13 Replies Latest reply on Aug 8, 2011 1:51 PM by wolf14
    adl.exe crashes on Flash CS4(air project) on test movie
    wolf14 Level 1
      Hello, I am using Flash CS4 and AIR version 2.7 and when testing movie within flash(AIR project) I get this adl.exe crash, most of the times which is annoying.
      Any advice? The crash is below:
      Problem signature:
        Problem Event Name: APPCRASH
        Application Name: adl.exe
        Application Version: 1.1.0.5790
        Application Timestamp: 483e46ec
        Fault Module Name: ntdll.dll
        Fault Module Version: 6.1.7601.17514
        Fault Module Timestamp: 4ce7ba58
        Exception Code: c0000005
        Exception Offset: 00038da9
        OS Version: 6.1.7601.2.1.0.256.1
        Locale ID: 1033
        Additional Information 1: 0a9e
        Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
        Additional Information 3: 0a9e
        Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
        • 1. Re: adl.exe crashes on Flash CS4(air project) on test movie
          wolf14 Level 1
          No solutions to this crash? Using Windows 7
          • 2. Re: adl.exe crashes on Flash CS4(air project) on test movie
            chris.campbell Adobe Employee
            Hi Wolf14,
            Could you open a bug for this issue over at bugbase.adobe.com and if possible, please include a crash dump with the steps that you took to reproduce the crash?  Here's a good article that describes this process for different Windows operating systems:
            Creating Dr. Watson Crash Dumps
            Chris
            • 3. Re: adl.exe crashes on Flash CS4(air project) on test movie
              wolf14 Level 1
              No time to open bug, maybe you guys do it? You getting paid afterall.
              Thanks!
              • 4. Re: adl.exe crashes on Flash CS4(air project) on test movie
                Unfortunately, I'm unable to reproduce the crash.  We'll need the crash log and/or some reproducible steps to help us take action.  Anything you can provide would be appreciated.
                Chris
                • 5. Re: adl.exe crashes on Flash CS4(air project) on test movie
                  wolf14 Level 1
                  How can I provide a crash log?
                  I am using Windows 7 Ultimate 64 bit, Flash CS4, Adobe air 2.7.
                  Maybe it's because adobe air runs on 32 bit? I think not but...just an idea.
                  It crashes when publishing a movie, at random times.
                  So sometimes it crashes sometimes it doesn't. I think it's because the adl.exe doesn't properly close when you hit the X button on the window, or an Air service doesn't properly close, so if you hit Ctrl Enter to re-publish the movie it conflicts.
                  • 6. Re: adl.exe crashes on Flash CS4(air project) on test movie
                    I found the following link which explains how to generate a dmp file on Windows 7.
                    Chris
                    • 7. Re: adl.exe crashes on Flash CS4(air project) on test movie
                      wolf14 Level 1
                      Here you are:
                      Version=1
                      EventType=APPCRASH
                      EventTime=129561122352896610
                      ReportType=2
                      Consent=1
                      ReportIdentifier=c032b697-b71a-11e0-9177-002421f38d52
                      IntegratorReportIdentifier=c032b696-b71a-11e0-9177-002421f38d52
                      WOW64=1
                      Response.type=4
                      Sig[0].Name=Application Name
                      Sig[0].Value=adl.exe
                      Sig[1].Name=Application Version
                      Sig[1].Value=1.1.0.5790
                      Sig[2].Name=Application Timestamp
                      Sig[2].Value=483e46ec
                      Sig[3].Name=Fault Module Name
                      Sig[3].Value=ntdll.dll
                      Sig[4].Name=Fault Module Version
                      Sig[4].Value=6.1.7601.17514
                      Sig[5].Name=Fault Module Timestamp
                      Sig[5].Value=4ce7ba58
                      Sig[6].Name=Exception Code
                      Sig[6].Value=c0000005
                      Sig[7].Name=Exception Offset
                      Sig[7].Value=00038da9
                      DynamicSig[1].Name=OS Version
                      DynamicSig[1].Value=6.1.7601.2.1.0.256.1
                      DynamicSig[2].Name=Locale ID
                      DynamicSig[2].Value=1033
                      DynamicSig[22].Name=Additional Information 1
                      DynamicSig[22].Value=0a9e
                      DynamicSig[23].Name=Additional Information 2
                      DynamicSig[23].Value=0a9e372d3b4ad19135b953a78882e789
                      DynamicSig[24].Name=Additional Information 3
                      DynamicSig[24].Value=0a9e
                      DynamicSig[25].Name=Additional Information 4
                      DynamicSig[25].Value=0a9e372d3b4ad19135b953a78882e789
                      UI[2]=C:\Program Files (x86)\Adobe\Adobe Flash CS4\AIK1.1\bin\adl.exe
                      UI[3]=adl.exe has stopped working
                      UI[4]=Windows can check online for a solution to the problem.
