6 Replies Latest reply on Mar 30, 2009 12:33 AM by Newsgroup_User
    Flex + php + mySQL query problem
    Level 7
      Hi all,
      I'm working on a flex project wich has to get a XMLList from a mySQL
      database by php. I can't do a SELECT * FROM Table twice, just the first time
      it gets the correct values... I can insert an other row in my db, but I
      can't update a dataGrid never more. I'm getting crazy...
      If I do an insertRecord() before to updateDB()... the insert always works,
      but the update just works for the first time again.
      the flex code:
      <mx:HTTPService id = "httpService"
      url=http://www.myserver.com/myphp.php
      showBusyCursor="true"
      fault="onFaultHandler(event);"
      resultFormat="e4x"
      useProxy="false"
      <mx:Script>
      <![CDATA[
      include "funcs.as";
      </mx:Script>
      <mx:TextInput id="_name"/>
      <mx:TextInput id="_year"/>
      <mx:TextInput id="_sizeX"/>
      <mx:TextInput id="_sizeY"/>
      <mx:Button label="Insert Record" click="insertRecord()"/>
      <mx:DataGrid x="57" y="232" width="293" height="214" textAlign="center"
      editable="false"
      dataProvider="{dataGridTotal}" id="_dataGrid">
      <mx:columns>
      <mx:DataGridColumn headerText="id" dataField="id"/>
      <mx:DataGridColumn headerText="name" dataField="name"/>
      <mx:DataGridColumn headerText="year" dataField="year"/>
      <mx:DataGridColumn headerText="sizeX" dataField="sizeX"/>
      <mx:DataGridColumn headerText="sizeY" dataField="sizeY"/>
      </mx:columns>
      </mx:DataGrid>
      <mx:Button label="Update DDBB" click="updateDB()"/>
      my funcs.as code:
      public function updateDB():void // It works just the first
      time is executed. never more. WHY????
      dataGridTotal = new XMLList;
      httpService.addEventListener(ResultEvent.RESULT,onResultHandler);
      httpService.method = "GET";
      var _params:Object = new Object();
      _params = {"method": "getAll"};
      httpService.cancel();
      httpService.send(_params);
      public function onResultHandler(event:ResultEvent):void
      httpService.removeEventListener(ResultEvent.RESULT,onResultHandler);
      dataGridTotal = event.result.item as XMLList;
      public function insertRecord():void
      httpService.addEventListener(ResultEvent.RESULT,onInsertItemResultHandler);
      httpService.method = "POST";
      _params = {"method": "insertRecord", "id": NaN, "name": _name.text,
      "year": _year.text, "sizeX": _sizeX.text, "sizeY": _sizeY.text};
      clearInsertInputFields();
      public function onInsertItemResultHandler(event:ResultEvent):void
      httpService.removeEventListener(ResultEvent.RESULT,onInsertItemResultHandler);
      updateDB(); // don't do that
      the php code:
      <?php
      $conn = mysql_pconnect("myserver", "user", "pass");
      if (!$conn) {
      exit("Unable to connect to DB: " . mysql_error());
      if (!mysql_select_db("myDB")) {
      exit("Unable to select mydbname: " . mysql_error());
      switch (@$_REQUEST["method"])
      case "getAll":
      $ret = getAll();
      break;
      case "insertRecord":
      $ret = insertRecord();
      break;
      mysql_close($conn);
      echo $ret;
      global $conn;
      $name = @$_REQUEST["name"];
      $year = @$_REQUEST["year"];
      $sizeX = intval(@$_REQUEST["sizeX"]);
      $sizeY = intval(@$_REQUEST["sizeY"]);
      $sql = "INSERT INTO Test (name, year, sizeX, sizeY) VALUES ('$name',
      '$year', '$sizeX', '$sizeY')";
      $result = mysql_query($sql, $conn);
      return $result;
      function getAll()
      global $conn;
      $sql = "SELECT * FROM Test";
      if (!$result) {
      echo "Could not successfully run query ($query_recordset) from DB:
      " . mysql_error();
      exit;
      else {
      $xmlStr = "<output>";
      while ($row = mysql_fetch_assoc($result)) {
      $xmlStr.= "<item>";
      for($x = 0 ; $x < mysql_num_fields($result) ; $x++) {
      $fieldName = mysql_field_name($result,$x);
      $xmlStr.=
      "<".$fieldName.">".$row[$fieldName]."</".$fieldName.">";
      $xmlStr.= "</item>";
      $xmlStr.= "</output>";
      mysql_free_result($result);
      return $xmlStr;
        • 1. Re: Flex + php + mySQL query problem
          Richard_Abbott Level 3
          LAPR,
          Are you allowed to write
          rather than
          dataGridTotal = new XMLList();
          Richard
          • 2. Re: Flex + php + mySQL query problem
            Level 7
            yeah... you are right :P.
            But it doesn't change anything, the problem still there...
            thanks anyway
            lapr.
            "Richard_Abbott" <webforumsuser@macromedia.com> escribió en el mensaje
            news:gqicip$518$1@forums.macromedia.com...
            > LAPR,
            > rather than
            > Richard
            • 3. Re: Flex + php + mySQL query problem
              Gregory Lafrance Level 6
              I'm wondering if something is going wrong because you are adding the event listener in the updateDB() method and removing it in the result handler functions. Maybe just add the handler in the HTTPService definition. Why are you removing it each time?
              resultFormat="e4x"
              useProxy="false"
              result="onResultHandler"
              • 4. Re: Flex + php + mySQL query problem
                Level 7
                well... I do that because there are two different handler events for the
                results:
                onResultHandler for the updateDB()
                onInsertItemResultHandler for the instertRecord()
                I've tried to add the listener in the HTTPService definition... just
                thinking in updateDB(), but it still retrieving the correct values for the
                first time.
                thanks again!
                lapr
                "Greg Lafrance" <webforumsuser@macromedia.com> escribió en el mensaje
                news:gqifnl$8im$1@forums.macromedia.com...
                > are
                > resultFormat="e4x"
                > useProxy="false"
                • 5. Re: Flex + php + mySQL query problem
                  Level 7
                  "LAPR" <aperez@bcnmultimedia.cat> wrote in message
                  news:gqi8sb$m7$1@forums.macromedia.com...
                  > Hi all,
                  > time it gets the correct values... I can insert an other row in my db, but
                  > I can't update a dataGrid never more. I'm getting crazy...
                  http://www.magnoliamultimedia.com/flex_examples/Amys_Flex_FAQ.pdf
                  Q7
                  • 6. Re: Flex + php + mySQL query problem
                    Level 7
                    :) yeah!!!!! it works...
                    The browser has cached the response it got from the first call you made to
                    the page. This means that you need to either change how you are calling the
                    page so it appears to be a new request, or you need to change the page
                    itself so that it won't be cached. To change how you are calling the page,
                    append a unique value to the end of the
                    URL. For example, new URLRequest('yourPage.asp?param="+(new Date()).getTime)
                    _params = {"method": "getAll", "date": (new Date()).getTime()};
                    ...thanks a lot!!!
                    lapr
                    "Amy Blankenship" <amySpamFilter@magnolia_pleaseNOspam_multimedia.com>
                    escribió en el mensaje news:gqisbe$nq8$1@forums.macromedia.com...
                    >> Hi all,
                    >> but I can't update a dataGrid never more. I'm getting crazy...
                    >> works, but the update just works for the first time again.
                    > Q7
