).
      I am wounder if the setting cause any conflict or how should it be correctly configurated. Thanks.
      Run.bat
      Original
      rem JVM memory allocation pool parameters. Modify as appropriate.
      rem Set heap defaults based on 32bit/64bit JVM
      set JAVA_HEAP_ARGS=-XX:PermSize=128m -XX:MaxPermSize=192m -Xms1024m -Xmx1024m
      "%JAVA%" -version 2>&1 | findstr /I 64-Bit > nul
      if not errorlevel == 1 (set JAVA_HEAP_ARGS=-XX:PermSize=256m -XX:MaxPermSize=384m -Xms1024m -Xmx2048m)
      set JAVA_OPTS=%JAVA_OPTS% %JAVA_HEAP_ARGS%
      Edited for 4GB RAM
      if not errorlevel == 1 (set JAVA_HEAP_ARGS=-XX:PermSize=256m -XX:MaxPermSize=384m -Xms4096m -Xmx4096m)
      Sever Log
      2011-07-21 10:17:06,960 INFO  [com.arjuna.ats.jbossatx.jta.TransactionManagerService] JBossTS Transaction Service (JTA version) - JBoss Inc.
      2011-07-21 10:17:06,960 INFO  [com.arjuna.ats.jbossatx.jta.TransactionManagerService] Setting up property manager MBean and JMX layer
      2011-07-21 10:17:07,367 INFO  [com.arjuna.ats.jbossatx.jta.TransactionManagerService] Starting recovery manager
      2011-07-21 10:17:07,757 INFO  [com.arjuna.ats.jbossatx.jta.TransactionManagerService] Recovery manager started
      2011-07-21 10:17:07,773 INFO  [com.arjuna.ats.jbossatx.jta.TransactionManagerService] Binding TransactionManager JNDI Reference
      2011-07-21 10:17:15,226 INFO  [org.jboss.ejb3.EJB3Deployer] Starting java:comp multiplexer
      2011-07-21 10:17:19,789 INFO  [org.jboss.ws.core.server.ServiceEndpointManager] jbossws-1.2.1.GA (build=200704151756)
      2011-07-21 10:17:21,258 INFO  [org.jboss.jmx.adaptor.snmp.agent.SnmpAgentService] SNMP agent going active
      2011-07-21 10:17:23,571 INFO  [org.jboss.iiop.CorbaNamingService] Naming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
      2011-07-21 10:17:23,664 WARN  [com.arjuna.ats.jta.logging.loggerI18N] [com.arjuna.ats.internal.jta.transaction.arjunacore.lastResource.startupWarning] [com.arjuna.ats.internal.jta.transaction.arjunacore.lastResource.startupWarning] You have chosen to enable multiple last resources in the transaction manager. This is transactionally unsafe and should not be relied upon.
