3 Replies Latest reply on Mar 27, 2009 8:54 PM by Newsgroup_User
    Xml parse failure
    Peter Hahmann Level 1
      I'm trying to parse the following xmlString, but as you'll notice, the parse will not be successful as one of my attributes has special chars. What can I do?
      Peter
      my xmlString:
      <node><node id="01" label="Some text"><node id="02" label="Some text with < or >"/></node></node>
        • 1. Re: Xml parse failure
          _Natasha_ Level 4
          You can fix this xmlString by changing all special characters to there equivalent &lt; &gt; and others
          For example, you can get all attributes using RegExp
          var pattern:RegExp = /"([^"]*)"/g;
          var result:Object = testString.match(pattern);
          And then check each attribute for <,>, &, ... and replace incorrect values.
          I think it's the easiest way to solve it.
          • 2. Re: Xml parse failure
            ruffing232
            could become
            <node><node id="01" label="Some text"><node id="02" label="Some text with &lt; or &gt;"/></node></node>
            If your server is sending back the response, then you should probably fix this on the server side. This happens a lot when developers code their response using string builders instead of an XML node builder and then outputting the node.
            If you are just doing this on the client side, then the fix is to replace the XML markup characters with their equivalently coded characters.
            • 3. Re: Xml parse failure
              Level 7
              "ruffing232" <webforumsuser@macromedia.com> wrote in message
              news:gqjfam$gtq$1@forums.macromedia.com...
              > < or
              >>"/></node></node>
              > could become
              > < or
              >>"/></node></node>
              > this
              > response
              > the
              > node.
              > the
              Or wrap the offending property in CDATA.
