5 Replies Latest reply on Aug 7, 2011 7:15 AM by kglad
    Cross fade frames
    Owen_Alextoys
      Hi
           I'm trying to cross fade between two frames using action script. I can fade a frame out with the following script but I can't figure out the cross fade part.
      /* Fade Out Movie Clip
      Fades out the symbol instance by decreasing its alpha property within an ENTER_FRAME event until it is invisible.
      Instructions:
      1. To change the speed at which the symbol instance fades out, change the 0.01 value below (valid values are in the range 0.0 - 1.0). Higher values cause faster fade out.
      2. The '-=' operator is a shortcut to typing 'Spread1.alpha = Spread1.alpha - 0.1'.
      3. Because the animation uses an ENTER_FRAME event, it progresses only when the playhead moves to a new frame, and the speed of the animation is also affected by the frame rate of the FLA file.
      Spread1.addEventListener(Event.ENTER_FRAME, fl_FadeSymbolOut);
      Spread1.alpha = 1;
      function fl_FadeSymbolOut(event:Event)
      Spread1.alpha -= 0.1;
      if(Spread1.alpha <= 0)
      Spread1.removeEventListener(Event.ENTER_FRAME, fl_FadeSymbolOut);
        • 1. Re: Cross fade frames
          if your object you want to fade-in has reference Spread2, use:
          Spread1.alpha = 1;
          Spread2.alpha = 0;
          Spread2.alpha+=.1;
          Spread2.alpha=1;
          • 2. Re: Cross fade frames
            Owen_Alextoys Level 1
            I'm getting the following error:
            TypeError: Error #1009: Cannot access a property or method of a null object reference.
            at FrontDeskVideoTest_fla::MainTimeline/frame1()
            Here's the AS3:
            /* Stop at This Frame
            The Flash timeline will stop/pause at the frame where you insert this code.
            Can also be used to stop/pause the timeline of movieclips.
            stop();
            var myTimer:Timer = new Timer(5000);
            myTimer.addEventListener(TimerEvent.TIMER, fiveSec);
            myTimer.start();
            function fiveSec(event:TimerEvent):void
               this.nextFrame();
               trace(currentFrame);
            Spread1.alpha = 1;
            Spread2.alpha = 0;
            Spread2.alpha+=.1;
            Spread2.alpha=1;
            • 3. Re: Cross fade frames
              do you have an object Spread2 that you want to fade-in?
              • 4. Re: Cross fade frames
                Yes the movie clip in the second frame is called Spread 2. I get the following in the output tab
                at FrontDeskVideoTest_fla::MainTimeline/fl_FadeSymbolOut()
                Sorry for the delay
                • 5. Re: Cross fade frames
                  use:
                  trace(Spread1);
                  trace(Spread2);
                  stop();
                  myTimer.start();
                     this.nextFrame();
                  Spread1.alpha = 1;
                  Spread2.alpha = 0;
                  Spread2.alpha+=.1;
                  Spread2.alpha=1;
                  one of both those traces are going be be null or undefined because one or both do not exist WHEN that code executes.  fix that.