      2011-07-21 10:17:23,930 INFO  [org.jboss.tm.iiop.CorbaTransactionService] TransactionFactory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
      2011-07-21 10:17:25,649 INFO  [org.apache.catalina.core.AprLifecycleListener] The Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: d:\Adobe\Adobe LiveCycle ES2\Java\jdk1.6.0_14\bin;.;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;D:\syba se\DataAccess\ADONET\dll;D:\sybase\DataAccess\OLEDB\dll;D:\sybase\DataAccess\ODBC\dll;D:\s ybase\OCS-15_0\lib3p;D:\sybase\OCS-15_0\dll;D:\sybase\OCS-15_0\bin;C:\WINDOWS\system32;C:\ WINDOWS;C:\WINDOWS\System32\Wbem;D:\sybase\DBISQL\bin
      2011-07-21 10:17:25,993 INFO  [org.apache.coyote.http11.Http11Protocol] Initializing Coyote HTTP/1.1 on http-0.0.0.0-8080
      2011-07-21 10:17:26,008 INFO  [org.apache.coyote.ajp.AjpProtocol] Initializing Coyote AJP/1.3 on ajp-0.0.0.0-8009
      2011-07-21 10:17:26,008 INFO  [org.apache.catalina.startup.Catalina] Initialization processed in 916 ms
      2011-07-21 10:17:26,008 INFO  [org.apache.catalina.core.StandardService] Starting service jboss.web
      2011-07-21 10:17:26,008 INFO  [org.apache.catalina.core.StandardEngine] Starting Servlet Engine: JBossWeb/2.0.0.GA
      2011-07-21 10:17:26,165 INFO  [org.apache.catalina.startup.Catalina] Server startup in 155 ms
      2011-07-21 10:17:27,102 INFO  [org.jboss.web.tomcat.service.TomcatDeployer] deploy, ctxPath=/, warUrl=.../deploy/jboss-web.deployer/ROOT.war/
      2011-07-21 10:17:28,977 INFO  [org.jboss.web.tomcat.service.TomcatDeployer] deploy, ctxPath=/invoker, warUrl=.../deploy/httpha-invoker.sar/invoker.war/
      2011-07-21 10:17:30,180 INFO  [org.jboss.web.tomcat.service.TomcatDeployer] deploy, ctxPath=/jbossws, warUrl=.../tmp/deploy/tmp760648833470872602jbossws-context-exp.war/
      2011-07-21 10:17:30,384 INFO  [org.jboss.web.tomcat.service.TomcatDeployer] deploy, ctxPath=/juddi, warUrl=.../deploy/juddi-service.sar/juddi.war/
      2011-07-21 10:17:30,618 INFO  [org.apache.juddi.registry.RegistryServlet] Loading jUDDI configuration.
      2011-07-21 10:17:30,618 INFO  [org.apache.juddi.registry.RegistryServlet] Resources loaded from: /WEB-INF/juddi.properties
      2011-07-21 10:17:30,618 INFO  [org.apache.juddi.registry.RegistryServlet] Initializing jUDDI components.
      2011-07-21 10:17:32,181 INFO  [org.jboss.mail.MailService] Mail Service bound to java:/Mail
      2011-07-21 10:17:32,915 INFO  [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/jboss-ha-local-jdbc.rar
      2011-07-21 10:17:33,024 INFO  [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/jboss-ha-xa-jdbc.rar
      2011-07-21 10:17:33,212 INFO  [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/jboss-local-jdbc.rar
      2011-07-21 10:17:33,321 INFO  [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/jboss-xa-jdbc.rar
      2011-07-21 10:17:33,384 INFO  [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/quartz-ra.rar
      2011-07-21 10:17:33,415 INFO  [org.jboss.resource.adapter.quartz.inflow.QuartzResourceAdapter] start quartz!!!
      2011-07-21 10:17:33,540 INFO  [org.quartz.simpl.SimpleThreadPool] Job execution threads will use class loader of thread: main
      2011-07-21 10:17:33,618 INFO  [org.quartz.core.QuartzScheduler] Quartz Scheduler v.1.6.0 created.
      2011-07-21 10:17:33,618 INFO  [org.quartz.simpl.RAMJobStore] RAMJobStore initialized.
      2011-07-21 10:17:33,618 INFO  [org.quartz.impl.StdSchedulerFactory] Quartz scheduler 'DefaultQuartzScheduler' initialized from default resource file in Quartz package: 'quartz.properties'
      2011-07-21 10:17:33,618 INFO  [org.quartz.impl.StdSchedulerFactory] Quartz scheduler version: 1.6.0
      2011-07-21 10:17:33,649 INFO  [org.quartz.core.QuartzScheduler] Scheduler DefaultQuartzScheduler_$_NON_CLUSTERED started.
