3 Replies Latest reply on Jul 22, 2011 6:31 AM by Karl_Sigiscar_1971
    Convert HierarchicalCollectionView to ArrayCollection
    sw_engr
      I'm trying to retrieve the ArrayCollection data provided to DataGrid and AdvancedDataGrid. While gridID.dataProvider works for flat data, I'm getting coercion error when data is heirarchical. Is there a way to retrieve the original ArrayCollection data? Parsing doesn't seem to work either. TIA!
        • 1. Re: Convert HierarchicalCollectionView to ArrayCollection
          Karl_Sigiscar_1971 Level 3
          Look at the declaration for both classes, they are very different and do not implement the same interfaces nor extend the same superclasses:
          public class HierarchicalCollectionView extends EventDispatcher
                                                  implements IHierarchicalCollectionView, IXMLNotifiable
          public class ArrayCollection extends ListCollectionView implements IExternalizable
          Since Adobe engineers knew that some people would want to use flat data as a hierarchical data source in an AdvancedDataGrid, they came up with the notion of grouping, which allows you to create a hierarchy from flat data.
          • 2. Re: Convert HierarchicalCollectionView to ArrayCollection
            sw_engr Level 1
            I see. But is there no way to retrieve the same flat data that I defined as source in the GroupingCollection2?
            • 3. Re: Convert HierarchicalCollectionView to ArrayCollection
              If you have a GroupingCollection2 instance, you can still retrieve its source afterward by using something like var ac:ArrayCollection = gc.source as ArrayCollection;
              <mx:AdvancedDataGrid id="myADG"
                  <mx:dataProvider>
                    <mx:GroupingCollection2 id="gc" source="{dpFlat}">
                      <mx:grouping>
                        <mx:Grouping>
                          <mx:GroupingField name="Region"/>
                          <mx:GroupingField name="Territory"/>
                        </mx:Grouping>
                      </mx:grouping>
                    </mx:GroupingCollection2>
                  </mx:dataProvider>
                  <mx:columns>
                    <mx:AdvancedDataGridColumn dataField="Region"/>
                    <mx:AdvancedDataGridColumn dataField="Territory"/>
                    <mx:AdvancedDataGridColumn dataField="Territory_Rep"/>
                    <mx:AdvancedDataGridColumn dataField="Actual"/>
                    <mx:AdvancedDataGridColumn dataField="Estimate"/>
                  </mx:columns>
                </mx:AdvancedDataGrid>
              In the case of this example from the livedocs, var ac:ArrayCollection = gc.source as ArrayCollection; would return a reference to dpFlat.