                      UI[5]=Check online for a solution and close the program
                      UI[6]=Check online for a solution later and close the program
                      UI[7]=Close the program
                      LoadedModule[0]=C:\Program Files (x86)\Adobe\Adobe Flash CS4\AIK1.1\bin\adl.exe
                      LoadedModule[1]=C:\Windows\SysWOW64\ntdll.dll
                      LoadedModule[2]=C:\Windows\syswow64\kernel32.dll
                      LoadedModule[3]=C:\Windows\syswow64\KERNELBASE.dll
                      LoadedModule[4]=C:\Windows\system32\msi.dll
                      LoadedModule[5]=C:\Windows\syswow64\msvcrt.dll
                      LoadedModule[6]=C:\Windows\syswow64\ADVAPI32.dll
                      LoadedModule[7]=C:\Windows\SysWOW64\sechost.dll
                      LoadedModule[8]=C:\Windows\syswow64\RPCRT4.dll
                      LoadedModule[9]=C:\Windows\syswow64\SspiCli.dll
                      LoadedModule[10]=C:\Windows\syswow64\CRYPTBASE.dll
                      LoadedModule[11]=C:\Windows\syswow64\USER32.dll
                      LoadedModule[12]=C:\Windows\syswow64\GDI32.dll
                      LoadedModule[13]=C:\Windows\syswow64\LPK.dll
                      LoadedModule[14]=C:\Windows\syswow64\USP10.dll
                      LoadedModule[15]=C:\Windows\syswow64\SHLWAPI.dll
                      LoadedModule[16]=C:\Windows\syswow64\ole32.dll
                      LoadedModule[17]=C:\Windows\syswow64\SHELL32.dll
                      LoadedModule[18]=C:\Windows\system32\IMM32.DLL
                      LoadedModule[19]=C:\Windows\syswow64\MSCTF.dll
                      LoadedModule[20]=C:\Program Files (x86)\Adobe\Adobe Flash CS4\AIK1.1\runtimes\air\win\Adobe AIR\Versions\1.0\Adobe AIR.dll
                      LoadedModule[21]=C:\Windows\system32\VERSION.dll
                      LoadedModule[22]=C:\Windows\syswow64\OLEAUT32.dll
                      LoadedModule[23]=C:\Windows\system32\WINMM.dll
                      LoadedModule[24]=C:\Windows\syswow64\CRYPT32.dll
                      LoadedModule[25]=C:\Windows\syswow64\MSASN1.dll
                      LoadedModule[26]=C:\Windows\syswow64\WS2_32.dll
                      LoadedModule[27]=C:\Windows\syswow64\NSI.dll
                      LoadedModule[28]=C:\Windows\system32\MSIMG32.dll
                      LoadedModule[29]=C:\Windows\syswow64\COMDLG32.dll
                      LoadedModule[30]=C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_ 5.82.7601.17514_none_ec83dffa859149af\COMCTL32.dll
                      LoadedModule[31]=C:\Windows\syswow64\WININET.dll
                      LoadedModule[32]=C:\Windows\syswow64\urlmon.dll
                      LoadedModule[33]=C:\Windows\syswow64\iertutil.dll
                      LoadedModule[34]=C:\Windows\system32\uxtheme.dll
                      LoadedModule[35]=C:\Windows\syswow64\CLBCatQ.DLL
                      LoadedModule[36]=C:\Windows\system32\mlang.dll
                      LoadedModule[37]=C:\Windows\system32\MMDevAPI.DLL
                      LoadedModule[38]=C:\Windows\system32\PROPSYS.dll
                      LoadedModule[39]=C:\Windows\system32\wdmaud.drv
                      LoadedModule[40]=C:\Windows\system32\ksuser.dll
                      LoadedModule[41]=C:\Windows\system32\AVRT.dll
                      LoadedModule[42]=C:\Windows\syswow64\SETUPAPI.dll
                      LoadedModule[43]=C:\Windows\syswow64\CFGMGR32.dll
                      LoadedModule[44]=C:\Windows\syswow64\DEVOBJ.dll
                      LoadedModule[45]=C:\Windows\system32\AUDIOSES.DLL
                      LoadedModule[46]=C:\Windows\system32\msacm32.drv
                      LoadedModule[47]=C:\Windows\system32\MSACM32.dll
                      LoadedModule[48]=C:\Windows\system32\midimap.dll
                      LoadedModule[49]=C:\Windows\system32\profapi.dll
                      LoadedModule[50]=C:\Windows\system32\dwmapi.dll