      2011-07-21 10:17:34,243 INFO  [org.jboss.resource.connectionmanager.ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=DataSourceBinding,name=IDP_DS' to JNDI name 'java:IDP_DS'
      2011-07-21 10:17:34,274 INFO  [org.jboss.resource.connectionmanager.ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=DataSourceBinding,name=EDC_DS' to JNDI name 'java:EDC_DS'
      2011-07-21 10:17:34,665 INFO  [org.jboss.resource.connectionmanager.ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=DataSourceBinding,name=LC_NCIA' to JNDI name 'java:LC_NCIA'
      2011-07-21 10:17:34,837 INFO  [org.jboss.resource.connectionmanager.ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=DataSourceBinding,name=LC_ALCCUSTOM' to JNDI name 'java:LC_ALCCUSTOM'
      2011-07-21 10:17:34,962 INFO  [org.jboss.resource.connectionmanager.ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=DataSourceBinding,name=DefaultDS' to JNDI name 'java:DefaultDS'
      2011-07-21 10:17:37,384 WARN  [org.jboss.resource.connectionmanager.JBossManagedConnectionPool] Throwable while attempting to get a new connection: null
      org.jboss.resource.JBossResourceException: Could not create connection; - nested throwable: (com.microsoft.sqlserver.jdbc.SQLServerException: Connection reset by peer: socket write error)
          at org.jboss.resource.adapter.jdbc.local.LocalManagedConnectionFactory.createManagedConnecti on(LocalManagedConnectionFactory.java:179)
          at org.jboss.resource.connectionmanager.InternalManagedConnectionPool.createConnectionEventL istener(InternalManagedConnectionPool.java:577)
          at org.jboss.resource.connectionmanager.InternalManagedConnectionPool.getConnection(Internal ManagedConnectionPool.java:262)
          at org.jboss.resource.connectionmanager.JBossManagedConnectionPool$BasePool.getConnection(JB ossManagedConnectionPool.java:500)
          at org.jboss.resource.connectionmanager.BaseConnectionManager2.getManagedConnection(BaseConn ectionManager2.java:341)
          at org.jboss.resource.connectionmanager.TxConnectionManager.getManagedConnection(TxConnectio nManager.java:315)
          at org.jboss.resource.connectionmanager.BaseConnectionManager2.allocateConnection(BaseConnec tionManager2.java:396)
          at org.jboss.resource.connectionmanager.BaseConnectionManager2$ConnectionManagerProxy.alloca teConnection(BaseConnectionManager2.java:842)
          at org.jboss.resource.adapter.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:88 )
          at org.jboss.ejb.plugins.cmp.jdbc.SQLUtil.tableExists(SQLUtil.java:1017)
          at org.jboss.ejb.txtimer.GeneralPurposeDatabasePersistencePlugin.createTableIfNotExists(Gene ralPurposeDatabasePersistencePlugin.java:142)
          at org.jboss.ejb.txtimer.DatabasePersistencePolicy.startService(DatabasePersistencePolicy.ja va:104)
          at org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:289)
          at org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:245)
          at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
          at java.lang.reflect.Method.invoke(Unknown Source)
          at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:155)
          at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94)
          at org.jboss.mx.server.Invocation.invoke(Invocation.java:86)
          at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
          at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659)
          at org.jboss.system.ServiceController$ServiceProxy.invoke(ServiceController.java:978)
          at $Proxy0.start(Unknown Source)
          at org.jboss.system.ServiceController.start(ServiceController.java:417)
          at org.jboss.system.ServiceController.start(ServiceController.java:435)
