2 Replies Latest reply on Mar 29, 2009 6:47 AM by Dan Bracuk
    How can I solve this proble
      How can I solve this problem " Could not find the included template includes/udf.cfm.
      Note: If you wish to use an absolute template path (e.g. TEMPLATE="/mypath/index.cfm") with CFINCLUDE then you must create a mapping for the path using the ColdFusion Administrator. Using relative paths (e.g. TEMPLATE="index.cfm" or TEMPLATE="../index.cfm") does not require the creation of any special mappings. It is therefore recommended that you use relative paths with CFINCLUDE whenever possible.
      The error occurred in F:\hshome\kunstart\blog.zeaqraht.com\Application.cfm: line 33
      31 : <cferror type="exception" template="error.cfm">
      32 :
      33 : <cfinclude template="includes/udf.cfm">
      34 :
      35 : <!--- By default we cache a lot of information. Allow reinit=1 in the URL to restart cache. --->
      Please try the following:
      * Check the ColdFusion documentation to verify that you are using the correct syntax.
      * Search the Knowledge Base to find a solution to your problem.
      Browser Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.8) Gecko/2009032609 Firefox/3.0.8
      Remote Address 209.148.136.211
      Referrer
      Date/Time 31-Mar-09 08:40 AM
      Stack Trace
      at cfApplication2ecfm1925097472.runPage(F:\hshome\kunstart\blog.zeaqraht.com\Application.cfm :33)
      coldfusion.tagext.lang.IncludeTag$NoSuchIncludeTemplateException: Could not find the included template includes/udf.cfm.
      at coldfusion.tagext.lang.IncludeTag.setTemplate(IncludeTag.java:283)
      at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:147)
      at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:357)
      at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:62)
      at coldfusion.filter.CfincludeFilter.include(CfincludeFilter.java:30)
      at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:93)
      at coldfusion.filter.PathFilter.invoke(PathFilter.java:80)
      at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:47)
      at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
      at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:35)
      at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:43)
      at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
      at coldfusion.CfmServlet.service(CfmServlet.java:105)
      at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
      at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
      at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:252)
      at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:527)
      at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:192)
      at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:348)
      at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:451)
      at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:294)
      at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
      "? I encountered the problem while I was setting up blog CFC5. Appreciate your help.
