2 Replies Latest reply on Jul 21, 2011 5:04 PM by Nancy OShea
    Question about what to do after building home page
      I have just finished the home page to a website I am making in dreamweaver. I am going to start making the other pages of the site now.
      I obviously want to use the same banner and some other features from the home page on every single page, so do I just copy the HTML from the home page to all of my new pages, and then just delete whatever code was only for the home page, and add the new code for the specific page?
      Also, do I need to make a new styles .css file for every single page of the site?
        • 1. Re: Question about what to do after building home page
          Ken Binney Level 6
          Do a little reading on Server Side Includes tonight and we will talk you through the process of
          moving selected portions of your code to a separate text files which you can save as (for example)
          header.inc, footer.inc, menu.inc
          This will be the code for the parts of your page that will appear on all your pages.
          Again for example, if your hosting supports PHP code you would past a small block of PHP code
          into your page to replace the code you removed the code that is now in the .inc files
          The small PHP code bits would look like
          <?php require_once("header.inc"); ?>  and
          <?php require_once("footer.inc"); ?> etc.
          Your pages would be named with a .php extension like index.php etc/
          The server will merge the code from the .inc in the page where you have placed the small PHP code tags.
          Any changes you need to make later in the .inc files will appear in all your pages at once
          You need only one stylesheet which applies to all pages by inserting this code within the <head> section of every page
          like <link href="styles.css" rel="stylesheet" type="text/css">
          • 2. Re: Question about what to do after building home page
            How many pages to do you anticipate having in your web site?  If somewhere around 20 but less than 50, saving your prototype page as a DWTemplate (dwt file) might be the way to go.
            As to CSS style sheets, one external sheet should be all you need for your site wide layout and text styles.  You can use  embedded CSS rules for page specific styling -- eg. you want to use a different background image on your contact page.
            Nancy O.
            Alt-Web Design & Publishing
            Web | Graphics | Print | Media  Specialists