          at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
          at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:210)
          at $Proxy4.start(Unknown Source)
          at org.jboss.deployment.SARDeployer.start(SARDeployer.java:302)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
          at org.jboss.mx.interceptor.AbstractInterceptor.invoke(AbstractInterceptor.java:133)
          at org.jboss.mx.server.Invocation.invoke(Invocation.java:88)
          at org.jboss.mx.interceptor.ModelMBeanOperationInterceptor.invoke(ModelMBeanOperationInterce ptor.java:142)
          at $Proxy43.start(Unknown Source)
          at org.jboss.deployment.XSLSubDeployer.start(XSLSubDeployer.java:197)
          at org.jboss.deployment.MainDeployer.start(MainDeployer.java:1025)
          at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:819)
          at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:782)
          at sun.reflect.GeneratedMethodAccessor22.invoke(Unknown Source)
          at $Proxy9.deploy(Unknown Source)
          at org.jboss.deployment.scanner.URLDeploymentScanner.deploy(URLDeploymentScanner.java:421)
          at org.jboss.deployment.scanner.URLDeploymentScanner.scan(URLDeploymentScanner.java:634)
          at org.jboss.deployment.scanner.AbstractDeploymentScanner$ScannerThread.doScan(AbstractDeplo ymentScanner.java:263)
          at org.jboss.deployment.scanner.AbstractDeploymentScanner.startService(AbstractDeploymentSca nner.java:336)
          at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:766)
          at $Proxy5.deploy(Unknown Source)
          at org.jboss.system.server.ServerImpl.doStart(ServerImpl.java:482)
          at org.jboss.system.server.ServerImpl.start(ServerImpl.java:362)
          at org.jboss.Main.boot(Main.java:200)
          at org.jboss.Main$1.run(Main.java:508)
          at java.lang.Thread.run(Unknown Source)
      Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Connection reset by peer: socket write error
          at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(Unknown Source)
          at com.microsoft.sqlserver.jdbc.TDSChannel.write(Unknown Source)
          at com.microsoft.sqlserver.jdbc.SQLServerConnection.Prelogin(Unknown Source)
          at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(Unknown Source)
          at com.microsoft.sqlserver.jdbc.SQLServerConnection.loginWithoutFailover(Unknown Source)
          at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(Unknown Source)
          at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(Unknown Source)
          at org.jboss.resource.adapter.jdbc.local.LocalManagedConnectionFactory.createManagedConnecti on(LocalManagedConnectionFactory.java:171)
          ... 121 more
      2011-07-21 10:17:37,446 ERROR [org.jboss.ejb.txtimer.GeneralPurposeDatabasePersistencePlugin] Cannot create timer table
      org.jboss.deployment.DeploymentException: Error while checking if table aleady exists TIMERS; - nested throwable: (org.jboss.util.NestedSQLException: Could not create connection; - nested throwable: (com.microsoft.sqlserver.jdbc.SQLServerException: Connection reset by peer: socket write error); - nested throwable: (org.jboss.resource.JBossResourceException: Could not create connection; - nested throwable: (com.microsoft.sqlserver.jdbc.SQLServerException: Connection reset by peer: socket write error)))
          at org.jboss.ejb.plugins.cmp.jdbc.SQLUtil.tableExists(SQLUtil.java:1062)
      Caused by: org.jboss.util.NestedSQLException: Could not create connection; - nested throwable: (com.microsoft.sqlserver.jdbc.SQLServerException: Connection reset by peer: socket write error); - nested throwable: (org.jboss.resource.JBossResourceException: Could not create connection; - nested throwable: (com.microsoft.sqlserver.jdbc.SQLServerException: Connection reset by peer: socket write error))
