4 Replies Latest reply on Jul 24, 2011 11:11 AM by Francisc
    Get line height of multiline StyleableTextField
    Francisc Level 3
      Hello,
      So? How can I do that: get the height in pixels between StyleableTextField lines?
      The reason I need this is that if I try to center it vertically, (totalHeight-StyleableTextField.textHeight)/2 it won't consider the vertical spacing and the centering is missing a few pixels.
      Thank you.
        • 1. Re: Get line height of multiline StyleableTextField
          Shongrunden Adobe Employee
          I would avoid using the textHeight property.  Does it work better if you use the getElementPreferredHeight() method that LabelItemRenderer provides?  See the renderer I created in this thread for an example.
          • 2. Re: Get line height of multiline StyleableTextField
            Francisc Level 3
            getElementPreferredHeight() does fix the problem.
            You're saying I should use getElementPreferredHeight() and getElementPreferredWidth() instead of other properties like textHeight or simply height in mobile item renderers?
            I did read the MultilineLabelItemRenderer you created. It was a good read, taught me a lot. The reason I used textHeight in this particular case was that text was never going to be more than 2 lines, so I figured the added complexity isn't needed for such a simple case.
            Thank you.
            • 3. Re: Get line height of multiline StyleableTextField
              Retrieving size information of an element in a renderer via getElementPreferredWidth()/getElementPreferredHeight() is the recommended approach.
              getElementPreferredWidth() is a convenience method which works similar to how setElementSize() works in that it calls different APIs depending on what the element is typed as:
                   *  A helper method to retrieve the preferred width of a child element.
                   *  <p>This method is the recommended way to get a child element's preferred
                   *  width. You can use this method instead of checking for and using
                   *  various interfaces/classes such as ILayoutElement, IFlexDisplayObject,
                   *  or StyleableTextField.</p>
                   *  @param element The child element to retrieve the width for. The element could
                   *  be an ILayoutElement, IFlexDisplayObject, StyleableTextField, or a generic
                   *  DisplayObject.
                   *  @return The child element's preferred width.
                   *  @see #getElementPreferredHeight
                   *  @langversion 3.0
                   *  @playerversion Flash 10.1
                   *  @playerversion AIR 2.5
                   *  @productversion Flex 4.5
                  protected function getElementPreferredWidth(element:Object):Number
                      if (element is ILayoutElement)
                          return ILayoutElement(element).getPreferredBoundsWidth();
                      else if (element is IFlexDisplayObject)
                          return IFlexDisplayObject(element).measuredWidth;
                      else
                          return element.width;
              Measuring a StyleableTextField can get really tricky and you really won't want to do it yourself if you don't need to.  Using getElementPreferredWidth() will call StyleableTextField.getPreferredBoundsWidth() which in turn calls the mx_internal measuredTextSize() method.  Check out the source code of those methods if you are interested in what measurement calculations are done behind the scenes.
              • 4. Re: Get line height of multiline StyleableTextField
                Francisc Level 3
                OK, Steve. Thank you very much.
