2 Replies Latest reply on Jul 24, 2011 3:41 PM by JJ0330
    Script Labels in Applescript and InDesign 5.5.
    JJ0330 Level 1
      I must be missing something because this should be simple.  Just trying to assign label to an object and then refer to that object by label later.
      Just put first move to make sure it works and does move when refer to as just rectangle 1 but not when label name later.  Get error "Can't get rectangle "Rectangle1"".  Thanks.
      tell application "Adobe InDesign CS5.5"
      tell document 1
        tell rectangle 1
         move to {2, 2}
        end tell
        set label of rectangle 1 to "Rectangle1"
      --Get error here.
        tell rectangle "Rectangle1"
         move to {4, 4}
        end tell
      end tell
      end tell
      set myGroup to make group at page 1 of myDocument with properties {group items:{myTextFrameA,
        • 1. Re: Script Labels in Applescript and InDesign 5.5.
          Muppet Mark Level 5
          Im not sure you were able to target items by label strings before… I recall some changes to labels but can't find that post now… Any hows you look like you need to make a variable to the object first and use that…
          tell application "Adobe InDesign CS5"
               tell document 1
                    set FirstRect to first rectangle
                    set label of FirstRect to "Rectangle1"
                    tell FirstRect
                         move to {20, 20}
                         delay 1
                         move to {40, 40}
                    end tell
               end tell
          end tell
          Labels are just a property so you can get later by using a filter…
               tell document 1
                    tell rectangle 1
                         move to {20, 20}
                    end tell
                    delay 1
                    tell (first rectangle whose label is "Rectangle1")
                         move to {40, 40}
                    end tell
               end tell
          end tell
          • 2. Re: Script Labels in Applescript and InDesign 5.5.
            JJ0330 Level 1
            Thanks again, that will work.