          at org.jboss.resource.adapter.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:94 )
          ... 112 more
      Caused by: org.jboss.resource.JBossResourceException: Could not create connection; - nested throwable: (com.microsoft.sqlserver.jdbc.SQLServerException: Connection reset by peer: socket write error)
          ... 113 more
          ... 121 more
      2011-07-21 10:17:37,525 WARN  [org.jboss.resource.connectionmanager.JBossManagedConnectionPool] Throwable while attempting to get a new connection: null
          at org.jboss.ejb.plugins.keygenerator.hilo.HiLoKeyGeneratorFactory.createTableIfNotExists(Hi LoKeyGeneratorFactory.java:366)
          at org.jboss.ejb.plugins.keygenerator.hilo.HiLoKeyGeneratorFactory.initSequence(HiLoKeyGener atorFactory.java:307)
          at org.jboss.ejb.plugins.keygenerator.hilo.HiLoKeyGeneratorFactory.startService(HiLoKeyGener atorFactory.java:281)
          ... 122 more
      2011-07-21 10:17:37,525 WARN  [org.jboss.system.ServiceController] Problem starting service jboss:service=KeyGeneratorFactory,type=HiLo
      org.jboss.deployment.DeploymentException: Error while checking if table aleady exists HILOSEQUENCES; - nested throwable: (org.jboss.util.NestedSQLException: Could not create connection; - nested throwable: (com.microsoft.sqlserver.jdbc.SQLServerException: Connection reset by peer: socket write error); - nested throwable: (org.jboss.resource.JBossResourceException: Could not create connection; - nested throwable: (com.microsoft.sqlserver.jdbc.SQLServerException: Connection reset by peer: socket write error)))
          ... 113 more
          ... 114 more
          ... 122 more
      2011-07-21 10:17:40,025 INFO  [org.jboss.deployment.EARDeployer] Init J2EE application: file:/D:/Adobe/Adobe LiveCycle ES2/jboss/server/lc_turnkey/deploy/adobe-livecycle-jboss.ear
      2011-07-21 10:17:54,744 WARN  [org.jboss.deployment.MainDeployer] Found non-jar deployer for adobe-dscf.jar: MBeanProxyExt[jboss.ejb:service=EJBDeployer]
      2011-07-21 10:17:55,025 WARN  [org.jboss.deployment.MainDeployer] Found non-jar deployer for um.jar: MBeanProxyExt[jboss.ejb:service=EJBDeployer]
      2011-07-21 10:17:55,697 WARN  [org.jboss.deployment.MainDeployer] Found non-jar deployer for um.jar: MBeanProxyExt[jboss.ejb:service=EJBDeployer]
      2011-07-21 10:17:56,447 WARN  [org.jboss.deployment.MainDeployer] Found non-jar deployer for adobe-dscf.jar: MBeanProxyExt[jboss.ejb:service=EJBDeployer]
      2011-07-21 10:17:56,682 WARN  [org.jboss.deployment.MainDeployer] Found non-jar deployer for um.jar: MBeanProxyExt[jboss.ejb:service=EJBDeployer]
      2011-07-21 10:17:57,119 WARN  [org.jboss.deployment.MainDeployer] Found non-jar deployer for um.jar: MBeanProxyExt[jboss.ejb:service=EJBDeployer]
      2011-07-21 10:17:57,713 WARN  [org.jboss.deployment.MainDeployer] Found non-jar deployer for adobe-dscf.jar: MBeanProxyExt[jboss.ejb:service=EJBDeployer]
      2011-07-21 10:17:57,869 WARN  [org.jboss.deployment.MainDeployer] Found non-jar deployer for um.jar: MBeanProxyExt[jboss.ejb:service=EJBDeployer]
      2011-07-21 10:17:58,197 WARN  [org.jboss.deployment.MainDeployer] Found non-jar deployer for um.jar: MBeanProxyExt[jboss.ejb:service=EJBDeployer]
      2011-07-21 10:17:58,572 WARN  [org.jboss.deployment.MainDeployer] Found non-jar deployer for um.jar: MBeanProxyExt[jboss.ejb:service=EJBDeployer]
      2011-07-21 10:17:59,307 WARN  [org.jboss.deployment.MainDeployer] Found non-jar deployer for adobe-ejb-receiver.jar: MBeanProxyExt[jboss.ejb:service=EJBDeployer]
      2011-07-21 10:18:05,119 WARN  [org.jboss.deployment.MainDeployer] Found non-jar deployer for um.jar: MBeanProxyExt[jboss.ejb:service=EJBDeployer]