                      LoadedModule[51]=C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_ 6.0.7601.17514_none_41e6975e2bd6f2b2\comctl32.dll
                      LoadedModule[52]=C:\Windows\system32\WindowsCodecs.dll
                      LoadedModule[53]=C:\Windows\system32\apphelp.dll
                      LoadedModule[54]=C:\Windows\system32\EhStorShell.dll
                      LoadedModule[55]=C:\Windows\system32\ntshrui.dll
                      LoadedModule[56]=C:\Windows\system32\srvcli.dll
                      LoadedModule[57]=C:\Windows\system32\cscapi.dll
                      LoadedModule[58]=C:\Windows\system32\slc.dll
                      LoadedModule[59]=C:\Windows\system32\Secur32.dll
                      LoadedModule[60]=C:\Windows\system32\credssp.dll
                      LoadedModule[61]=C:\Windows\SysWOW64\schannel.dll
                      LoadedModule[62]=C:\Windows\system32\mswsock.dll
                      LoadedModule[63]=C:\Windows\System32\wshtcpip.dll
                      LoadedModule[64]=C:\Windows\System32\wship6.dll
                      LoadedModule[65]=C:\Windows\system32\DNSAPI.dll
                      LoadedModule[66]=C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL
                      LoadedModule[67]=C:\Windows\syswow64\PSAPI.DLL
                      LoadedModule[68]=C:\Windows\system32\IPHLPAPI.DLL
                      LoadedModule[69]=C:\Windows\system32\WINNSI.DLL
                      LoadedModule[70]=C:\Windows\system32\rasadhlp.dll
                      LoadedModule[71]=C:\Windows\System32\fwpuclnt.dll
                      LoadedModule[72]=C:\Windows\system32\RASAPI32.dll
                      LoadedModule[73]=C:\Windows\system32\rasman.dll
                      LoadedModule[74]=C:\Windows\system32\rtutils.dll
                      LoadedModule[75]=C:\Windows\system32\sensapi.dll
                      LoadedModule[76]=C:\Windows\system32\NLAapi.dll
                      LoadedModule[77]=C:\Windows\system32\napinsp.dll
                      LoadedModule[78]=C:\Windows\system32\pnrpnsp.dll
                      LoadedModule[79]=C:\Windows\System32\winrnr.dll
                      LoadedModule[80]=C:\Windows\system32\ntmarta.dll
                      LoadedModule[81]=C:\Windows\syswow64\WLDAP32.dll
                      FriendlyEventName=Stopped working
                      ConsentKey=APPCRASH
                      AppName=adl.exe
                      AppPath=C:\Program Files (x86)\Adobe\Adobe Flash CS4\AIK1.1\bin\adl.exe
                      • 8. Re: adl.exe crashes on Flash CS4(air project) on test movie
                        When you generated that, was a .dmp file also created?  If you can send that to me at ccampbel@adobe.com we can go from there.
                        Chris
                        • 9. Re: adl.exe crashes on Flash CS4(air project) on test movie
                          wolf14 Level 1
                          Yes it is 94mb though, I think it contains all the crashes that happened. What you want me to send you on your email?
                          • 10. Re: adl.exe crashes on Flash CS4(air project) on test movie
                            Do you mind emailing me the latest .dmp?   I'm not sure how much it'll compress, but feel free to zip it if it helps.
                            Chris
                            • 11. Re: adl.exe crashes on Flash CS4(air project) on test movie
                              wolf14 Level 1
                              I've sent you an email, not sure if you received it.
                              • 12. Re: adl.exe crashes on Flash CS4(air project) on test movie
                                Got the email, thank you.  Replied back.
                                Chris
                                • 13. Re: adl.exe crashes on Flash CS4(air project) on test movie
                                  wolf14 Level 1
                                  As I said to Chris via email, seems like updating to Flash CS4 10.0.2 using Adobe Updater fixed the issue.
                                  Thanks again.
